LS9 cam on the way
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 15 of 108
2009-2014 Cadillac CTS-V Performance Mods Discussion, LS9 cam on the way in Cadillac CTS-V Series Forum - 2009-2014; Just as the title says. Much bigger cam and it should really wake the V up with the 10% crank ...
    DrumStix is offline Cadillac Owner
    Automobile(s): 2009 CTS-V
    Nov 2009
    1,651
    LS9 cam on the way
    Just as the title says. Much bigger cam and it should really wake the V up with the 10% crank swap I'm doing at the same time. Install appt is 5/14.
    dqw1's Avatar
    dqw1 is offline Cadillac Owners Connoisseur
    Apr 2005
    Madison, AL
    53
    2,015
    Re: LS9 cam on the way
    That might be too much power. j/k
    Please post a video when you get done.
    Nov 2009
    1,651
    LOL. I'll get a video.
  5. #4
    1-2-N-V is offline Cadillac Owners Fanatic
    Apr 2009
    363
    subscribed
  6. #5
    backup is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTSV, silver, manual
    Mar 2009
    Indiana
    213
    I know this has been discussed before, but in my reserach the LS9 cam still seems a bit mild? no? Can do a more aggressive cam with stock heads and still idle and drive well I think. Would like to know your opinion on this.
  7. #6
    CTSV4now is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS-V
    Oct 2009
    Houston
    413
    do you have specs on LSA cam and LS9 cam?
  8. #7
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,276
    Too much power.
  9. #8
    Operations is offline Cadillac Owners Member
    Automobile(s): none
    Jun 2009
    55
    5
  10. #9
    Mar 2009
    Indiana
    213
    From my research, the LSA cam is this:
    198/216 0.480"/0.480"
    the LS9 cam is this:
    211/230 0.562"/0.558"
    I think they both have the same lobe separation angle also (117?), which means the overlap is nearly identical (I think, can somebody confirm this?). This is an important parameter in a FI engine.
    From those that have run the LS9 cam the report is it is still 'mild'. There are also reports from various sources that more aggressive cams still run and idle near stock but add more power. My big concern is how do they work with the stock LSA heads (many who have gone with >LS9 cams have also done heads) and how they run at high rpm (springs and float and ramp rates and all kinds of conerns that I am no expert to decipher).
    I am about this --><-- close to pulling the trigger on a package that includes the W4M .604 lift cam which I think would rock!
  11. #10
    Nov 2009
    1,651
    Quote Originally Posted by backup View Post
    $95 experiment in stock drivability while surfing the net at lunch today. I'm not looking for something too burly in the V. Cams go in, cams come out. The difference between these two cams is pretty huge.
  12. #11
    Nov 2009
    1,651
    The LSA and LS9 are more like 120.5 - 121 on both cams. I don't think GM has done much under 119 on any of the LSX motors, at least in the cars.
    You can go WAY up on the duration as long at you maintain a wide LSA in a split duration cam and retain great drivability. I want quick cylinder filling and I will get that with this cam. I also want good bottom end with this heavier car and this cam will retain that. What is making you consider a .604 cam, if you please? Lift is not the most important number on a cam, especially a blower cam. Do you know the other numbers?
    I'm also adding 918's and chrome moly push rods so she'll be stout like Guiness. I'll be bumping the limiter more towards 6600 as well, to match the LS9. The rockers are the same in both cars.
  13. #12
    Nov 2009
    1,651
    Quote Originally Posted by thebigjimsho View Post
    Too much power.
    Ahahahaha, you kill me.
  14. #13
    glgjr is offline Cadillac Owners Fanatic
    Jul 2008
    128
    Too much power.
    I guess this is your schtick?
  15. #14
    Karch's Avatar
    Karch is offline Cadillac Owners Fanatic
    Automobile(s): 2010 TG sedan, 6A,LPE 650, and a few more mods.
    Dec 2009
    Los Angeles
    492
    Overlap is not solely dependent on LSA. If you have increased duration with the same LSA, you will have more overlap.
    BTW, these heads love lift. Have you seen the flow data at lifts above 0.500".
    If I were to go through the effort of installing a new cam, it certainly would not be a cam from the factory, as they make too many compromises. Just my 2 cents.
    Sure, they've tested them well enough, but they also put in too much cushiion with regards to valvetrain wear and noise, emissions, and driveability for all the potential owners.
    Also, bear in mind that the LS9 is designed for a car that weighs a half-ton less than a V. Just be sure to do your homework, and best of luck.
    I'm sure it will improve quite a bit, but I think there are much better options out there.
  16. #15
    Nov 2009
    1,651
    Quote Originally Posted by Karch View Post
    Good, get your wallet out and make your purchase.
    EVERYTHING has a set of compromises.
    You will not have more overlap if you split the durations WIDER apart as in the LS9 cam. It all depends on when the opening and closing events occur. You could have a 210/235 cam with nearly no overlap. If you tighten them up you can get more overlap but will increase exhaust scavaging, which is not necessarily a bad thing. It also depends on the advance ground in. Are we going deep into cam theory now?
    Most of what they've done on the LS9 cam, to extend your theory, was split the duration wider, causing a lengthened time for cylinder filling and a broader power band. That should more than make up for the torque band changes and the LS9 cam's LSA is much wider so I'm sure it will haul this car around just fine. They also kept the lift reasonable for longevity and to prevent the thing from eating itself in 10,000 miles. So with lower durations and a wider LSA, I am going to have early cylinder filling over a wider range while retaining acceptable mileage and bottom end. There is a lot more I can do with this car than throw a stupid ass big cam in there to kill mileage, drivability, engine vacuum under coast, bottom end, valve springs and so on. But, If I feel like it, I can add 1.85's in an hour and a half to bump the lift to .612.
    So, are you getting a 244/250 cam on a 113 with .620? Remember, most of the cams are made for lighter cars.
    BTW, there is no trouble for me installing this cam. I just don't want to have "too much power," lol.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
