Emblem Removal - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Emblem Removal in Cadillac CTS-V Series Forum - 2009-2015; Thanks for that info, do you know the part # for the rear trunk wreath and Cadillac emblem (fora wagon ...
  1. #16
    camaroz06 is offline Cadillac Owners Member
    Mar 2014
    54
    Re: Emblem Removal
    Thanks for that info, do you know the part # for the rear trunk wreath and Cadillac emblem (fora wagon if it makes a difference)? I need at least the emblem, mine (the acrylic) is a bit scratched up.
    Quote Originally Posted by Spalding_Speaks View Post
    you can get GM parts on eBay. I always check because most dealers will price match as long as you can show them the part number. I can give you some numbers..is it just the V badge you wanted?
    the lowest you will get a new "V" emblem is about $71. (there are plenty that are $3-$35 but none are OEM)
    the "CTS" is way less than that and you can get those for around $15-$20.
    The actual wreath and crest are different from the trunk to the grill and most of those the best price is around $45-$55
    those are very good prices on GM badges. if you don't care if they're GM OEM, then you can get everything listed above for probably $35. your call there. hope this helps a little
    I've removed a ton of badges in my day, and personally the best way I've come across debadging is to use monofilament fishing line(anywhere from 6-12lb test) and just kinda massage it down from N to S. if you want, you can put masking tape around the edges of the badges to make sure you don't scratch the paint.
    after you get the badge off, use some rubbing alcohol or goo-gone/label sticker removal and wipe clean. I recommend waxing that spot after as well.
  2. #17
    Spartan 50 is offline Cadillac Owners Member
    Automobile(s): CTS-V
    May 2014
    Southern Maryland
    53
    7
    Re: Emblem Removal
    For Gary Wells "Jolly Roger" VF-84 ? look, Did you consider C6R 'Jake" ?
  3. Remove Advertisements
