Leaking Sunroof - Page 4
Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 67
Like Tree1Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Leaking Sunroof in Cadillac CTS-V Series Forum - 2009-2015; I have a STS 2008 with the same problem, the front drainage are clogged. Di someone now how to fixed? ...
  1. #46
    Ariel Segarra is offline Cadillac Owners Member
    Automobile(s): STS 2008
    Oct 2013
    6
    Re: Leaking Sunroof
    I have a STS 2008 with the same problem, the front drainage are clogged. Di someone now how to fixed? were are the tubes? how to rich it
  2. #47
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,674
    Re: Leaking Sunroof
    Quote Originally Posted by Ariel Segarra View Post
    Hello Ariel Segarra,
    I am sorry you are experiencing a leaking water issue through your sunroof. I see you are new to the forum and I would like to welcome you to the Cadillac community. Gregory and I monitor the Cadillac forums and are here to assist. Please contact us via private message and include your full contact information, VIN and current mileage. I would like the opportunity to discuss your situation with you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  3. #48
    tinman's Avatar
    Jul 2006
    Jacksonville, Florida
    8,867
    Re: Leaking Sunroof
    Here's something that may help:
    Sunroof Adjustment for Wind Noise & Leaks
    There are 4 adjustment screws. First, there are two in the rear. Next, sit in the car with the sunroof closed, carefully peel back slightly the vinyl/rubber trim between the headliner and the sunroof. Work your way toward the front of the car and you will find the other two adjustment screws. To eliminate the noise, you must make an adjustment using all four screws.
    Prior to making any adjustment, locate the source of the noise. Take a new, stiff dollar bill and, from outside the car, slide it between the roof and the sliding portion of the glass. Do this on all four sides of the glass and note where the bill slides in easily. This gives you a target area to adjust the glass in that direction. Note: no adjustments should be or can be made to the fixed portion of the glass.
    Now, go back inside the car and once again locate the four adjustment screws. These screws can be adjusted with the sunroof in the closed position. Loosen the screws and physically maneuver the glass toward the gaps that you located with the dollar bill. Tighten the screws. Go back outside and do the dollar bill test again. If any new gaps are found, readjust the screws. Take a test drive and the noise should be significantly diminished. I made 3 or 4 readjustments and test drives before I eliminated the noise completely.
    Even with the final adjustment, the glass and the roof are not completely flush with each other. In fact, when I adjusted the glass flush, the noise actually became louder. I believe the water leak was due to a misaligned sunroof and not due to a plugged drain or anything else. I have not had any leaking or noise problems since I used the above procedure. It is a trial and error method that takes a little patience but it works well, costs nothing, and the cabin is quieter now than when I bought the car.
    Sunroof water leak in passenger floor area
    Try using a turkey baster as a “toilet plunger” and work the drain with water in it. Try the ol’ “in and out” routine until it hopefully forces the water and debris out the drain line. Then the light bulb went off. With the drain lines full of water along with the sunroof tray, I put the turkey baster directly on the drain hole and started pumping. I started feeling some resistance and then the clog finally gave way. A perfect stream of water was now flowing onto the driveway at the bottom of wheel well.
    OR
    Use thick monofilament or weed wacker line to run through the 4 drains. Smooth out the cut end of the line with sandpaper to help it slide through the drains.
    Open sunroof.
    Front: Take a cup of water and carefully pour into front drain channel to gauge initial drain rate. Use weed wacker line and rod out front drains from roof. The front drain lines run down the "A" pillars and exit out the side (behind the fender) about a foot below the top of the dash, about 3-1/2 feet. Pour more water and observe draining. Run weed wacker line again. Repeat until satisfied. You should notice the run off puddling behind the front wheels and may also observe dirt/sludge/algae that was in the lines.
