Sedan 285/35/19 on the front
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By needstires
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Sedan 285/35/19 on the front in Cadillac CTS-V Series Forum - 2009-2015; Has anyone tried to run this I mounted my rear sedan wheels on the front and put the rear coupe ...
    needstires is offline Cadillac Owners Member
    Dec 2012
    52
    Has anyone tried to run this I mounted my rear sedan wheels on the front and put the rear coupe wheels and tires on the rear as anyone tried this combo out I drove around with the rear coupe wheels in the rear of my sedan and it was ok no problem I don't know what would happen if you put 3 huge people in the back seat if the bulge old rub or not is really close . By the way it looks great with the extra 1/2 inch stance in the rear !
    Low_ET's Avatar
    Low_ET is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V, Thunder Gray, Auto
    Mar 2009
    East Central Florida
    221
    Re: Sedan 285/35/19 on the front
    I tried my factory sedan rear 19x9.5 wheels on the front. They hit the upper control arm. I needed a 8 mm spacer to make it work. Any spacer that thick or thicker needs to be hub-centric. The 285 mm width is no problem with the spacer.
    I have not tried the coupe wheels on the rear. The 19x10 coupe rears have a 40 mm offset. That would stick out 16 mm more than the factory set-up.
    Dec 2012
    52
    Quote Originally Posted by Low_ET
    If you would like I will send a pic it looks really good and the tire is still under the wheel lip it might rub on the bulge but you will need to put a lot of weight in the rear and hit some hard bumps but these IRS set ups the top of the wheel tip inward on the way up so I'm confident it won't be a problem . It looks really good with the wider stance its 1/2 inch out further than stock on both sides it's going to help on the road course keep it planted .
  5. #4
    cotty is offline Cadillac Owners Member
    Automobile(s): ctsv 2009
    May 2011
    62
    36
    i put my rear rims up front with 17 mm hub centric and hardend studs
    and i had the front rims widened to 11 in with 305 24mm hub centric and hardend studs.i had to roll the rear fender
    very little and had no problem. Running springs and sway bars from d3.Have run several track days d3 over nighted me spacers and were real good at working with me so i could make it to the cadillac challenge
  6. #5
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    You can run the rear sedan wheels on the front with our spacer kit. However the rear of the sedan might have some rubbing issues when you use the Coupe rear wheels, unless you spend some time working on the fenders. The offset is more aggressive. Looks great, but it will contact the tire unless you are running a stretch setup. Even that is no guarantee... I would be concerned about bumps in the road, or too much weight in the rear.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by needstires View Post
  7. #6
    Dec 2012
    52
    Quote Originally Posted by Dr. Design
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
    I'm on the waiting list for the 11 mm and stud kit for the front . I appreciate the input thanks. I'm not going to load up the back seat if possible with the coupe wheels . I'm going to run it both ways come April stock and with the coupe wheels in the back and the 285s up front with the spacer kit . And see if it make it better or not I will use the transponder so there is no cheating . I will post the time difference if any . Also the same tires .
    Dr. Design and Dr. Design like this.
  8. Remove Advertisements
