5k to spend on the V, opinions on mod path are appreciated.
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree3Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, 5k to spend on the V, opinions on mod path are appreciated. in Cadillac CTS-V Series Forum - 2009-2014; So I'm going to have 5k or so to play with for my V in a month and I wanted ...
    2013CTSV is offline Cadillac Owners Member
    Automobile(s): 2013CTSV
    May 2013
    60
    So I'm going to have 5k or so to play with for my V in a month and I wanted some peoples opinions on my mod path choice.
    I have airraid intake already,160* thermostat, D3 Comps going on in spring.
    I'm thinking cams, upper & lower pulley, port and polish everything, possibly tune it on E-85(it's readily available) & some fat stick tires. I've heard the exhaust isn't that much of a restriction, with this much increased flow though I'm thinking it may become a bottle neck....thoughts?
    I have no specific brands selected yet as I am still doing research on the various companies. Looking to achieve around 650-700whp. Previously dynoed at 524 with just the airraid intake in May. Stock V makes about 475 on this places dyno. I will go back to the same dyno in May with similar conditions to get as accurate of a comparison as possible. I will of course get her dynoed in the dead of winter for some feel good runs haha
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V sedan, '13ZL1 vert, '12 V coupe
    Feb 2004
    mockingbigjimsville, NC
    48
    6,043
    Re: 5k to spend on the V, opinions on mod path are appreciated.
    Don't see upgraded injectors and Heat exchanger.
    May 2013
    60
    I wasn't sure if injectors were needed, I assumed they were but only if I run E-85 if I'm not mistaken? Is the heat exchanger a must?
  5. #4
    CVP33's Avatar
    Feb 2004
    48
    6,043
    If you're doing upper and lower pulleys AND a cam......man you're going to need injectors. If you're doing all that it will be a waste without a larger HX. Without it the car will run hot, you'll pull timing and almost never be a full power.
  6. #5
    matt116 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS V Blackdiamond coupe
    Mar 2012
    Baltimore Md.
    150
    For 650 to 700 whp? You may get all the parts you need for $5,000. If it's bhp your looking for your good to go. For the money injectors are good piece of mine in any build IMHO.
  7. #6
    Moparman4444 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2010
    535
    650 whp is do-able but 700 at the wheels is strong.
    I got 640 at the wheels on regular gas for under $5000.
    If you want to climb into the 700 whp you are looking at some internal upgrades if you want the car to last. imho.
    I think you will be happy with a cam, upper and lower pulley, injectors, cam sprocket, CAI, Ported Snout, HX, heads with springs and push rods, and free flowing exhaust. The stock is a restriction. Now you are close to $6000.
  8. #7
    TKDalumni's Avatar
    TKDalumni is offline Cadillac Owners Member
    Automobile(s): Silver Frost CTS-V
    Jun 2013
    57
    You got 50hp from just the air raid?!
  9. #8
    May 2013
    60
    Quote Originally Posted by TKDalumni
    The dyno operator was amazed at the gain from the airraid, I did not dyno it stock for all I know I got a factory freak. A V dynoed at 475 no more then a month earlier with colder weather. Is the stock intake that restrictive?
  10. #9
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,421
    You can't do that. The car needs a baseline and then after. Otherwise, its all guessing and conjecture...
  11. #10
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    691
    Quote Originally Posted by thebigjimsho View Post
    Yeah, could have gained you 50 or could have gained you 1. Without a baseline there is nothing to compare it to so just guessing.
    On the mods, pulleys, cam, intake, headers, heat exchanger should net you over 600hp at the wheels. If you are willing to do any of the work, you can do it pretty cheap.
  12. #11
    stl_ls1gto is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS-V wagon M6, 2011 GMC Sierra CCSB 6.2L, 2004 GTO
    Nov 2005
    St. Charles, MO
    339
    injectors, upper and lower pulleys, nitrous system, tires, install....rest is gas money
    CVP33 likes this.
  13. #12
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V A6, 752 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,108
    2.4 upper, HX, 1000cc+ injectors, ported snout, flex fuel conversion. You'll be 650ish rwhp on e-85
  14. #13
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    253
    IMO how to spend depends on how you plan to use the car. If it's street/strip/bragging rights, HP/torque and cooling. Street and road course/track use, HP/torque isn't the issue. CAI, ZL1 lid, HX/pump/reservoir, a rear diff cooler that works, brake upgrades, a safe tune not on the edge, and take the rest of the $$$ and put it in the suspension.
  15. #14
    bnagel is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Sedan
    Jul 2010
    128
    All good info from local peeps.
  16. #15
    CVP33's Avatar
    Feb 2004
    48
    6,043
    I'm working through my shopping list using black Friday and Cyber Monday deals. So far:
    1) ID850's - $762
    2) Airaid CAI - $252
    3) Track attack HX - $508
    4) 29gpm HX pump - $260
    5) Dual catch cans - $130
    6) NorCal tank - $365
    7) ZL1 Lid - $250
    8) Kooks headers, coated, catted Xpipe - $1,750 (we have emissions so I needed cats, may gut them later.)
    Total $4,277 so far.
    Below is what I still need and simply guessing at the costs:
    1) $250 - 2.4 upper pulley only. Changed my mind on going with the lower.
    2) $850 - Cam kit (springs, pushrods)
    3) $65 - Plugs
    4) $100 - Ported TB (labor only)
    5) $2,000 - Tune & install
    Grand Total - $7,292
    Shooting for around 625rwfrwhp (reliable, worry-free, rear wheel horsepower)
    Still need my drag rims and tires. Looking for used deals on those.
    thebigjimsho likes this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
