160 thermostats, is it worth changing to
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Like Tree4Likes
2009-2014 Cadillac CTS-V Performance Mods Discussion, 160 thermostats, is it worth changing to in Cadillac CTS-V Series Forum - 2009-2014; Just wondering if I should change the T-stat to 160. Car runs great but if it can better, I am ...
    1Sensei is offline Cadillac Owners Fanatic
    Automobile(s): CTSV COUPE
    Aug 2011
    156
    Question 160 thermostats, is it worth changing to
    Just wondering if I should change the T-stat to 160. Car runs great but if it can better, I am all for it. Please chime in with your feedback. Thanks in advance.
    wait4me's Avatar
    wait4me is offline Cadillac Owners Connoisseur
    Automobile(s): 11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
    Jan 2009
    warsaw indiana
    2,998
    Re: 160 thermostats, is it worth changing to
    Well, The coolant temperature dramatically effects applied timing, so It does help keep your horsepower.
    When past 212 degree coolant temp, it will start to pull timing. 1.8 degrees at 2000rpm and .6 degree at 5200 rpms. More as your coolant temp goes up.
    Plus the underhood temp drop, the quicker engine temp drop, and other benefits.. Even cooler running transmission from the lower allowed fan settings.
    smackdownCTSV's Avatar
    smackdownCTSV is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V BDE (Sold) 2010 CTS-V Red (Traded)
    Jun 2011
    1,958
    It's a very popular, cheap, and easy to do mod.
  5. #4
    qictrk's Avatar
    qictrk is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2008
    The coast, Ca.
    589
    Its an easy change mechanically, but most likely, you well need a reprogram of your ecm. Most people get an engine code error if you don't, me included.
    Some people don't, but its rare. Cecil..........
  6. #5
    EdwardETraylorIII is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V, Z06s, ZR1...
    Sep 2011
    188
    You will see little to no advantage to doing this mod. The thermal efficiency of the radiator on our cars is already maxxed out so changing this thermostat doesn't buy you an appreciable drop in engine temps.
    With so many people having leaking aftermarket thermostat issues, why bother?
  7. #6
    Gary Wells is online now Cadillac Owners Connoisseur
    Automobile(s): '09 CTS-V, 3K miles & '87 Turbo Buick, 29K miles
    May 2009
    Long Beach, Kali
    70
    3,321
    Looks like Ed has had previous experience with this.
    More than likely it can or will affect ability to pass smog in smog states.
    Even on the turbo Buicks, this mod by itself is pretty worthless.
    And it can and will affect the ability on those cars to pass smog also.
  8. #7
    shade is offline Cadillac Owner
    Automobile(s): CTSV
    May 2010
    AZ
    499
    Sorry boys no matter what thermal efficiency says...
    Before the mod car ran 205 all day long
    After the mod car runs 185-190 all day long under the same conditions. I have logs to back it up.
    It allowed for another couple degrees of timing with absolutely no knock.
    Dale Pittman likes this.
  9. #8
    Speedtrapped is offline Cadillac Owners Fanatic
    Automobile(s): 11' cts-v wagon
    Jul 2011
    45
    390
    I understand the purpose, what is stock? Mine was done as part of LPE performance package, but when you think of it, once the engine is hot, the t stat is just an opened valve-right? I am still wondering if it makes sense to spend the $ on a better IC rad, given that I live in NE, and its now cool out. But as I have heard Ed discuss alot sounds like meth is the bigger bang for the buck. Sorry didnt mean to thread jack.
  10. #9
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Blue/Titanium 2009 V Auto
    May 2010
    Racine, WI
    3,426
    I was debating this for a while myself. After reading, that when tested, the stocker opened in the 180s, I left it alone. I wish someone made a 180 also. I just don't want to drop that low for a DD in Wisconsin.
  11. #10
    Tedboss1's Avatar
    Tedboss1 is online now Cadillac Owners Enthusiast
    Automobile(s): 2009 CTSV Auto
    Jun 2009
    Montreal
    927
  12. #11
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,090
    Quote Originally Posted by EdwardETraylorIII View Post
    The most obvious benefit that I saw when I changed to a 160 degree t-stat on my Camaro (along with reprogramming the computer to take advantage of the change) was that I could be out on the track going full blast for more than 1/2 hour and the temp gauge hardly budged... and yes, the '98 F-bodies were the last year that the car had a "real" temperature gauge! After the change, it took virtually no time at all to cool the car back down after a lapping session to where the needle would read normally. With the stock t-stat, I'd have to drive around the pits for 6-7 min. to get the gauge back down.
    Before the swap, the temp needle would begin to come close to the red area on the gauge after 15-20 min. on the track and I had to keep a close eye on it - especially on hot days.
    That being said, as Ed is suggesting here, this may not be an issue at all with the V. A 25-30 min. lapping session in the V has virtually no effect on the where the needle points on my temperature gauge.
    I also never had a problem getting lots of heat during the winter with the 160 t-stat in the Camaro when I would take it out on dry days...
    Best regards,
    Elie
  13. #12
    Aug 2011
    156
    Thanks for the feedback. I thank I may change it after other mods.
  14. #13
    Bushidopupil is offline Cadillac Owners Enthusiast
    Automobile(s): (V)icious Coupe
    Oct 2010
    FL Panhandle
    571
    Mine was changed 12 days after buying the car new....temp never gets over 210, even where I live in Florida. Also, I just took it to the half mile event and ran it 7-8 times, hitting 151 mph and never broke 210....I say it is worth it if you plan to mod, and if you are in a hotter climate IMHO.
  15. #14
    kcshaner is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V, 545 RWHP 591 TQ
    Oct 2010
    36
    72
    I have my car going into the shop for a few little things tomorrow along with a tune. If it was spring time I would think it would be a no brainer to toss one in, but considering I am heading into winter I think it may be best to wait. Any thoughts on this? Will heat be an issue at all in the sub 20 degree temps with a 160 stat?
  16. #15
    Tedboss1's Avatar
    Jun 2009
    Montreal
    927
    I have installed the 160 deg thermostat and during last winter in Montreal heat was not an issue in my V.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
