Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
Thread: NEW Velgen VMB5 Wheels for CTS V Sedan!
  1. #46
    Deenasty83 is offline Cadillac Owners Member
    Automobile(s): 11 CTS-V
    Aug 2012
    34
    5
    In this picture the 285 Hankook looks like on a decent bump it would make contact with the quarter panel. That's why I'm skeptical running the 295. ImageUploadedByTapatalk1372383724.357683.jpg
  2. #47
    May 2012
    Orland Park, IL
    132
    Re: NEW Velgen VMB5 Wheels for CTS V Sedan!
    There is no rub and the 285 was chosen due to how low the vehicle was adjusted on the KW Coilovers. The is CTSV21's car and I would suggest contacting him directly to confirm. He even stated that he feels a 295 would have worked without issue, even with his current drop.
    I would personally recommend 285 if you are lowered that far. A 295 will be no problem if you have the standard Eibach drop.
    Edit: I attempted to reply to your PM but your inbox is full. Please let me know when space is cleared and I will resend. Thanks!
  3. #48
    Aug 2012
    34
    5
    Paul I sent you a PM.
  4. #49
    Aug 2012
    34
    5
    Quote Originally Posted by CTSV21 View Post
    Hey guys, thats my car on the velgens.
    The wheels fit and ride great on the car. I went with a 285 in the back because I wanted to be low and I didn't find many people on the forum that went with 295 on their 20's but im sure a 295 would've worked too. Overall i'm really happy with the wheels, I think they look great!
    Here are a couple more pics
    Attachment 108233
    PS: I'm on lowered KW V3
    I just purchased these, and I am wondering whether to go with the 285 or 295 rear. My sedan is lowered on Eibach Coupe springs (un-cut). Any suggestions? They look great!
  5. #50
    CTSV21 is offline Cadillac Owners Member
    Automobile(s): Black Diamond CTS-V Sedan
    Oct 2011
    33
    I am lowered on the V3 with a 285-30-20 V12 , When i first installed i couldnt drive because i was tucking tire , so after adjusting the height in the pictures above there is no rubbing.
    If your lowered on the Eibachs , you for sure can run the 295 / as eibach's sit higher than the D3 Suspension. I had the D3 spring and i wanted to go lower, so thats why i purchased the V3.[COLOR="Silver"]
    @ Deenasty , your mailbox is full..
  6. #51
    bolt007's Avatar
    bolt007 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS DI Super charged
    Aug 2011
    Conyers GA
    40
    110
    What kind ok hankook tires are you running?
    What kind ok hankook tires are you running series?
  7. #52
    May 2012
    Orland Park, IL
    132
    Quote Originally Posted by bolt007 View Post
    These are Hankook Ventus V12 Evo tires.
    255/30/20 and 285/30/20
  8. #53
    kcmoctsv is offline Cadillac Owners Member
    Automobile(s): 2009 CTSv Sedan
    Jan 2013
    4
    Quote Originally Posted by Deenasty83 View Post
    What tire did you end up going with on rear?? 285 or 295? Getting ready to pull the trigger on exact same setup (wheels, eibach uncut coupe springs on Sedan). Was curious with what you
    went with and if you had any issues.
    Thanks!
  9. #54
    bolt007's Avatar
    Aug 2011
    Conyers GA
    40
    110
    I have 285-35-20 I am selling the set
    Will take pics this weekend will put them online.
  10. #55
    silvergs is offline Cadillac Owners Member
    Automobile(s): 09 CTSVEEEE
    Feb 2013
    Socal
    34
    28
    How close are the spokes to the calipers? I'd like to run 305s but I know it will rub with these offsets. Is there room on the back spacing to machine Down thus increasing the offset? I'd like to be able to machine down to end with an offset of around 50-52 in the rear.
  11. #56
    May 2012
    Orland Park, IL
    132
    Quote Originally Posted by silvergs View Post
    If you machine down the offset to 50-52 there will be two issues:
    1) You center caps will not fit and the spindle/dust cap will protrude.
    2) Your lug studs will over extend and normal lug nuts will crack when you tighten them down. You will need open ended lug nuts.
    As far as caliper clearance, you should have not problem with the extra 5 to 7mm.
    Paul
  • You may not post replies
