Stock dyno 425 Stock including a CAI, modified now 608whp.
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 12 of 12
2009-2014 Cadillac CTS-V Performance Mods Discussion, Stock dyno 425 Stock including a CAI, modified now 608whp. in Cadillac CTS-V Series Forum - 2009-2014; I had my cay dynoed and ended up with a limp 426hp at the wheels including a CAI. I then ...
    Moparman4444 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2010
    513
    I then modded the car with a mild G9 cam, pulleys, upgraded springs, reflowed the injectors to 72lbs, ported snout and blower and a tune. Stock exhaust and power jumped to 608 at the wheels. That's a 172hp increase on a VERY conservative tune.
    My tuner didn't want to go further w/o eliminating the stock CATS. He thinks he may have melted them tuning the car.
    I must say that I am very surprised at the cars drivability. At light throttle and general cruising there is absolutely no difference from stock other than a slight 180 rpm increase in the idle and a slightly more detectable lump from the cam. If I wasn't looking for an increased cam lump I wouldn't even notice it. My wife didn't.
    It's time to eliminate the CATS, replace the crimped exhaust pipes, add a resonator and pick up another 40hp with a more aggressive tune.
    gOt BoOsT's Avatar
    gOt BoOsT is offline Cadillac Owners Member
    Automobile(s): '11 CtsV '10 c300 '08 k1500 4x4 '11 RxpX Turbo E85 Powered
    Oct 2010
    Cali
    83
    Re: Stock dyno 425 Stock including a CAI, modified now 608whp.
    nice jump in power! there's some left on the table having cats and stock exhaust manifolds...
    Jun 2010
    513
    My tuner expects another 30-40 just by eliminating the CATS and replacing the mid pipes. I must say I was real disappointed in the stock numbers and the final number but I know there is more to come.
    Attached is the dyno sheet
  5. #4
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,985
    Your low power on stock was from your air filter assembly not being tuned. If you look in that dyno, It shows you where 9s air fuel ratio. Which is why you are 30 hp lower than normal values for a stock car.
    The cold air kit just wasn't tuned to fix air fuel ratios.
    In your stock run, you made 444 hp according to the dyno log you uploaded. Which would have been about 488-490 if the fuel ratio would have been in the higher 11.s/ You can see how the engine was breaking up from the to rich of a mixture.
    As for hp setup vs your final hp, It sounds about right on. Usually that exact setup we are at 620hp. So not to far off.
    With headers or cat delete pipes you will gain 8 more hp.
    Edit: ported snout/blower when we do that with your combo we are at 650.
  6. #5
    Jun 2010
    513
    Thanks for the comments Jesse. I wish you were located closer to me.
    I would still expect more with CAT delete and a leaner mix.
  7. #6
    wait4me's Avatar
    Jan 2009
    warsaw indiana
    2,985
    In your final pull as per that dyno you where running 13.0 which is WAY to lean near peak torque. I would get it re dyno tuned. Target for your car is 11.4 At no point in wot should you be in the 13s.
    If the tuner wants to know why it is doing that, have him give me a call and I will tell him the fix. It also looks like it is getting a lot of KR during that entire run, past 2500 rpms. As you can see the computer trying to add it back in and pulling it back out. "wavy"
    So to answer your last message, on leaner mix. You are already VERY dangerously lean.
  8. #7
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan A6, 730 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,054
    Nice #s moparman! What pulley combo did you end up with?
  9. #8
    Jun 2010
    513
    Im using a 2.55 upper and 9.1 lower pulley.
    I must say that it was V Locity's sound bite that put me over the top on getting the cam.
  10. #9
    V locity's Avatar
    Jan 2012
    Katy, TX
    1,054
    Yea... The GT9 is very close to the stock cam in sound & streetability. Oh, btw, you may want to monitor your IDC in the cold months with the 72lb injectors...
    Many smiles ahead!
  11. #10
    Jun 2010
    513
    What is IDC? do you mean IAC ? Idle air control?
  12. #11
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    May 2011
    Central Florida
    2,382
    Quote Originally Posted by Moparman4444
    Injector Duty Cycle is where I think he's headed.
  13. #12
    V locity's Avatar
    Jan 2012
    Katy, TX
    1,054
    Yes, Injector Duty Cycle. Sorry
    Your build is similar to mine & I'm at 80% duty cycle, in cold weather, with the stock pump & 85lb injectors...
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