    Rear: The rear drain lines run down the "C" pillars into the trunk and exit out the rear wheelhouses. Peel back the sides of the trunk liner to access the drain lines. The right rear drain line can be seen by removing the battery access cover, but it is difficult to work with unless you peel back the liner. Detach the rear lines from the wheel well grommets and run weed wacker line up the drain lines. The distance from the drain outlet to the sunroof is about 4-1/2 feet. Place the drain line in a bucket or bottle. Carefully pour water into the side drain channels of the sunroof. You may want to have someone pour water in the channels while you observe the flow into the bucket/bottle. Run weed wacker line again. Repeat until satisfied.
    All sunroofs leak some water and that leak off is normally handled by the drain lines. IMO this sunroof is a flawed design for two reasons. (1) The fixed portion of the sunroof uses the same type of perimeter seal the moving portion uses and therefore doubles the amount of leak off compared to a standard sunroof; (2) The drain lines are undersized even for a standard sized sunroof. As a result of this, the drain lines, at best, are barely adequate for a light rain. Throw in a little bit of clogging and a more intense rain and we get what we all complain about. After constantly cleaning lines and still living with leaks, I removed my headliner to see if I could resolve this problem. I replaced all four lines with 1/2" I.D. tubing in place of the factory 1/4" I.D. and have had zero leakage even in a total downpour (I live in Florida).
    Use 1/2" I.D - 5/8" O.D. clear hose from any hardware store. I considered 3/8", but why not not use the largest size that will fit?
    The 4 drain nipples on the corner of the sunroof are 1/2” O.D. There is a grommet on each corner that reduces them to 3/8” O.D. to fit the original drain lines. The clear hose fit perfectly on the sunroof nipples once the reducer was removed. There are clips on the stock hose that keep them in place (2 in the rear and 3 in front - 2 on "A" pillar, 1 under dash). Remove the clips from the stock hose, tape precut lengths of new hose to them (roof side) and then pull the whole thing through the trunk and underdash, respectively. Place a grommet around the front lines and secure the grommet to the existing inner fender holes. The fronts were a pain to get to and you have to slightly enlarge the hole to accomadate the larger grommet. The rears were easy. Secure the new hose to a 1/2” nipple and push it through the existing wheelhouse grommet.
    Removing and reinstalling the interior parts (especially the headliner) takes patience and took the longest time, but is not overly difficult. I removed the headliner from my car, but I would recommend leaving it in and trying to work around it. There are two electrical harnesses that are glued to the headliner that I had to remove and then reattach when installing.
    Originally Posted by loosend
    What so you mean about the 1 under the dash and how does that one come into play? Is it the AC condenser drain tube or related to the sunroof? How do you get to that one under the dash?
    The nylon clips clamp around the hose and then push into a body hole with a barbed end. In order to pull the stock hoses out you have to remove these clips. The front hoses have two clips on the "A" pillar that are easily removed. There is a third hose clip that can only be removed by reaching under the dash. The sunroof drains only drain the sunroof.
    *Remove the front kick panels (these are the plastic side panels under the dash - to the left of the driver's feet, right of the passenger's feet.
    *Remove under dash trim plates - plastic panels under driver and passenger dash area - both have lights that need to be unplugged. Passenger side has airbag control module (I think it was) that needs to be unplugged also.
    *Once these panels are removed, reach up and peel back the carpeting from the outer corners. The carpeting has attached insulation and is fairly rigid so takes a little effort to move. On the driver’s side there is also a styrofoam wedge (dead pedal) that I found easier to remove and then glue back to the carpeting.
    *With a light, look up under the dash to the now exposed side area (I ended up on my back for this part). You should see the drain hose coming down (if you follow the hose up you should now see the third clip) and then going through an access hole and finally plugging into a grommet in the inner fender. Tugging a little on the drain hose from above (while you're lying under the dash) may help to identify what you are looking at.
  5. #49
    Oct 2013
    6
    Re: Leaking Sunroof
    Thanks This will help me very much.
  6. #50
    tinman's Avatar
    Jul 2006
    8,867
    Re: Leaking Sunroof
    Glad to help. You're welcome.
