Results 1 to 7 of 7
Thread: CTS-V options
    Pounder is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    20
    CTS-V options
    I keep on reading that V's in reviews had a track option package with better brakes etc....
    But nowhere do I see that as an option anymore.
    Is this now standard on the car?
    If not; is it still offered and how much is it?
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    Re: CTS-V options
    Dealer installed option.
    Oct 2008
    20
    Re: CTS-V options
    Are the dealers installing the Brembo brakes and the extra cooling?
  5. #4
    Dec 2004
    Leesburg, Florida
    2,190
    Re: CTS-V options
    The "track" brake package will be Dealer installed, but probably not available until next year. All CTS-Vs come with Brembos- the track package just adds red painted calipers and non-slotted front rotors. Braking performance should be very comparable between the two, with a slight edge to the non-slotted ones at higher speed (more swept area for the pads to grab). Once the package is out there, it's possible it may become orderable on the car, then installed at the Dealer (similar to the FG2 shocks on the first CTS-Vs).
    Same deal with the rear differential cooler: Optional Dealer installed accessory for the track hounds, and not available at start of production.
  6. #5
    V-Love's Avatar
    V-Love is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTSV(killed), 2005 CTSV(killed that too). 2004 DTS.
    Mar 2004
    North Cuba
    1,574
    Re: CTS-V options
    Quote Originally Posted by Cadillac Tony View Post
    Tony, I thought the track brake package was a 2 piece,floating rotor set up and standard rotors were the big single donuts.
  7. #6
    Dec 2004
    Leesburg, Florida
    2,190
    Re: CTS-V options
    You're half right.
    The track package front rotors are genuine "two-piece" rotors where the rotor is separate and bolted to the hat. The stock rotors however, are "co-cast", meaning the braking surface is cast iron bonded to an aluminum hat to create a single piece made of two different metals (as opposed to the all iron "donut" on the current CTS-V).
    Unless you plan on heavy track use, the upgrade package won't provide any noticeable difference in street driving.
  8. #7
    Oct 2008
    20
    Re: CTS-V options
    Thanks for the info. I'm now back on track
  • You may not post replies
