fog light replacement
Results 1 to 15 of 15
2009-2015 Cadillac CTS-V Appearance Mods Discussion, fog light replacement in Cadillac CTS-V Series Forum - 2009-2015; Can someone point me to links or advice on how to replace the stock foglights? I would like to convert ...
    simgolfer's Avatar
    simgolfer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V sedan, manual, silver/ebony, airaid, SW catback
    Jul 2011
    Elk Grove, CA
    228
    Can someone point me to links or advice on how to replace the stock foglights? I would like to convert to HID bulbs that match the color of the HID headlamps. Thanks.
    Purple87SS is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Black Raven CTS-V, 1987 Turbo Buick WE4
    Dec 2011
    244
    Re: fog light replacement
    Turn away the wheel from the side you are working on (or just remove it ) and remove the 2-3 plastic push pins holding in the wheel wells. This should give you enough room to R&R the bulbs for HIDS. Someone else can prob chime in as to where to mount the ballast.
    Bigron is offline Cadillac Owners Enthusiast
    Sep 2007
    Southfield, MI
    934
    I removed way more than 3 push pins when I did mine.
    There is a nice "shelf" right above the fog light where I 3M taped the ballast.
    Smokin80 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black Raven CTS V/Manual
    Jan 2011
    Alberta, Canada
    32
    201
    What brand/site are you guys getting these from.
    I assume closest to factory color would be a 35w 5000k? Or maybe 4300k?
    Thanks!
    ClarkkentCTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Thunder gray CTS V
    Jun 2012
    South Florida
    34
    215
    4300k is the closest to the headlight color. Unfortunately the only way to truly match the headlights is to go with a 55w ballast, but with the fog light housing being so small you run the risk of melting it from the heat of the more powerful ballast. That's why everyone goes with the 35w, but there is still a hint of blue. You would have to be very critical to notice the difference. My HID fogs match my light bars perfectly. Looks killer with just the fogs and parking lights on. I went with the DDM tuning setup. Cost $35 and has been great for the last 6 month. Don't buy into the $100 kits, they are all the same.
    Jan 2011
    Alberta, Canada
    32
    201
    Right on. What bulb is in the fogs?
    simgolfer's Avatar
    Jul 2011
    Elk Grove, CA
    228
    I think the bulbs are H11. Please someone correct me if I am wrong. Anyone with experience putting in LED bulbs?
    _GVG_ is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Sedan
    Feb 2013
    Quote Originally Posted by ClarkkentCTSV View Post
    ClarkkentCTSV, what bulbs did you use? Is it the H11? Thanks in advance!
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,884
    Are you really set on HID fogs? Many of us used the non-HID Hoen H11 bulbs. Been on my '09 for 3+ years and no issues. And they match up perfectly with the headlamps...
    Sep 2007
    Southfield, MI
    934
    Quote Originally Posted by thebigjimsho View Post
    They match perfectly but do they add any additional light or visabilty? With my OEM bulbs you couldn't tell the difference between on/off.
    My 55w bulbs add plently of light. I have considered switching to yellow HIDs for a different look.
    Automobile(s): ZIP
    51,884
    How about switching to yellow for actual functionality?
    Fog lights are yellow. Driving lights are white.
    You choose.
    LSUFoolsball is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V Sedan All options
    Feb 2013
    34
    40
    So H11 for V2 CTS-V fogs?
    Automobile(s): ZIP
    51,884
    Quote Originally Posted by LSUFoolsball View Post
    Yes.
  16. #14
    genna is offline Cadillac Owners Member
    Automobile(s): '11 CTS-V Sedan BDE, Manual
    Mar 2007
    10
    thebigjimsho:
    Eh.. not really.. Fog lamps can be white or selective yellow... and most newer cars have white. It's about the characteristics of the beam. low and wide with sharp cut-off on top(prevent glare back). There are no factory "driving lights" installed on "on road" passenger vehicles. Those big lights you see on grill of rally cars or lightbars on Jeeps and such, those are driving lights
  17. #15
    Automobile(s): ZIP
    51,884
    Quote Originally Posted by genna View Post
    thebigjimsho:
    Let's put it this way. There are no driving lights on any passenger cars made today. And there are no fog lights on any passenger cars made today.
    They are all for decoration...
  18. Remove Advertisements
