Boost not building sometimes
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 6 of 6
2009-2014 Cadillac CTS-V Performance Mods Discussion, Boost not building sometimes in Cadillac CTS-V Series Forum - 2009-2014; Hey guys so sometimes my boost is not building. If my car is running well the boost gauge will read ...
    2012 CTS-V is offline Cadillac Owners Fanatic
    Automobile(s): 2012 Cadillac CTS-V
    Mar 2012
    105
    Hey guys so sometimes my boost is not building. If my car is running well the boost gauge will read 12 psi. I went out for a ride before and it wouldn't go above 5 psi. Any ideas? I have an automatic 2012 sedan with upper pulley tune thermostat and intake.
    Mikes2009V's Avatar
    Mikes2009V is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTSV
    Feb 2012
    Cinnaminson, NJ
    37
    122
    I just had the same issue with my 2009 MT with similar mods. Two possibilities I was told to look for were belt slip and also the boost bypass valve. Turns out it was a combination of both. To the left of the actuator on the bypass valve there is stop bracket with a set screw. If the bracket is not adjusted right or the set screw is in to far, the butterfly valve isn't completely closed and you are bleeding off boost. In my case the bracket was misaligned (should be straight up and down) and the butterfly was staying open. Also belt slip becomes an issue if you do not have an idler pulley which I will soon be adding. Hope that helps.
    Mar 2012
    105
    Re: Boost not building sometimes
    Thanks I'm bringing my car to my tuner this week. He mentioned it might be belt slip but has to take a look at the car. I will mention to him the issue you had with the boost bypass valve.
  5. #4
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    It is going to be the bypass valve, just look and do the pvalve mod, it is the easiest.. It will still shut off boost while non full throttle, so you don't have to worry about anything. It will just not be able to pull boost anymore.
  6. #5
    the blur's Avatar
    the blur is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Oct 2008
    NY
    894
    My 2009 is all stock , and the boost gauge only goes about 1/2 way. Is that normal?
  7. #6
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,706
    Quote Originally Posted by the blur
    Stock boost is give or take 9 pounds on the unreliable stock gauge.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
