Supercharger/ Lid Tq Specs
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree1Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, Supercharger/ Lid Tq Specs in Cadillac CTS-V Series Forum - 2009-2014; I did a quick search on here and didn't come up with anything. Does anyone have the tq specs for ...
    FLYING V is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V
    Oct 2011
    100
    I did a quick search on here and didn't come up with anything. Does anyone have the tq specs for the blower and lid bolts?
    Thanks
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    since gm doesn't service the supercharger in this way, I'm going to say no one will know. you're going to have to take a guess, mine would be <22ft/lbs since it aluminum threads
    smackdownCTSV's Avatar
    smackdownCTSV is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V BDE (Sold) 2010 CTS-V Red (Traded)
    Jun 2011
    1,958
    Re: Supercharger/ Lid Tq Specs
    The lid doesn't come with the supercharger. So there should be torq specs for it.
  5. #4
    mannyz is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS(Sold) Black 09 V
    Jan 2009
    28
    457
    Doesn't Lingenfelter have a write up? I think its 22lbs not 100% sure though.
  6. #5
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by smackdownCTSV View Post
    didn't know that. I thought they didn't mess with the units at all..
    in that case, I'd use the 22ft/lbs rule. That's generally the max for aluminum threads as I said previously.
  7. #6
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Blue/Titanium 2009 V Auto
    May 2010
    Racine, WI
    3,426
    22 foot pounds is pretty steep for a small bolt! Isn't that only about a 6MM or so?
  8. #7
    glgjr is offline Cadillac Owners Fanatic
    Jul 2008
    128
    It is like 100 inch pounds. I have the manuals at home and I usually torque mine to 8 lbs. I will look it up when I get home.
  9. #8
    Jun 2011
    1,958
    Quote Originally Posted by M5eater View Post
    Neither did I until I saw a couple on ebay w/o the lid and the dealer re-used my lid. And this pic too. http://www.camaro5.com/forums/attach...0&d=1254086216 Also, the lid has the intercooler so they are probably trying to save money that way too.
  10. #9
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,998
    89 in lb
  11. #10
    Club Malibu is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V, White, Manual, Bone stock, no sun-roof
    Feb 2010
    459
    From my 2010 GM Shop manual:
    (all listings have the prefix "Supercharger")
    Be sure to double check for "inches" vs "feet". (For clarity, the 37's and 18's are feet. The rest are inches.)
    Air Outlet Pressure Sensor Bolt = 89 lb in
    Barometric Pressure Sensor Bolt = 89 lb in
    Belt Idler Pulley Bolt = 37 lb ft
    Belt Idler Pulley Bracket Bolt = 37 lb ft
    Belt Tensioner Bolt = 37 lb ft
    Bypass Valve Actuator Bolts = 18 lb ft
    Charge Air Bypass Regulator Solenoid Bolt = 89 lb in
    Inlet Air Pressure Sensor Bolt = 89 lb in
    Charge Air Cooler-to-Cover bolts = 89 lb in
    Charge Air Cooler Outlet Pipe Bolts = 89 lb in
    Charge Air Cooler Isolator Bolts = 44 lb in
    Lower - Manifold-to-Cylinder Head Bolts - First Pass in Sequence = 44 lb in
    Lower - Manifold-to-Cylinder Head Bolts - Final Pass in Sequence = 89 lb in
    Upper - Charge Air Cooler Cover Bolts - First Pass in Sequence = 44 lb in
    Upper - Charge Air Cooler Cover Bolts - Final Pass in Sequence = 89 lb in
  12. #11
    Feb 2010
    459
    Sequence for Lower
    Sequence for Upper
  13. #12
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    great info!
  14. #13
    Oct 2011
    100
    Great, thanks a lot for the info wait4me and Club Malibu!
  15. #14
    SecretWeapon is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Sedan, M6, Silver/Ebony
    Oct 2010
    Spring, Texas
    457
    Thanks for posting. Will be changing out the SC this weekend for a ported one and was wondering the same thing.
  16. #15
    musclesbmf is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 GTR
    Jan 2009
    Tampa, FL
    42
    1,026
    Also, it's a two step process... First pass is like 44, and the final is 89 and that is inch lbs, not ft lbs... You'll snap the bolt if you use the wrong measurement.
    Mark
    Tedboss1 and Tedboss1 like this.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
