Little Help Here! Plasti Dip fog Light Housing and chrome Trim Ring?
Results 1 to 2 of 2
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Little Help Here! Plasti Dip fog Light Housing and chrome Trim Ring? in Cadillac CTS-V Series Forum - 2009-2015; Heading says it all. I want to blacken out the Fog Light housing and fog light trim ring but am ...
    45LongColt's Avatar
    45LongColt is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Sedan
    Aug 2012
    54
    Heading says it all. I want to blacken out the Fog Light housing and fog light trim ring but am not sure the best route to take. Does the Fog Light Chrome Trim Rings come off (unscrew or something), or do most folks just spray the entire housing, fog light and trim rings all together. If so, do you tape off areas, or spray the entire housing and peel off the fog light lamp area. Also, doesn't the Plasti Dip fill in the little pin hole air vents in the housing?
    Any suggestions would be greatly appreciated as I would like to do it correctly the first time. Thanks
    LongColt
    daowens is offline Cadillac Owners Fanatic
    Automobile(s): 2015i Escalade Premium, 2009 CTS-V
    Aug 2011
    Mt. Vernon, Missouri
    30
    134
    Re: Little Help Here! Plasti Dip fog Light Housing and chrome Trim Ring?
    I just taped mine off sprayed the entire housing. Just make sure to leave about 1/2" exposed around the housing so you can grab it and get a good split. Also, spray it on nice and thick. It makes it easier to take off if you decide to. Hope this helps!
