Rear end fluid change - not happy - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 86 of 86
Like Tree3Likes
2009-2015 Cadillac CTS-V General Discussion Discussion, Rear end fluid change - not happy in Cadillac CTS-V Series Forum - 2009-2015; Ty....I did go back on thier site, this was part of the products description... Contains additional friction modifiers for suitability ...
  1. #76
    Speedtrapped is offline Cadillac Owners Fanatic
    Automobile(s): 11' cts-v wagon
    Jul 2011
    48
    389
    Re: Rear end fluid change - not happy
    Contains additional friction modifiers for suitability with clutch-type limited slip differentials - for most LSDs, no additional friction modifiers are required
    I have driven for 50 miles since change...no noise
  2. #77
    kirks5oh is offline Cadillac Owners Member
    Automobile(s): 2009 escalade esv
    Aug 2009
    wisconsin
    40
    63
    Quote Originally Posted by baabootoo View Post
    Who/what caused the whine though? Was it there from the beginning?
    hard to know for sure if it was there all along. i just bought the car (2010 with 11k miles) two months ago, and the fluid change was done within 300 miles of owning the car. to be honest, you can't hear it with the radio up or the windows down, which is how i drive the car normally--
    for whatever reason, i've only been able to put in about a quart and a half at most--car is level on a lift
  3. #78
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by Speedtrapped View Post
    Amsoil used to say the same thing. Then they changed. Remember, it says "most". The V is certainly more than the usual...
  5. #79
    Jul 2011
    48
    389
    Well no whine, but if add additive and redline has it, will the extra harm the diff?
  6. #80
    Automobile(s): ZIP
    51,885
    I don't think so. But the additive isn't really for whine, but for keeping the clutch packs from groaning...
  7. #81
    Jul 2011
    48
    389
    Quote Originally Posted by thebigjimsho View Post
    ok, appreciate the feedback. I will pick up the additive
  8. #82
    Z71's Avatar
    Z71
    Z71 is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    May 2005
    1,379
    From AMSOIL Severe Gear 75W-90 web page
    AMSOIL Severe Gear is compatible with most limited-slip differentials. If limited-slip differential chatter occurs, add AMSOIL Slip-Lock friction modifier additive.
    I have this in the rear and front axles of my 09 CTS4 and my 2010 GMC Sierra Z71. Not any problems. I prefer AMSOIL because it made just a few hundred miles from me in Superior, Wisconsin (Duluth, MN).
    Gear whine it caused by the meshing of the ring and pinion gears and you hear the noise when there is pressure on them, never when coasting. It appears to be a normal noise associated with the CTS and it may be related to the aluminum housings not drowning out the noise. I thought I read a service bulletin that said to add more insulation somewhere to deaden the noise if customer complains but I cannot find it at the moment.
  9. #83
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,781
    You guys use Amsoil, and you're squawking over another $10???????????
  10. #84
    Automobile(s): ZIP
    51,885
    Quote Originally Posted by Z71 View Post
    amsoil added an addendum to add friction modifier. As for the V2, we have iron diffs as opposed to V1's aluminum...
  11. #85
    Z71's Avatar
    Z71
    Automobile(s): NONE
    May 2005
    1,379
    From where do you get that information?
    AMSOIL Severe Gear Data Bulletin
    The info I gave comes directly from the AMSOIL web site and literature. Unless you are referring to the If in the statement being the addendum.
    AMSOIL Severe Gear is compatible with most limited-slip differentials. If limited-slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifi er additive.
    NOTE - To those with GM trucks, i.e. Escalade, Denali, Sierra, Silverado, Tahoe, Yukon. YOU DO NOT have a limited slip differential in most instances. If you have G80 option it is a LOCKING rear differential and the use of any additional additive in the locking differential can cause the locking mechanism to slip and miss engagement and lead to differential failure (per GM technical bulletins). Limited slips are coded as G86 and were only used in rear steer suv and truck. Only GM cars use Limited Slip differentials.
  12. #86
    Automobile(s): ZIP
    51,885
    OK, first off, do you own a V? I do and I run Amsoil in my diff. Ran it without the friction modifier(as I did in my '04, without problems). Yet, in my '09 the diff started to groan on turns in colder weather and then did it in all weather. Now, when I changed the fluid again, I added the friction modifier. No problems at all.
    I can't find the right thread, but there is this one from one of Amsoil's very reputable vendors...
    http://www.cadillacforums.com/forums...ormulated.html
    No matter what, you NEED the friction modifier with the Amsoil Severe Gear in the V2. Period.
  13. Remove Advertisements
