Driving school tire pressure recommendations
Results 1 to 8 of 8
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Driving school tire pressure recommendations in Cadillac CTS-V Series Forum - 2009-2015; ...
    Trionalaw is offline Cadillac Owners Fanatic
    Automobile(s): none
    Dec 2011
    64
    249
    I'm attending a high performance driving school at Putnam Park next weekend. I have brand-new Hankook Ventus V12's (275/35/19 and 305/30/19 with 10 mm spacers all the way around). My Michelin PS2's gave me 17,000 miles plus. However, the outside of each tire particularly in front were perfectly smooth.
    I know the idea is to keep the tire pressures high enough that you don't hand over onto the outside of the tire in turns. The tires' maximum tire pressure is 50 psi, which I understand is in fact the cold temperature rating.
    I think I should start out at about 37 psi and 35 psi – cold – and see what happens. However, I would appreciate advice from smarter people than me or maybe people with more experience so I don't hurt my own feelings.
    Thanks so much and happy Easter to everyone,
    Jim
    brent38's Avatar
    brent38 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Coupe
    Jun 2011
    Calgary Canada
    76
    You should be running at least 40lbs on street tires. Check on line with your tire manufacture as they should have warnings / cautions about hi speed driving.
    Have fun!
    Automobile(s): none
    Dec 2011
    64
    249
    Re: Driving school tire pressure recommendations
    Wiil do and thanks.
    jim
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Get a tread depth gauge and some tire marker. Start at about 35 cold and watch those outer front shoulders like a hawk.
    Bump up if needed...
    Automobile(s): none
    Dec 2011
    64
    249
    I ran 37 PSI cold in the front and 35 PSI cold in the rear. No wear at all on shoulders. I will write a quick review of the driving school and post it on a separate thread.
    Thanks for all the input,
    Jim
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Red/Blk 2016
    May 2010
    Racine, WI
    3,737
    I left them at 32 cold, and watched them go up during the driving to 35-ish. I like that better than starting higher. When I started higher, they shot way up, and I got the high-pressure warning. No rolling over either at the lower pressures.
    the blur's Avatar
    the blur is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac
    Oct 2008
    NY
    1,014
    I rant 40-38 cold, because I didn't want to destroy my tires. It worked out well.
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,737
    I should have added that I also have the 275/35x19 Michelin Pilot Super Sports up front, and stock size in the back.
  11. Remove Advertisements
