Running wires through the firewall?
Results 1 to 5 of 5
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Running wires through the firewall? in Cadillac CTS-V Series Forum - 2009-2015; Does anyone have any tips on running a few wires from under the hood (fuse box) into the cabin? Where ...
    SSpray is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    14
    Does anyone have any tips on running a few wires from under the hood (fuse box) into the cabin? Where did you run them?
    (Installing ZR4 laser shifters, so if you have any specific installation tips, I would appreciate that)
    -thanks.
    Aug 2006
    14
    Re: Running wires through the firewall?
    bump
    matt116 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS V Blackdiamond coupe
    Mar 2012
    Baltimore Md.
    155
    I cut a small hole in the rubber boot at the firewall where the steering column goes through. I then use a metal coat hanger to push through. It may take you some time as it is thick. Make sure where you are pushing there is nothing on the other side.
    Hope this helps
    Matt
    jraVegas is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan
    Mar 2013
    Las Vegas
    10
    Quote Originally Posted by matt116
    Hope this helps
    Matt
    ^^^^this^^^. Probably your best bet is to fish a hook through the rubber boot. Make sure those wires in the engine bay are protected from the heat. Then it's just a matter of making sure the lasers are well mounted, 100% level and IMO as close to your headlights as possible.
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    692
    The leather punch on a pocket knife works well too.
  8. Remove Advertisements
