Results 1 to 4 of 4
Thread: I Started making Real Carbon fiber cold air kits. For 102mm and larger throttlebodies
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,997
    Hi guys, Due to the need of tubing i could not get, I have started making my own carbon fiber parts here in my shop.. It takes a few days to make each part due to curing times, ect. But i should have enough extras to start selling soon when i get back from PRI next week. Ill probably make 10 kits at a time just so i dont have to do them as much.. Tubing sizes will be 102mm ID and 105mm ID with as little of a bend as possible to fit multiple setups.
    Carbon fiber material im using is aircraft top of the line stuff.
    It will allow us to use 102 and 105mm throttle bodies to thier full potential.
    Tuning WILL be required with this type of kit because of it massive internal non restrictive volume.
    SecretWeapon is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Sedan, M6, Silver/Ebony
    Oct 2010
    Spring, Texas
    457
    Re: I Started making Real Carbon fiber cold air kits. For 102mm and larger throttlebo
    Sounds like a good solution to the heat soak/transfer of the metal tubes. Please post pictures and price once maf positioning and development are completed.
    vetkila is offline Cadillac Owner
    Automobile(s): 2009 CTS-V
    Sep 2009
    NJ
    35
    188
    Would this fit the TVS 2300?
  5. #4
    aceofblitz is offline Cadillac Owners Fanatic
    Automobile(s): '09 CTS-V
    Feb 2009
    217
    Make sure you send me a set along with that block, I need to install/break-in the new block before you arrive
  • You may not post replies