  7. #51
    DCV
    DCV is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTSV bone stock
    Dec 2012
    Washington DC
    53
    629
    Re: Leaking Sunroof
    Great! My sunroof has wind noise too. I'll adjust it this evening. So once you've found the gap you loosen the screws to loosen the glass and move the whole assembly in that direction?
  8. #52
    tinman's Avatar
    Jul 2006
    8,867
    Re: Leaking Sunroof
    I have not had to do this personally. I have compiled a list of items that pertain to our cars into a "CTS Knowledgebase". I keep some random repairs and DIY stuff.
  9. #53
    straightravage is offline Cadillac Owners Member
    Mar 2014
    6
    Re: Leaking Sunroof
    Hello, I am new to this forum.
    I just purchased a CPO 2012 CTS-V just over a month ago, love the car!
    EXCEPT today, after raining for 3 days straight and raining for the past two weeks off and on,I noticed my cars interior to be soaked. The rear passenger footwell area is socked. So I looked in the trunk where the battery is located, I noticed that the battery has water and condensation on it.
    So I call up my local Cadillac dealership in Waldorf MD, the amazing lady there told me the drain lines get clogged all of the time. She said it's NOT covered under warranty. I have to pay for anything related to water damage. My rear interior is soaked and it's my fault that I just purchased this car not even a month ago and now it's all my fault!
    Also, I have noticed that recently there has been a poop smell to my interior... I thought I might have stepped in dog crap...but I know I am super careful with my car PERIOD. So I assume that the smell is due to my interior being wet.
    Does anyone know if a wet interior can smell like faint poop??
    Also, can anyone lease help me find a Cadillac service center that actually cares???
    I live in southern MD, I am close to DC I am willing to drive to have my car looked at.
    To the Cadillac service center in Waldorf MD, they are a GM/Honda service center, so maybe they don't actually specialize in Cadillac service?
    I BEG ANYONE TO PLEASE HELP ME!
  10. #54
    tinman's Avatar
    Jul 2006
    8,867
    Re: Leaking Sunroof
    First, welcome to your Forum. Glad to have you with us.
    Since I live in Florida I can't help with a dealer, but someone out there surely can.
    straightravage likes this.
  11. #55
    6104696 is offline Cadillac Owners Connoisseur
    2,178
    Re: Leaking Sunroof
    If anyone can help you, it is Lindsay Cadillac in Alexandria VA. They will do whatever they can to make it right, and they have great techs and great service advisors, and a great service manager. That having been said, though, if GM says it's not a warranty item, you can't expect a dealer to do it for free. You would need to work with GM.
    But Lindsay is among the best in the business.
  12. #56
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,840
    Had flood water just creep into the carpet in my old Camaro. Yes, it will smell moldy in no time. Once the jute underneath is soaked you're screwed. I ended up getting all new carpet and it looked great afterwards. Best of luck with it.
  13. #57
    tinman's Avatar
    Jul 2006
    8,867
    Re: Leaking Sunroof
    Same thing happened to my dad's Lexus, trapspeed. Remove/replace that carpet and good to go. In the Florida sun it took no time to get moldy and phew-y!
  14. #58
    Mar 2010
    Detroit, USA
    12,674
    Re: Leaking Sunroof
    Quote Originally Posted by straightravage View Post
    Hi straightravage,
    Welcome to the forum, I am sorry it is not under better circumstances.
    I understand your frustration with this situation and I would like to look into it for you. If you would please PM me your VIN, mileage, and contact information, I can set up a service request and contact a dealership on your behalf. Hope to hear from you soon.
    Austin J.
  15. #59
    silky17 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS Black Cherry
    May 2014
    5
    Re: Leaking Sunroof
    I'm having the same leaking sunroof with my 2008 Cadillac CTS with only 18,000 miles. I would like to know if GM will cover the expense on my leaks. I live in the NYC area. Please help!!!
  16. #60
    tinman's Avatar
    Jul 2006
    8,867
    Re: Leaking Sunroof
    Offhand, I don't believe GM will help you. Your '08 has gone beyond its warranty.
  17. Remove Advertisements
