Electronic Parking Brake Info
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
2009-2015 Cadillac CTS-V General Discussion Discussion, Electronic Parking Brake Info in Cadillac CTS-V Series Forum - 2009-2015; Due to the lack of any exciting new information, I'm reduced to posting anything V related I can get my ...
    Cadillac Tony is offline Cadillac Owners Connoisseur
    Dec 2004
    Leesburg, Florida
    2,190
    Due to the lack of any exciting new information, I'm reduced to posting anything V related I can get my hands on, even if it's parking brake.
    Seriously though- I've seen a few questions about this, so when I came across this info today I figured I'd share with the class.
    Kind of neat that it wil automatically disengage if an attempt is made to accelerate, which means it can be used for hill start assist on steep inclines to avoid roasting the clutch.
    I know it's not much, but it's all I've got today that's V related.
    CIWS's Avatar
    CIWS is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2015 BMUU 335i MSport, 2006 STS-V--2005 CTS-V ( traded in)
    Dec 2005
    D/FW Tejas
    25,514
    Re: Electronic Parking Brake Info
    Thanks Tony. All info is good to read about.
    lusterblade's Avatar
    lusterblade is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 CTS 3.6DI AWD
    Aug 2006
    Troy, MI
    29
    934
    I'll add some info too.
    Tap Shift
    To use Tap Shift, the shift lever must be in Manual Mode. Vehicles with this feature have switches on the back of the steering wheel. Tap the left switch to downshift, and the right switch to upshift.
    The tachometer display on the instrument panel cluster will show which gear the vehicle is in and a number indicating the requested gear range when moving the shift lever forward or rearward. See Speedometer and Odometer for more information on the odometer.
    CTS-V vehicles use tracer lights around the outside of the tachometer as a performance up-shift light. These tracers flash to indicate when to shift to the next higher gear to avoid the engine speed limit. See Tachometerfor more information.
    While using the Tap Shift feature, the vehicle will have firmer, quicker shifting for increased performance. You can use this for sport driving or when climbing or descending hills, to stay in gear longer, or to down shift for more power or engine braking.
    The transmission will only allow you to shift into gears appropriate for the vehicle speed and engine Revolutions Per Minute (RPM). The transmission will not automatically shift to the next lower gear if the engine RPM is too high.
    If shifting is prevented for any reason, the currently selected gear will flash multiple times, indicating that the transmission has not shifted gears.
    While in the Tap Shift mode, the transmission will not automatically downshift on hard acceleration.
    When accelerating your vehicle from a stop in snowy and icy conditions, you may want to shift into second gear. A higher gear ratio allows you to gain more traction on slippery surfaces.
    lawfive's Avatar
    lawfive is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2011 CTS-V sedan; 2005 Maggied CTS-V; 2004 Lightning
    Sep 2004
    Steeler Nation
    12,006
    DIC warning
    lol...
    lawfive's Avatar
    Sep 2004
    Steeler Nation
    12,006
    Stock shift light. Nice.
    CIWS's Avatar
    Dec 2005
    D/FW Tejas
    25,514
    Quote Originally Posted by lawfive View Post
    Here was a static display of the 09V gauge cluster.
    [YOUTUBE]XZrVhdAJj6E[/YOUTUBE]
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    FrgMstr is offline Cadillac Owners Member
    Automobile(s): Escalade '15
    Mar 2007
    Dallas
    39
    Feeling better and better about the automatic all the time.
    StealthV's Avatar
    StealthV is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 Z06 / 2013 F150 EcoBeast / 2008 Twin-Turbo Bimmer
    May 2004
    MN>ND>MN>SD>IL>MN>IL
    48
    4,860
    How does one adjust the EPB system to allow for lining wear?
    Slushbox: The transmission the V needed back in '04.
    ^^^ Can't believe I just typed that.
    Someone hacked my account.
    the cadillac kid's Avatar
    the cadillac kid is offline Cadillac Owners 10000+ Posts
    Automobile(s): > BMUU
    Mar 2007
    jersey
    14,388
    Quote Originally Posted by CIWS View Post
    +1, thanks C.T.
    RightTurn's Avatar
    RightTurn is offline Cadillac Owners 10000+ Posts
    Sep 2006
    Keep Right™
    41,011
    Quote Originally Posted by StealthV View Post
    Well, you're over 40 now after all. Time for the plaid pants.
    lawfive's Avatar
    Sep 2004
    Steeler Nation
    12,006
    Push the button harder.
    Ha! Must search for all previous "LawFive: I'm getting the auto..." StealthV: "Slushie slush sucky slushbox pop tart..." posts.
    Kadonny's Avatar
    Kadonny is offline Cadillac Owners Connoisseur
    Automobile(s): Owned 3 V's, now driving a GC STR8
    Dec 2004
    Pennsylvania
    53
    2,573
    Great info Tony, love the built in shift light.
    While on the subject, any info on the keyless entry and start system? Did you say the start will be a turn instead of a push? Also, will we get remote start? No info on the 09V page of Cadillac, maybe I should check Reeds site.
  16. #14
    Rich H's Avatar
    Rich H is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTSV
    Apr 2004
    Denver
    590
    Quote Originally Posted by lusterblade View Post
    Tap Shift
    Too many nanny controls on the automatic in "manual" tap shift - I'll gladly stick with the REAL manual tranny.
  17. #15
    Dualcams34 is offline Cadillac Owners Member
    Feb 2005
    60
    No need to worry about adjusting this animal. There is a module on top of the rear frame/cradle that is very smart and will adjust to whatever it takes to engage. As for holding on hills or any other thing related to movement forget it, it won't happen. The park brake module is watching every move you make.
  18. Remove Advertisements
