HELP eibach pro kit install
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
Like Tree4Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, HELP eibach pro kit install in Cadillac CTS-V Series Forum - 2009-2014; I am trying to pull the front shock/spring assembly, took out the lower shock bolts, dropped the lower control arm ...
    larry arizona is offline Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    43
    1,347
    I am trying to pull the front shock/spring assembly, took out the lower shock bolts, dropped the lower control arm and unplugged the top shock plug, Do all the top shock tower bolts need to come out and remove the whole upper control arm THEN use the spring compressor? Thought I read that only two of the top tower bolts hold the shock assembly in???
    musclesbmf is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 GTR
    Jan 2009
    Tampa, FL
    42
    1,026
    Re: HELP eibach pro kit install
    Take the strut tower brace off... there is a bolt under there that also holds the shock in..
    Mark
    Feb 2012
    Metro Detroit
    43
    1,347
    thanks!!!! got it out, not too bad, got one side done
    Stillborn and Stillborn like this.
  5. #4
    Stillborn's Avatar
    Stillborn is offline Cadillac Owners Enthusiast
    Automobile(s): 09 DW 4DR,AT,Recaros,metco 2.5,RX c-can,AEM-A/F, 634hp,642tq
    May 2011
    tri-state
    46
    777
    i hope you marked the suspension...it will make life 100x easier. good luck, don't, i repeat, DO NOT put the dust covers back on. you have been advised. loL
    if you have break lube, it might be a good idea to grease that top rubber peice where it touches the inside plastic. i wish i had a pic, but unfortunately i do not.
  6. #5
    Feb 2012
    Metro Detroit
    43
    1,347
    Got it all done. WOW does that look sweet!!!!! It went together very easy once I figured out the first side. Cut the bumpstops, removed caps and NO SQUEAKS.
    Rears were a breeze.
    Ride is Excellent in both sport and tour mode. Handling is much sharper and crisper.
    ONE BIG QUESTION!!!! When I put the first side back together the dust boot/sleeve (not the cap) where the bump stop sits in fell out of the rubber spring perch. I tried to shove it back up there best I could, It has not fallen back down YET. I was hoping it will find its place with a couple full susension jounces. Its not a big deal to take it back out and reset the dust boot (not the cap). When I did the second side I was sure to push the boot/sleeve in place before reassembly.
    A MUST DO MOD!!!!! LOVE IT!
  7. #6
    Feb 2012
    Metro Detroit
    43
    1,347
    took passenger assy out and reseated the dust boot/sleeve into the rubber perch and its perfect with no knocks or rattles.
  8. #7
    hlantin's Avatar
    hlantin is offline Cadillac Owners Fanatic
    Automobile(s): Silver MT CTS-V Sedan - Recaro/Graphite Wheels
    Jan 2005
    Hollywood, CA
    294
    any pics?
  9. #8
    Feb 2012
    Metro Detroit
    43
    1,347
    I will post pics as soon as I get time to take a few
  10. #9
    DPL
    DPL is offline Cadillac Owners Fanatic
    Apr 2006
    156
    I'm in the shop starting my install. Can anyone advise on the rears? How do these come out?
  11. #10
    Feb 2012
    Metro Detroit
    43
    1,347
    I responded to your other thread. Jack up rear end unbolt lower a arm and push down and the spring can simply be pulled out. I used a jack to help align the rear a arm to put bolts back in. Takes a little muscle and patience. took 30 minutes for rears total. Very easy.
  12. #11
    DPL
    Apr 2006
    156
    Excellent. Does anyone know why our front rotors appear to be for an all wheel drive car?
  13. #12
    DPL
    Apr 2006
    156
    Day 3 with this mod and I agree, this is a MUST DO mod. The car feels as good comfort wise and has less body roll around the twists. The car looks better too. For $250 and a half day of work, nothing comes close!
  14. #13
    Hotrod-Realtor is offline Cadillac Owners Member
    Feb 2012
    48
    86
    I just finished installing springs all the way around. There seems to be two methods to install the fronts. One is described above. I chose the easier way that does not use a spring compressor. The way I did it was to pull off the electrical connector at the top of the shock. Remove the nut under that connector. Remove the second nut under that one. Remove the 2 ABS 10 mm bolts that hold the sensor in and the wiring harness hold down on the spindle. Remove the 18 mm upper control arm nut. Remove the two 13 mm bolts that hold the bottom of the shock to the lower control arm. Simply slide the shock and spring assembly out. It is really easy this way and you do not need a spring compressor.
    Reassembly is pretty straightforward. Cut your bumpstop, remove the dust cap, install the new spring, pay attention to the black washer that sets down on the shock shaft. It has a bevel that faces down. Slide the shock / spring assembly back in place. Install the two 13 mm bolts in the bottom of the shock. I used a small floor jack to push up on the bottom of the lower control arm to help install the 18 mm nut on the upper control arm ball joint. Reinstall the ABS sensor and two 10 mm bolts. Reinstall the two nuts at the top of the shock and hook up the mag ride electrical connector. You should be done.
    Once you have all your tools out, the entire job shouldn't take more than 30 minutes a side.
    Hope this helps others searching for a DIY Eibach spring install.
    Warren
  15. #14
    DRL650's Avatar
    DRL650 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS V Coupe
    Jul 2012
    Cape Coral Fl.
    199
    How are you guys lifting your cars? are you doing these with a lift? Or jack stands? If so where are you putting the stands and where are the jacking points? Thanks for any shared info.
  16. #15
    Betiwin is online now Cadillac Owners Member
    Automobile(s): CTS-V Coupe
    Sep 2012
    35
    69
    Guys Please post pictures!
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
