CTS-V dyno, stock Vs wait4me tune + 2.55 pulley - Page 3
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 76
2009-2014 Cadillac CTS-V Performance Mods Discussion, CTS-V dyno, stock Vs wait4me tune + 2.55 pulley in Cadillac CTS-V Series Forum - 2009-2014; Isn't belt slip a non issue at this point? Mainly because a little smaller belt can be used? Can original ...
  1. #31
    shade is offline Cadillac Owner
    Automobile(s): CTSV
    May 2010
    AZ
    499
    Re: CTS-V dyno, stock Vs wait4me tune + 2.55 pulley
    Isn't belt slip a non issue at this point? Mainly because a little smaller belt can be used? Can original upper pulleys be purchased or does a 3rd party make original sizes?
  2. #32
    markrn is offline Cadillac Owners Member
    Automobile(s): 11 V Sedan / 06 TBSS
    Aug 2010
    58
    71
    How many miles on your V?
  3. #33
    6speeder is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Feb 2010
    59
    293
    Quote Originally Posted by shade View Post
    Belt slip CAN be an issue, even with a smaller belt because the smaller diameter means that less of the upper pulley is in contact with the belt (less belt wrap). That being said, I don't think I'm experiencing any slip.
    GM does not sell the stock pulley, only supercharger snouts with pulleys, they really don't want this to be a replaceable item.
  4. #34
    Automobile(s): CTSV
    May 2010
    AZ
    499
    Then like the other member said lets get a vendor to make snouts with the pulley size of choice on them...or stock pulleys we can press back on...
  5. #35
    Feb 2010
    59
    293
    You can press on the stock one, just be careful when removing. Mine is perfect and can go right back on.
  6. #36
    Automobile(s): CTSV
    May 2010
    AZ
    499
    Gotcha. Did you also use a solid isolater at the same time?
  7. #37
    Feb 2010
    59
    293
    No I didn't. Wasn't there a thread here where GM engineering actually came on and said that would cause more problems than the wear on the shaft caused.
    BTW: We did see some wear.
  8. #38
    PremierJosh is offline Cadillac Owners Fanatic
    Sep 2010
    Memphis
    37
    340
    Quote Originally Posted by 6speeder View Post
    Yes there was but I have never seen the solid cause anymore shaft wear. Every shaft I have seen has had wear. I would change, do you ever think a gm engineer would come on here and say the stock part causes issues and you should install a aftermarket peice?
  9. #39
    Bowtye8's Avatar
    Bowtye8 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V & 2006 Z06
    Sep 2010
    Florida
    43
    136
    What shop pressed on the new pully? A local speed shop or dealer?
    I sent a pm to Jesse interested in this setup.
    I did not talk with him yet.. but now I am confused either to go with a upper 2.55 or lower 9.5...............?
    Thanks.
  10. #40
    neuronbob's Avatar
    neuronbob is online now Cadillac Owners Connoisseur
    Automobile(s): 2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
    Dec 2007
    Cleveland area, OH
    46
    4,303
    2.55 is very good bang for the buck. I've got 7000 miles on my setup. I can confirm that the pulley looks stock. No belt slip, not even once, not even on my single trip to the dragstrip since install. Belt slip may be a potential problem, but I've never had it and I don't think anyone else with an upper in this application has, either, at least on this board.
  11. #41
    kirbyCTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V manual
    Nov 2010
    Memphis, TN
    37
    433
    does the upper 2.55 belt slip only occur when adding a new lower pulley or even with a stock one?
  12. #42
    Sep 2010
    Memphis
    37
    340
    Only with a lower also. With the correct belt on my 8.6 lower combo I have never had belt slip. I also added a larger upper idler pulley recently, it gave me a little more upper belt wrap but boost still datalogs the same. It was just extra insurance. But at some point as belt speed and pulleys get smaller it will become a issue just like it has been for the cobra guys.
  13. #43
    cbloveday's Avatar
    cbloveday is offline Cadillac Owners Connoisseur
    Dec 2007
    4,151
    Does changing belt often help? I bought spares in case it does. I plan to put on a new one periodically at the first signs of wear or slippage.
  14. #44
    snzuloz's Avatar
    snzuloz is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V / 2004 Porsche CTT
    May 2010
    Look up Way up
    44
    724
    Quote Originally Posted by cbloveday View Post
    I don't know about you but I was surprised at how little the tensioner moves to release the belt, usually it takes a lot of movement, not so on these. Once the belts stretch a little and start to glaze it's time to ditch them, I don't think mine will ever see them start to develop any cracks etc before replacement. I think the upper swap is best served with the upgraded idler (100mm I think) chances of slippage probably negligable with that much wrap.
  15. #45
    Sep 2010
    Memphis
    37
    340
    I view on the 2.55 upper vs 9.6 lower debate is that is you are a person that already really enjoys the car and hasn't kept modding there past cars the 2.55 is good for them. Very cost effective. Now if you are a guy where gaining 80whp is good for now but it is just a stepping stone to more mods in the future get the lower 9.6 so you can switch to the 10" when you do heads and cam. You know your past with cars. I have always wanted more and more power on every car I have owned.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
