Why the hell did the factory squish the exhaust pipes in the center?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2009-2014 Cadillac CTS-V Performance Mods Discussion, Why the hell did the factory squish the exhaust pipes in the center? in Cadillac CTS-V Series Forum - 2009-2014; I looked under my coupe and saw that the factory crushed the 2 1/2" exhaust tubes down to 1"x3 1/2" ...
    Moparman4444 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    Jun 2010
    532
    I looked under my coupe and saw that the factory crushed the 2 1/2" exhaust tubes down to 1"x3 1/2" in the center of the car. Seriously?? Why the hell would anyone do that? Does it reduce noise, air flow, limit power? What?
    There is plenty of ground clearance and smashed tubes make no sense to me.
    Can anybody explain??
    cruiser68 is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 CTS-V A6 Sedan Modded :)
    May 2011
    Chicagoland
    659
    Re: Why the hell did the factory squish the exhaust pipes in the center?
    They pretty much all have it. One of the many reasons I went headers. I know some have fixed it. I also know of 700+HP on stock exhaust so it flows decent if you fix the kink....and remove or replace the cats.
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    May 2011
    Central Florida
    2,654
    For all we know they're using the same Y-pipe that was used on the old Camaros. The one on my '99 SS had the same crimp....until the headers went on!
  5. #4
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,998
    It allowed for machine robot easy installation onto the vehicle.
  6. #5
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    689
    The area through the squished portion may still be the same as the unsquished part. Just a different shape.
  7. #6
    May 2011
    Chicagoland
    659
    Having looked at it up close I would guess there is 50% of the original cross section left through the crimp.
  8. #7
    Da V-Man is offline Cadillac Owners Fanatic
    May 2012
    236
    If the crimped pipe measures 1x3.5", like the OP's pipe, then the cross-sectional area is about 35% smaller than the round pipe. If the crimped pipe measures 1.5x3", like my pipe, then the cross-sectional area is about 20% smaller than the round pipe.
  9. #8
    DiamondWhtV is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V
    Feb 2010
    64
    364
    Doubt you will ever get a true answer and just a bunch of guesses. My guess that it had to do with either manufacturering or assembly requirements. Regardless it probably has no effect on a stock engine. If you are going to add a bunch of horsepower, you would go the route of headers and eliminate any flow restrictions. I can think of a few silly things they did to the V- like no spare tire, that are more important.
  10. #9
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,654
    On the Camaro, I can almost cite a ground clearance issue. With the off road pipe it would grind a speed bump if I wasn't careful.
  11. #10
    gaduser is offline Cadillac Owners Member
    Automobile(s): 2011 Black Diamond Edition CTS-V Coupe, 2012 SRX Luxury
    Apr 2013
    Novelty, OH
    73
    24
    My 2011 Coupe has a similar "smashed pipe". It is hard to believe that GM would accept what appears to be shoddy workmanship and/or damage prior to delivery.
    Might the "smash" be a factory adjustment, albeit crude. It may be that the power system is unbalanced, left to right, either forward and/or aft of the "smash". I believe it possible that a crimp might provide some flow and/or pressure balance. Further, it may have to do with the acoustics of scavenging. One might generously call it a crimp in one of those or similar cases. Note that the air intake is not centered which may contribute to some form of asymmetry in function of the system. The blower certainly can favor one bank and/or some cylinders.
    I began to wonder after seeing several pipes. They were not all the same. One should expect that if the right side can be bent smoothly, so can the left. It does not look like a virgin manufactured component.
    If my postulate is correct, good for GM for making the adjustment even though is seems a little crude. If not, ...............
  12. #11
    Arca500 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    37
    Wait4me hit the nail on the head. I've seen this in many different GM vehicles over the years. Even on a 94 GMC turbo diesel dually. It's just for easy manufacturing. That's all.
  13. #12
    dennych is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Sep 2012
    718
    Mechanic claimed it is better for torque #'s at the cost of a few HP.
  14. #13
    Jun 2010
    532
    I would guess its to limit performance upgrades by restricting flow.
  15. #14
    May 2012
    236
    you guys are overthinking this. Look at the pipe locations under the car. On the passenger side there is more overhead clearance, and the pipe is installed a little higher. On the driver side there is less overhead clearance, and the pipe is installed a little lower. The pipe had to be squished to meet minimun ground clearance requirements.
  16. #15
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,654
    Quote Originally Posted by Da V-Man
    Exactly.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
