V1 vs. V2 headlights - something worth quibbling about
Results 1 to 11 of 11
2009-2015 Cadillac CTS-V General Discussion Discussion, V1 vs. V2 headlights - something worth quibbling about in Cadillac CTS-V Series Forum - 2009-2015; As someone who's lovingly stuck with the V1 (but admittedly drooling over the V2) something occurred to me the other ...
    razl's Avatar
    razl is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac CTS-V Light Platinum
    Sep 2007
    Orlando, FL
    237
    As someone who's lovingly stuck with the V1 (but admittedly drooling over the V2) something occurred to me the other day...
    On the V1, the low beams are at the top of the headlights and highs are at the bottom, on the V2 it's reversed (I'm presuming the arrangement of the V2 are the same as the 09CTS).
    I definitely like the V1 better because the arrangement just seems more unique, those HIDs being right at the top of the hood just look menacing at night. (The only other vertical stack I can think of is the prev gen G35, and I think those were the same arrangement).
    Why would they have reversed them for V2?
    Maybe I'm just consoling myself psychologically with reasons to keep loving my V1 in the face of the coming V2....
    Cadillac Tony is offline Cadillac Owners Connoisseur
    Dec 2004
    Leesburg, Florida
    2,190
    Re: V1 vs. V2 headlights - something worth quibbling about
    Quote Originally Posted by razl View Post
    I think you're right.
    There's several differences between the Sigma and Sigma2 CTS headlights, mainly that the new ones are Bi-Xenon, and use the same bulb for high and low beams (a motorized reflector in them changes the angle). The new headlights also turn up to 15 degrees with the steering at night, looking through the apex of a corner before you enter it, which is really neat.
    From a cosmetic standpoint, I assume that they moved the bulb to the bottom of the housing to reduce the "tall" look of the first CTS (a critique that more than one reviewer has mentioned in the new CTS articles). Which one looks better is just personal taste, but I think the new ones look awesome at night.
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    The low beams on the 2004-2007 CTS-V are HID. The separate high beams are not HID (standard halogen bulbs). Cadillac Tony is correct in that the 2009 CTS-V has only one lamp for both high and low beams with the low beam results from a mechanical shutter. However, I don't think the 2009 CTS-V lamp is halogen. It is HID as it was in the 2004-2007 CTS-V series.
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Quote Originally Posted by tedcmiller View Post
    Im lost. Noone said the new V would have halogens? Theyre bi-xenon...
    Apr 2004
    1,827
    Xenon is a halogen gas. The 2008 CTS-V does not use a halogen bulb with a tungsten filament for the headlamps. The 2004-2007 CTS-V always had HID low beams. The new CTS-V will have HIDs also, but there will be only one lamp with the low beam being produced by a mechanical shutter. The standard CTS might use non-HIDs. As an example, earlier STSs had a headlamp that outwardly appeared to be an HID, but was actually a halogen bulb with a tungsten filament.
    HPCC is offline Cadillac Owners Member
    Automobile(s): NONE
    Dec 2003
    L.A.
    74
    Xenon is actually a "noble" or "inert" gas that is ionized by the electric arc in an HID capsule; traces of Iodine, Bromine compounds, etc. make up the "halogens" in a halogen lamp.
    Dec 2007
    5,630
    Youre sorta right here. But HID systems do use xenon gas. HID bulbs contain xenon gas and metal salts. An electric arc ignites xenon gas very quickly, which gives off some light before the metal salts ionize and produce the really bright light. This is why typical HID systems look like they take 1 or 2 seconds to light up fully.
    Technically these are metal halide lamps, but its common to call them xenon bulbs in the car industry. MErcedes uses a similar setup, like the 09 V, and still call it bi-xenon.
    Dec 2004
    Leesburg, Florida
    2,190
    You're both wrong- Xenon gas is actually from the planet Xeno, and creates light when microscopic alien nanomachines are activated by the stalk mounted lever inside the car.
    Seriously.
    RightTurn's Avatar
    RightTurn is offline Cadillac Owners 10000+ Posts
    Sep 2006
    Keep Right™
    41,011
    lawfive's Avatar
    lawfive is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2011 CTS-V sedan; 2005 Maggied CTS-V; 2004 Lightning
    Sep 2004
    Steeler Nation
    12,006
    So why doesn't the 2009 CTS-V come with a collector dish to gather trace particles of xenon gas to keep the navigational sensor array... I mean the headlights charged? You'd expect that on a $70K car, right?
    What a ripoff. I'm buying an M5.
    Dec 2007
    5,630
    Quote Originally Posted by Cadillac Tony View Post
    ..alien nanomachines...
    Would these nanomachines clean my kitchen before the woman gets home? Im allready in trouble...
  14. Remove Advertisements
