Anyone running 19" TSW Nurburgring wheels? - Page 2
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Like Tree1Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, Anyone running 19" TSW Nurburgring wheels? in Cadillac CTS-V Series Forum - 2009-2014; Originally Posted by Low_ET I am about to buy a set of 19x9.5 wheels. The optimal offset in a 9.5-inch ...
  1. #16
    Havasusteve's Avatar
    Havasusteve is offline Cadillac Owners Fanatic
    Automobile(s): 12 TG Sedan; SOLD
    Jun 2009
    Upland, CA
    54
    303
    Re: Anyone running 19" TSW Nurburgring wheels?
    Quote Originally Posted by Low_ET View Post
    I am about to buy a set of 19x9.5 wheels. The optimal offset in a 9.5-inch wheel is 45 mm for the front. So, if you want a square setup (like I do), then 19x9.5 - 45 mm is the best bet.
    TSW does not list that offset, but their other brand/label, "Beyern Wheels", does. Beyern has the Nurburgring wheel listed as the "Beyern Spartan" with the better offset. Beyern also sells a wheel called the "Bavaria" with the optimal offset. Those are both made using TSW's Rotary Forge method to get a strong, lightweight wheel.
    Thanks.. I have ordered a set of the dual TSW Nurburgring 19x9.5's with the 41mm offset. These will be for the track and my Toyo R888 295.30.19's will go on the rims.
  2. #17
    Low_ET's Avatar
    Low_ET is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V, Thunder Gray, Auto
    Mar 2009
    East Central Florida
    220
    Quote Originally Posted by Havasusteve View Post
    Thanks.. I have ordered a set of the dual TSW Nurburgring 19x9.5's with the 41mm offset. These will be for the track and my Toyo R888 19.30.18's will go on the rims.
    I already use TSW Nurburgring wheels for the track. The only thing I don't like about that setup is the way the 40 mm offset looks - It sticks out too wide in the front. I don't really care about looks on the track, but it is a little different for street wheels. I am about to replace my factory wheels with Beyern wheels in 45 mm offset for daily use.
  3. #18
    simgolfer's Avatar
    simgolfer is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V sedan, manual, silver/ebony, airaid, SW catback
    Jul 2011
    Elk Grove, CA
    228
    I have Bayern wheels on my V and the offsets are perfect front and back with 19 inch wheels. Bought decals with Cadillac logos to cover the Bayern center caps. Wish they had more concavity but for the price, an excellent deal.
  4. #19
    Low_ET's Avatar
    Mar 2009
    220
    Quote Originally Posted by simgolfer View Post
    Which Beyern wheels did you buy, Spartan?
    Where did you get the Cadillac Logos for the center caps? I was thinking about covering up the Beyern Logo.
  5. #20
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,062
    Good to know about the Bayerns...
  6. #21
    simgolfer's Avatar
    Jul 2011
    Elk Grove, CA
    228
    I have Bayern Bavaria in matte black. Fronts are 19 x 18.5 40, rears are 19 x 9.5 45. No spacers needed only longer lug nuts. Decals from http://eu-decals.com
  7. #22
    SoCalCTSV's Avatar
    SoCalCTSV is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 CTSV Coupe, 1966 Chevelle
    Aug 2011
    Agoura Hills
    48
    680
    Pics of decals?
  8. #23
    the blur's Avatar
    the blur is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac
    Oct 2008
    NY
    807
    Do these cars push so much, you need a square setup ?
  9. #24
    rgp6373 is offline Cadillac Owners Member
    Automobile(s): 2009 cts-v
    Feb 2009
    41
    87
    as far as i can tell you can't get the nurburgring in a 10.5 with the 65 offset in our bolt pattern only in a 27 offset the 65 has the 5x120.65 bolt pattern
  10. #25
    the blur's Avatar
    Oct 2008
    NY
    807
    I can get 4) Z06 rear 18" wheels from a 2002 Z06.
    would this fit front and rear of our V's for track usage ?
  11. #26
    Low_ET's Avatar
    Mar 2009
    220
    Quote Originally Posted by the blur View Post
    I like the square setup on the track because it makes the car easier to rotate. The downside is that it is easier to rotate. It has more of a safe understeer tendency with the staggered setup. It is more lively with a square setup but you can get into trouble faster.
    The other issue is tire wear. On the track, I tear up front tires twice as fast as rear. I get a lot more track-miles on a square setup. I plan to do the same for the street soon.
    I think the 2002 Z06 had 18x10.5" wheels on the rear. That will be hard to fit in the front. Clearance is tight on the inside (wheel lip to spindle clearance) on the factory 9.0" wide wheel. To go wider on the front, all the extra width has to go outboard.
    I took a quick look and the Z06 offset is 54 mm or 58 mm (two sources do not agree). If that is correct, the wheel will hit the spindle. The interference will be about 20 mm. That would be a huge spacer. To make a 10.5" wheel work on the front, you need an offset less than 35 mm. Unless I made a math error.
  12. #27
    Automobile(s): ZIP
    50,062
    Maybe some replica wheels for the front with legits for the rear?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
