Rear Chrome Molding Replacement - Question
Results 1 to 12 of 12
2009-2015 Cadillac CTS-V Appearance Mods Discussion, Rear Chrome Molding Replacement - Question in Cadillac CTS-V Series Forum - 2009-2015; How hard is it to remove? I want to paint it, but on the underside of the trunk lid there ...
    qictrk's Avatar
    qictrk is offline Cadillac Owners Enthusiast
    Automobile(s): 1958 Coupe DeVille
    Nov 2008
    The coast, Ca.
    591
    How hard is it to remove? I want to paint it, but on the underside of the trunk lid there are about 7 plastic buttons to remove. Do I just break them off and replace them or do they pop off and on?
    Those of you that have done this, I would appreciate giveing me a plan before I go and break something that didn't need to be broken. Cecil..........
    Domsz06 is offline Cadillac Owner
    Automobile(s): 2009 CTS-V, 2007 Z06
    Jul 2010
    Houston Area
    38
    2,843
    Re: Rear Chrome Molding Replacement - Question
    On my sedan cecil you pull the black pins out, pull the two screws out of the handle, and remove the rubber stop pieces. This allows the carpet to come out and then you can see the screws that hold it together.
    Then you remove the tag lights and should see a screw or two. I think there was 2 here.
    It's not hard at all, just takes a few minutes. As far as the plastic ties I always order mine from autofastner.com, they end up being about 30 cents each instead of 12 dollars like the caddy dealer. I try and replace all the "christmas tree" style since they never work as good when you pull em out. I'll try and see if I have any pics from when I did mine.
    Karch's Avatar
    Karch is offline Cadillac Owners Fanatic
    Automobile(s): 2010 TG sedan, 6A,LPE 650, and a few more mods.
    Dec 2009
    Los Angeles
    498
    Were you able to remove the chrome piece?
  5. #4
    tkracing is offline Cadillac Owners Fanatic
    Automobile(s): 2012 cts-v coupe
    Feb 2012
    46
    194
    I just did it today on a coupe. Wasn't hard just follow what was said in the earlier post. If your careful with the push pins when removing you can reuse them. I did.
  6. #5
    Karch's Avatar
    Dec 2009
    Los Angeles
    498
    I had trouble getting the chrome piece out. I removed two nuts, but couldn't get the piece out.
  7. #6
    Feb 2012
    46
    194
    There is the 2 inside the tag lights. You have to pop them out to see them. There are 4 inside the trunk which you can see once you have removed the trunk carpet.
  8. #7
    Karch's Avatar
    Dec 2009
    Los Angeles
    498
    Thank you, I'll give it another go.
    Seeing how you have a coupe, it may be different.
  9. #8
    Feb 2012
    46
    194
    Let me know if you were successful.
  10. #9
    Karch's Avatar
    Dec 2009
    Los Angeles
    498
    Will do. I am trying to replace mine with one with a camera, but it appears the 2011+ years are wider, or, rather, taller, by about 1/2".
  11. #10
    qictrk's Avatar
    Nov 2008
    The coast, Ca.
    591
    Sorrry, I wasn't paying attention to my own thread. Yes, it wasn't that bad. I'm not sure what your stuck on, but there are 4 screws on the back side of the plate. Two of those are hard
    to see unless you almost crawl into the trunk. There are also two from the outside that you will see when you get the light lens off. If you really can't get it done, I think you can paint it without
    taking it off. Just do a real good tape job and mask on the outside and it can be done. No one will know but you. Cecil................[COLOR="Silver"]
  12. #11
    Mike02z's Avatar
    Mike02z is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Sedan Black Raven 6 speed manual
    Apr 2011
    49
    404
    I did mine with Plastidip and never removed it. It came out looking great.
  13. #12
    Karch's Avatar
    Dec 2009
    Los Angeles
    498
    Thanks guys. Not interested in painting anything, I want to add a factory rearview camera. The 2011+ models have a camera, but they are about a 1/2" taller, about 1-3/4" compared to about 2-1/4".
  14. Remove Advertisements
