Injector advice - brand, quality?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By cruiser68
  • 1 Post By SC2150
2009-2014 Cadillac CTS-V Performance Mods Discussion, Injector advice - brand, quality? in Cadillac CTS-V Series Forum - 2009-2014; I need bigger injectors, most likely 80lb/850cc, in that range. Everybody's go-to injectors are the ID850s, my tuner is recommending ...
    Xaqtly's Avatar
    Xaqtly is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    951
    I need bigger injectors, most likely 80lb/850cc, in that range. Everybody's go-to injectors are the ID850s, my tuner is recommending FIC 80lb injectors instead. In doing my standard research I found that there are two companies both called FIC that both make injectors for the V. One is Fuel Injector CONNECTION and the other is Fuel Injector CLINIC. They don't appear to be related to each other, but it was real hard to separate reviews because I never knew which FIC they were talking about. So my questions are:
    1. Does anybody have any experience with FIC injectors?
    2. Which FIC was it, Clinic or Connection?
    3. Are FIC injectors any good? I saw a number of comments referring to the FICs as not being as good as the IDs.
    4. Given that the difference for 80lb injectors is about $400 per set between the IDs and the FICs, would you put FICs in your own car?
    Thanks for any info on this, doing the research on it hasn't been as helpful as I had hoped and I was hoping somebody here had direct experience with them.
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    573
    Re: Injector advice - brand, quality?
    I would use whatever your tuner is suggesting. My tuner loves ID850's and that is what I went with. He claimed the ID's were easier to tune since they give you detailed flow characteristics.
    Luna. and SerbsCTSV like this.
    Esq. is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan
    Aug 2013
    4
    I agree that you should go with what your tuner recommends. He obviously is more comfortable tuning with the FICs, and at the end of the day, he cannot blame any issues you might have on your not using the recommended injectors. My tuner liked FICs (fuel injector connection) also, so that's what I went with.
    Also, I think you'll generally find that people are referring to Fuel Injector Connection, not Clinic.
  5. #4
    Xaqtly's Avatar
    Jan 2012
    Las Vegas, NV
    951
    I probably will go with what my tuner recommends but I never do anything to my car without doing independent research first. I just wanted to see if anybody here had direct experience. I talked to my tuner again, and he said they actually work with Fuel Injector Clinic, and that their equipment was all upgraded a year or two ago, and they provide flow charts with all their injectors, and they're based on the same Bosch units that ID uses. They're just $400 cheaper, lol. Anyway he's been doing this a long time and their shop has a good reputation, so I'm just going to go with the FICs and trust that they know how to tune to them.
  6. #5
    jb_bgg is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Black/Black V, Manual, Recaros, loaded
    Feb 2011
    Orange County, CA
    246
    FIC's 80lb in mine, work fine.
  7. #6
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    58
    1,596
    We have an ASNU injector cleaning and flow matching machine, world of difference between the spray pattern and consistency of the ID's built new to spec and the FIC re-drilled. If you saw the spray pattern there would be no question, go with the ID's...nothing better.
    CVP33 likes this.
    RX Performance Products/RevXtreme.com 941-721-1826
  8. #7
    stl_ls1gto is offline Cadillac Owners Fanatic
    Automobile(s): 2013 CTS-V wagon M6, 2011 GMC Sierra CCSB 6.2L, 2004 GTO
    Nov 2005
    St. Charles, MO
    254
    id injectors are by far the best, not an area to cheap out on. sure the others can be made to run ok, but they are not as consistent.
  9. #8
    SerbsCTSV is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Black Diamond Edition Sedan
    Oct 2013
    Oak Creek, WI
    40
    Tony at the shop told me the same thing this past Friday when I was there getting tuned. Definitely doing them within the next few weeks.
    Serbs...
    Quote Originally Posted by cruiser68 View Post
    Tony at the shop told me the same thing when i was there this past Friday getting tuned. definitely getting them within the next few weeks.
  10. #9
    lsxtuner is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Sep 2013
    41
    17
    Quote Originally Posted by stl_ls1gto View Post
    How are they "by far the best"?
    Do you mean they make way more power?
    Do you mean they will get noticeably better mileage in the car?
    Do you mean the car will be more responsive once properly tuned with the correct injector data?
    I have seen no discernible differences in these areas amongst a significant sample size of boosted LSx cars.
    There are thousands of people who have used FIC, Siemens, and FAST injectors at half the price of ID's that produced the same hp, drivability, and overall results in the end. I just put a flow matched set (within 1%) of Siemens 60's in my personal 14' A6 V and they still have plenty of duty cycle left at 570rwhp. I plan on installing an LS9 cam and 9.1" lower pulley to get me to 640rwhp and they should still be able to fuel the car since they flow at 74# in the V. Would I use a non-matched set of these in a car? Nope, but proper flow matching gives you a great set of injectors with essentially identical dynamic flow characteristics and spray pattern.
  11. #10
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V sedan, '13ZL1 vert, '12 V coupe
    Feb 2004
    mockingbigjimsville, NC
    48
    5,795
    Quote Originally Posted by SC2150 View Post
    I thought this pretty well covered it. No conspiracy theories needed. Sometimes better is just better.
  12. #11
    Nov 2005
    St. Charles, MO
    254
    there are so many posts about this topic on different ls forums.....no question that the Injector dynamics are the best.
  13. #12
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan A6, 730 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,054
    I have a set of ID 850s for $700 to the first taker...
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
