V2 Tranny fluid check?
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
2009-2015 Cadillac CTS-V General Discussion Discussion, V2 Tranny fluid check? in Cadillac CTS-V Series Forum - 2009-2015; How? where? Who? Huh??? Lol. What do you do to check it???...
    chopmeat's Avatar
    chopmeat is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Dec 2008
    527
    Lol.
    chopmeat's Avatar
    Dec 2008
    527
    Re: V2 Tranny fluid check?
    Geez, over 110 views and not 1 comment???
    No dipstick?
    Check from the transmission underneath?
    nradcad is offline Cadillac Owners Enthusiast
    Automobile(s): 09 V B-B
    Aug 2009
    Houston
    39
    502
    have you searched yet?
    SlvrBullIT is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2009
    557
    Most likely temp will be the best indicator with no dipstick available....... I also looked at the plug on the fill hole to the pan to see what level it was at.
    chopmeat's Avatar
    Dec 2008
    527
    Yeah, I did many searches and I see in the CTS V Book that it is very difficult to check and can only be done from the bottom at the tranny I assume.
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    According to the owner's manual, there is no need to check the automatic transmission fluid level if there is no loss of fluid. This information can be found on page 5-29 of the owner's manual. Unlike previous automatic transmissions, there is no dip stick provided on the automatic transmission of the 2009 CTS-V. As a result, checking the fluid level and/or condition envolves having the transmission in a specific temperature range, the car running and in Park, raising the car and then removing a plug from the bottom of the transmission case.. As a result, the owner's manual suggest that the automatic transmission fluid level be checked only by the dealer. For those who can do everything for themselves, the following is extracted from the factory service manual.
    The car must be raised and the fluid level/condition checked by removing the plug from the bottom of the transmission pan. In theory, if the fluid level is correct, only a few drops of fluid will come out of the plug hole. If too much fluid is present, let is run out until the flow stops. If too little fluid, add appropriate fluid until it starts to overflow. In any case, the fluid must be in the designated temperature range, the car running, and the transmission in Park. Doing this check while not meeting these conditions will result in an incorrect check. Replacing the fluid is even more complex and is not discussed here.
    nynd is offline Cadillac Owners Fanatic
    Automobile(s): 13 M5. SOLD:11 BD CTS-V, 6M, Loaded - SOLD:09 CTS-V (Auto)
    May 2009
    446
    Easiest thing is measure what comes out at a stable temp and then refill with the same amount. The new tranny fluids seem to have a property of expanding with increasing temperature.
    chopmeat's Avatar
    Dec 2008
    527
    Yeah I saw that in the manual before.
    Sounds crazy.
    I'm going to the Vette Doctors and they'll check and change everything.
    I bought that donut that W4me sells that goes behind the SC pulley to stop the noise and the stock spring damaging the pulley stalk.
    musclesbmf is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 GTR
    Jan 2009
    Tampa, FL
    45
    1,026
    tedcmiller:
    Would you mind posting up the service procedure for replacing the auto tranny fluid for us DIY guys, since it is said to be a "complex" procedure?
    thanks,
    Mark
    Apr 2004
    1,827
    Sorry, it is several pages in the factory service manual and envolves removing a fitting from the top of the transmission, installing a hose and pump to remove the old fluid, etc. If you are really into "doing it yourself," I would suggest that you invest in the factory service manual offered by Helm.
    Jan 2009
    Tampa, FL
    45
    1,026
    ok... thanks.
    Jan 2009
    Tampa, FL
    45
    1,026
    As posted on corvette forum (I love that place).
    Transmission Fluid Fill Procedure
    Notice: Use Dexron VI transmission fluid only. Failure to use the proper fluid may result in transmission internal damage.
    Perform this procedure for vehicles with transmissions that are not equipped with a fill tube and dipstick. Based on accessibility, transmission fluid may be added through the fluid fill tube plug assembly (1) hole or through the oil level check plug (2) hole in the bottom of the transmission fluid pan.
    Tools Required
    • DT 47784 Transmission Fluid Fill Pan Adapter
    • J 45096 Transmission Oil Cooling System Flush and Flow Test Tool
    • J 45096-30 Transmission Cooler Flush Adapters
    • J 45096-40 Transflow Oil Fill Adapter
    Fill Tube Plug Method
    Notice: Before removing the transmission fluid fill tube plug assembly, thoroughly clean around the plug to prevent dirt or contaminants from entering the transmission during plug removal. Use compressed air to dislodge any caked dirt that may be stuck on and around the plug area. Use a mirror to confirm the area is free of dirt before removing the plug. Failure to clean around the plug may result in transmission contamination.
    Clean around the fluid fill tube plug.
    Important: It may be necessary to use a long pair of 90 degree needle nose pliers to lift the plunger and remove the plug assembly.
    Unlock the fill tube plug by lifting the plunger. Once the plunger is lifted, remove the entire plug assembly.
    Determine the approximate amount of fluid needed to fill the transmission, based on the repair performed. Refer to Fluid Capacity Specifications . To avoid an under-fill condition, slightly overfill the transmission, and then allow the extra fluid to drain during the fluid checking procedure.
    Important: The J 45096 is being utilized as a convenient method to pump the fluid into the bottom pan. A suitable hand pump may also be used instead. When using the J 45096 , monitor the display panel to determine the amount of fluid being pumped from the tool supply tank into the transmission.
    Using the J 45096-40 (1) and the J 45096 (2), or a suitable hand pump, add transmission fluid through the fill tube plug opening. Refer to Transmission Fluid Cooler Flushing and Flow Test for complete J 45096 operating instructions. Use the FLOW position on the main function switch to pump the fluid.
    Check the fluid level. Refer to Transmission Fluid Check .
    Check Plug Method
    Important: When the oil level check plug is removed with the engine OFF, transmission fluid may drain from the hole.
    Remove the oil level check plug.
    Install the DT 47784 (1) and, if necessary, one adapter from the J 45096-30 (2).
    Using the DT 47784 (1), J 45096-30 (2), and the J 45096 (3), add transmission fluid through the check plug hole. Refer to Transmission Fluid Cooler Flushing and Flow Test for complete J 45096 operating instructions. Use the FLOW position on the main function switch to pump the fluid.
    Important: Failure to start the engine and move the shift lever through the gear ranges before removing the DT 47784 and J 45096-30 from the bottom pan will result in an excess amount of fluid draining from the check plug hole. This may lead to an under-fill condition.
    Start the engine and move the shift lever through each gear range. Pause for at least 3 seconds in each gear range.
    With the engine still running, remove the DT 47784 (1), J 45096-30 (2), and J 45096 (3) and then check the fluid level. Refer to Transmission Fluid Check .
    © 2009 General Motors Corporation. All rights reserved.
    chopmeat's Avatar
    Dec 2008
    527
    That is absolutely the funniest darn thing I ever read!
    Lol
    I think it's just easier to hold a hand saw at the back of my neck and proceed to cut until the "said" head drops off????
    lol
  16. #14
    Domsz06 is offline Cadillac Owner
    Automobile(s): 2009 CTS-V, 2007 Z06
    Jul 2010
    Houston Area
    38
    2,843
    so what is the capacity? anyone know that? When you google you get all kinds of differences since all the different cars use different convertors...
  17. #15
    markrn is offline Cadillac Owners Member
    Automobile(s): 11 V Sedan / 06 TBSS
    Aug 2010
    60
    71
  18. Remove Advertisements
