Oil Catch Can I've Selected and why
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2009-2015 Cadillac CTS-V General Discussion Discussion, Oil Catch Can I've Selected and why in Cadillac CTS-V Series Forum - 2009-2015; I've 95% decided to buy this catch can and install. It is easily reversible and I will monitor the oil ...
    gonfishin is offline Cadillac Owners Connoisseur
    Dec 2007
    4,150
    It is easily reversible and I will monitor the oil buildup in the can and the oil level via the engine dipstick to see what is going on.
    The reason I'm going with this can is because of the quality, the built in dipstick and the port on the bottom which will aid in emptying. I'll probably go with the black or brushed. I haven't decided yet. I'm leaning toward the black.
    I stopped by the dealer today and spoke to their SC guy Chuck and we had a 30 minute discussion on it. Again, easily reversible. Just reconnect OEM Lines
    Here is the line to the intake and the breather lines to either bank.
    There are various negative effects when excess oil vapor contaminates the intake
    system from the stock PCV system - such as:
    *Throttle body and/or MAFS (Mass Air Flow Sensor) malfunction or failure.
    *Air filter, intercooler (if equipped) and intake ducting contamination if oil pools and run back out the intake system after engine shutdown.
    *Reduced octane of the air/fuel mixture, which can cause detonation and the ECM (Engine Control Module) to retard timing, thereby reducing engine power.
    *Excessive carbon build-up on valves, piston crowns, combustion chambers and spark plugs. This also increases the chance of detonation and power loss.
    *Increased emissions & possible contamination of catalytic converters and oxygen sensors.
    Bottom line: Excessive amounts of oil vapor in the intake manifold is detrimental to
    your engine!
    The Can:
    http://www.42draftdesigns.com/catego...catchcans.html
    09V
    09V is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS V
    Sep 2009
    226
    Re: Oil Catch Can I've Selected and why
    Looks like a real nice piece. I may have to invest in one myself. Maybe you can "test" it.
    Dec 2007
    4,150
    Seems like this has not been done, so I will test it and then record the mileage and empty after say 1,000 miles with a photo of the amount of oil
    captured. Looking forward to see what the results are.
    Fubar75207 is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V
    Mar 2009
    Dallas, TX
    44
    231
    I would just let it drain out to the ground. I have a friend who recently got into a hydro-lock scenario because he failed to empty the drain canister in a timely manner. Emissions are stupid... Gore is full of shit, we need more petrol
    Gary Wells is offline Cadillac Owners Connoisseur
    Automobile(s): '09 CTS-V, 3K miles & '87 Turbo Buick, 29K miles
    May 2009
    Long Beach, Kali
    72
    3,435
    Will make a nice addition to your already beautiful motor compartment, Curtis.
    Dec 2007
    4,150
    Not comfortable letting it drain to the ground.
    1.) Don't want oil on underside of car
    2.) This can has a dip stick! So won't get too full before being checked.
    Dec 2007
    4,150
    Quote Originally Posted by Gary Wells View Post
    Thanks Gary!
    Razorecko is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V , 2010 SRX 2.8T
    Feb 2008
    3,085
    Good stuff Curtis ! , keep us updated on this
    Dec 2007
    4,150
    Can arrives tomorrow. I will post pics of install and once some miles are put on it, will post pics of amount of oil collected.
    mpouls1's Avatar
    mpouls1 is offline Cadillac Owners Enthusiast
    Automobile(s): '09V 11.99@118mph stock, '15i Escalade ESV, '03 Silverado LT
    May 2009
    iatethebones
    646
    I am interested to see what happens. I've always wondered why don't the manufacturers just install something like this. Are they too lazy or cheap? I look forward to seeing the results. I'm sure it will be a great addition to your already beautiful motor.
    Feb 2008
    3,085
    Quote Originally Posted by mpouls1 View Post
    would you trust car owners to routinely check the catch can before it overfills ? Seems like alot of people nowadays dont even know how to check their own tire pressure....It would be a nice "side option" though.
    Prof's Avatar
    Prof is offline Cadillac Owners Enthusiast
    Nov 2008
    Wadsworth, IL
    826
    High horsepower vehicles with forced induction have some blow-by. I think as long as we have cooler/damper weather you will get some condensation in the catch can and a small amount of oil spray. You will probably have a few drops of oil in the condensation...my truck catch can needs to be drained every 4 or 5 hundred miles this time of the year, I get possibly a half a cup of moisture with a little congealed oil in it.
    I have a tube that allows one to read the level of the moisture in the can...depending on your success I may add one to the V2 since I have done the Lingenfelter upgrade too.
    (Curtis, I should have a package for you early next week!)
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V, '13ZL1, '12 V, '16 Z06 SC757
    Feb 2004
    Killer of diffs 7X
    50
    6,441
    Curtis,
    Nice piece. But honestly your fender well is thinking some really crazy shit.
    Any thoughts about contacting billet tech? They do some really nice stuff for the LX/LY guys.
  16. #14
    Dec 2007
    4,150
    Chris,
    Love the engine bay. I thought about Billet technology. However I wanted something that you didn't have to unscrew to check the oil level or empty.
    I had one from Billet Technology on my 300 SRT8 and wanted something different this time.
  17. #15
    IBNR's Avatar
    IBNR is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V (Silver over Black Recaros)
    Jan 2010
    Santa Clara, CA
    322
    Curtis: Will you post install/results in this thread? Seems like a mandatory *subscribe*!
    Thanks for taking the lead here....
  18. Remove Advertisements
