Any 355mm rotors weights 2.5kg(5.3lbs)?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 2 of 2
2009-2014 Cadillac CTS-V Performance Mods Discussion, Any 355mm rotors weights 2.5kg(5.3lbs)? in Cadillac CTS-V Series Forum - 2009-2014; I've heard about that yesterday, but now still under testing. It seems like powder-metallurgy mixed with ceramic and metal. 355mm ...
    Eswat is offline Cadillac Owners Member
    Nov 2010
    Taipei, T'ai-pei, Taiwan, 1107
    37
    25
    355mm rotor with bracket weight 5.34lb/2.425kg, could be lighter.
    Designer told me the price by this dimension would be around 500-600USD, estimated.
    How much weight about a CCB rotor at similar dimension?
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Re: Any 355mm rotors weights 2.5kg(5.3lbs)?
    Ah, you have a 370mm rotor, the V1s have the 355mm rotors.
    You do shave weight going to a two piece design, as well as the added bonus of saving your hub bearings...
    Brembo, Racing Brakes, and a couple other companies make rotors for your car already...
    Research is your friend
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
