V2 Fuel Restriction
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
2009-2015 Cadillac CTS-V General Discussion Discussion, V2 Fuel Restriction in Cadillac CTS-V Series Forum - 2009-2015; I want to say thanks to Greg for the help. So been doing some research on the fuel restriction problem ...
    CadV is offline Cadillac Owners Connoisseur
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    V2 Fuel Restriction
    So been doing some research on the fuel restriction problem Jessie ran into around 15-16 pounds of boost.
    Here is a diagram of the fuel system on our cars:
    Here are the guts of the assembly which is part# 19207950:
    You will notice the pumps and how they have a pin size opening for the fuel. It was common for FBodies and GTO's to replace this part with one that allows more fuel.
    The thing I am trying to figure out is what part we can use to do the same thing. Can anyone help?
    jlford30 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jun 2009
    65
    Re: V2 Fuel Restriction
    I had heard a fuel system upgrade was in the works.....
    SSideways is offline Cadillac Owners Member
    Automobile(s): Cadillac
    May 2008
    66
    You could always purchase walbro pumps from Racetronix or APE that put out 255 ltr/hr. GSS340 or GSS307 come to mind. they have a larger inlet than stock fuel pumps.
    HTH
  5. #4
    1-2-N-V is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Apr 2009
    366
    I thought this was an injector problem not a pressure problem. You can always buy a bigger pump, but can the injectors handle the flow. I have a guy up here in Ossining NY, Chuck Mosello who works on Vettes and is very renounced in the Vette world. Says hey has a guy that can micro machine the jetting to give more flow. Don't know enough yet to comment. This Vette guy has worked with Jesse so he knows his stuff. I will be modding my pulleys soon and do want to make sure there is enough fuel for the added boost.
  6. #5
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    Quote Originally Posted by 1-2-N-V View Post
    Is that why he's trying to get his foothold in the V2 world?
  7. #6
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    The injectors are just fine. They are the same ones in the ZR1 that makes ALOT more power than us.
    The problem is the FUEL PRESSURE CONTROL MODULE. It is what pulses the pumps to make pressure. It is at 100% duty cycle meaning it cant produce any more required fuel VOLUME to maintain the commanded fuel pressure of 65 psi at wot. IF It could mantain the pressure OR run at HIGHER than stock settings without the fpdm knowing it is the fix. You cant just stick in a higher flowing pump very easily, as the fpdm is Pulse width modulated. Not the same as the others..
    Since the fpdm is only setup to go to 65psi stock, SO that makes the injector duty cycle 100% right at the 600rwhp mark... IF you can generate more flow that is fine and dandy BUT..... REMEMBER this is a closed system meaning there is only as much flow and pressure as the system can use. So if you put too much pressure/volume thru the system you will cause engine codes, and other failures as well as possible fpdm burnout and pump lockups. The FPDM has a window of duty cycle it can output. too low dead heads the pumps, too high makes too much pressure and makes an overly rich condition that is un correctable.
  8. #7
    Automobile(s): V2
    Jul 2004
    TX
    40
    1,079
    So Jess did you replace the fuel pressure control module with one for the ZR1 or something?
    Thanks for chiming in.
  9. #8
    Apr 2009
    366
    Yes Thanks Jesse for your correction.
  10. #9
    musclesbmf is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 GTR
    Jan 2009
    Tampa, FL
    44
    1,026
    more info.... more info.
  11. #10
    wait4me's Avatar
    Jan 2009
    warsaw indiana
    2,997
    Sure you could try the zr1 controller. You should do a price check at your dealer for that.......
  12. #11
    Domsz06 is offline Cadillac Owner
    Automobile(s): 2009 CTS-V, 2007 Z06
    Jul 2010
    Houston Area
    38
    2,843
    So the question is what do we do to fix our issue? Get LPE's boost a pump or what?
    Love to hear more for obvious reasons.
  13. #12
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,840
    Quote Originally Posted by wait4me View Post
    Pressure times volume equals a constant, so if a given injector is running wide-open, the only way to increase volume at that point is to increase pressure.
    However, if the stock fuel pump can deliver its max pressure at a higher-than-stock flow rate (volume), then larger than stock injectors should also be able to deliver more fuel to the engine. But if the stock fuel pump's max pressure decreased as volume went up, then larger injectors wouldn't help.
    So tuners: can our stock fuel pumps deliver their max pressure at higher-than-stock flow rates? Or do they drop off?
  14. #13
    Jul 2010
    Houston Area
    38
    2,843
    Quote Originally Posted by GMX322V S/C View Post
    this area is kinda vague..... Kinda sounds like a BAP is needed....
  15. #14
    DrumStix is offline Cadillac Owner
    Nov 2009
    1,651
    I read a post in the other fueling thread today where James was claiming a logged value of 49 psi or so and dropping at 6000 rpm.
    "On CTS-Vs within these power ranges, if you log fuel pressure via your datalogger (such as HPT or EFIL), you'll more than likely find that fuel pressure will drop by the end of the pull to 49 to 51 psi (or lower), regardless of commanded pressure via the tune. Here is a datalog of my friend's CTS-V2 showing the various pids logged (I cut out some of them that weren't as pertinent, to decrease file size), including fuel pressure:
    Read more at http://www.cadillacforums.com/forums/cadillac-cts-v-series-forum-2009/217343-cts-v2-fuel-system-warning-important.html?ktrack=kcplink"
    http://www.cadillacforums.com/forums...important.html
  16. #15
    RWTD's Avatar
    RWTD is offline Cadillac Owners Member
    Jan 2009
    Mobile, AL & Denver, CO
    41
    38
    Quote Originally Posted by DrumStix View Post
    I actually took that out of my post just now, as I can see where it will cause some confusion. Basically, one can take it as fuel pressure is dropping drastically, therefore the pumps must be done. In actuality, the pumps have plenty left, BUT the injectors are too small at the amount of fuel pressure to properly support the power ranges I quoted in my other thread. Also, the 49-51 psi fuel pressure I was discussing was actually the DeltaP, not the actual pressure out of the pumps (which was 65 psi). DeltaP is Actual pressure minus boost.
  17. Remove Advertisements
