Stock vs. Airaid intake results at drag track - Page 2
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 16 to 30 of 36
Like Tree3Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, Stock vs. Airaid intake results at drag track in Cadillac CTS-V Series Forum - 2009-2014; Just picked up, and am in the process of putting it together. I can't wait to drive with it installed. ...
  1. #16
    GoHawks24 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS V
    Dec 2013
    43
    Just picked up, and am in the process of putting it together. I can't wait to drive with it installed. $276.00 on Amazon right now. Best deal I've found on this item and, free two day shipping. Thanks for your informative post.
  2. #17
    CavemanB52's Avatar
    CavemanB52 is online now Cadillac Owners Enthusiast
    Automobile(s): 2012 CTSV coupe
    Aug 2012
    774
    Yes. A live rear axle will get better 60 foot times. IRS is not made for launching... its for turning. Its trade off that some find more valuable than just going fast straight. But launch aside... once moving it will function munch better than the old style muscle cars.
  3. #18
    BADASSV is offline Cadillac Owners Member
    Dec 2013
    26
    Quote Originally Posted by CVP33 View Post
    Strong 1/4 mile for that pulley, but I believe you right at 2.55 = 12-ish pounds. I'm going 2.4 and shooting for 15-ish, but may be lower with other supporting mods.
    I have the 2.4 upper with 100mm idler pulley and solid isolator. Would this be a good combo? Only mods are k&n intake and corsa cat back exhaust. Thanks for any help
  4. #19
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V sedan, '13ZL1 vert, '12 V coupe
    Feb 2004
    mockingbigjimsville, NC
    47
    5,730
    Re: Stock vs. Airaid intake results at drag track
    Quote Originally Posted by BADASSV View Post
    Interesting first post.....I'll bite. 2.4" upper puts you at 15psi. You really need injectors at that point, ID850's or 1,000's. Also recommend getting an upgraded HX and pump. Obviously a custom tune as well. BTW, K&N doesn't make an intake for the V. You sure you have a CTS-V?
    ID850's - $800
    HX - $500
    Pump - $275
    Tune - $500
    Total $2,075
  5. #20
    Dec 2013
    26
    Yeah, meant k&n filter. Thanks for the reply. Just got the car and the owner let pulleys go with it. It's all metco motorsports. Was debating on goin with it or just buying a 2.55
  6. #21
    Dec 2013
    26
  7. #22
    CavemanB52's Avatar
    Aug 2012
    774
    <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=172642"/>
    +1. You need injectors with all that. Or you will see plenty of detonation.
  8. #23
    Dec 2013
    26
    Ok, I knew it would be borderline but wasn't sure. Thinking about going with the E85 tune so I'd have to get injectors anyway.
  9. #24
    CVP33's Avatar
    Feb 2004
    47
    5,730
    Sorry I doubted you. You've got some of the parts you need. Definitely will need injectors with pulley swap and E85 only makes you need them more. Still think you'll be battling some heat with 15psi so not an immediate need, but an upgraded HX and pump should be in your future plans.
    You should look at a CAI as well. You can get the Airaid from AutoZone for $250 when they're running their sales.
  10. #25
    Dec 2013
    26
    I understand. I never do forums but I've found a lot of useful info on this one. My goals for now are around 600whp.
  11. #26
    CVP33's Avatar
    Feb 2004
    47
    5,730
    Quote Originally Posted by GoHawks24 View Post
    $275. A little involved but not too bad:
    Part no. 251-253
    1) Go to ebates.com and create an account if you don't already have one. Link to Auto Zone for a 4% rebate
    2) Load part number 251-253 into your cart.
    3) $334.99 + $18.09 Taxes
    4) Use code PAYPAL20 to receive 20%OFF
    5) $286.08 is what you'll pay with free shipping
    6) 4% rebate nets you down to $274.64.
    The better deal was when the had the $25 gift card for every $100 spent. That, with rebate and using your Discover Card netted the CAI down to $246-ish.
  12. #27
    Dec 2013
    26
    Yea, ordering a cai this week. Even tho I'll only hit the dragstrip here and there and occasional weekend cruising, would 15lbs be torturing the motor?
  13. #28
    CVP33's Avatar
    Feb 2004
    47
    5,730
    I have the same goals. Did it once with my first sedan, but the tuner had a lean tune in the car and burned up #7 piston. Also cracked a cylinder. Good fun. Tuner blamed bad gas. I got to drive it all of 500 miles before it blew up. I miss that car, 2010 W/D, every option.....only had 14,000 miles when I picked it up.
    http://www.youtube.com/watch?v=9QVbsVDCREI
    Without supporting mods (injectors, tune, HX, pump) you're risking hurting the motor. I also believe that headers help relieve heat and a good cam can do the same reducing dynamic compression.
  14. #29
    Dec 2013
    26
    That's the setup I'm going for. Later on add headers then cam. looks like I'll be adding hx and pump before anything tho
  15. #30
    CavemanB52's Avatar
    Aug 2012
    774
    Hx will help from getting heat soaked and pulling timing. Headers help but more importantly if you don't do something like high flow cats or cat deletion down range you will melt the front cats at 15 psi. I did and... and I only had a 1.5 Metco at the time with 12-13psi.
    CVP33 likes this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
