LS9 cam on the way - Page 7
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 108
2009-2014 Cadillac CTS-V Performance Mods Discussion, LS9 cam on the way in Cadillac CTS-V Series Forum - 2009-2014; I read "similar cam" so they will have similar gains. Since you chimed in, any recommendations? There are hundreds of ...
  1. #91
    DrumStix is offline Cadillac Owner
    Automobile(s): 2009 CTS-V
    Nov 2009
    1,651
    Re: LS9 cam on the way
    I read "similar cam" so they will have similar gains. Since you chimed in, any recommendations? There are hundreds of other cams to choose from for the LSX.
  2. #92
    94guy is offline Cadillac Owners Member
    Sep 2010
    44
    i went ahead and installed the ls9 cam. i hope it makes me about 30rwhp. i just wanted something that drives like stock but has good gains in power. if i don't make the power with my over all combo i will put the lingenfelterGT9 cam in.
  3. #93
    Nov 2009
    1,651
    You'll be fine. Post your mods and I'll give you the expected RWHP. Also, is this the only thing your changing this round of mods?
  4. #94
    PremierJosh is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Sep 2010
    Memphis
    37
    340
    I'm ready to order a camshaft. Does anyone that went with a ls9 wish they would have went a little larger? I plan to also do ported heads in the future so I would like something with a little more lift but I want what to be able to tell there is a cam in the car at all.
  5. #95
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,831
    Not me, I'm perfectly happy with the LS9 cam. The power added met my expectations and being an OEM cam from a 50-state car, I'm not expecting to have any problems passing the Cali smog test down the road. If I wasn't worried about smog, I'd probably be running LPE's GT9 cam (no lope claimed and who knows if it would've passed smog anyway?). Beyond that, from what I understand, the GT11 cam has a nice, ever-so-slightly lopey idle that you can still run on an auto. At least one other forum member has posted over the last year or so that he is running this cam.
  6. #96
    Razorecko is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V , 2010 SRX 2.8T
    Feb 2008
    3,092
    What kind of power increases are you guys getting with the ls9 cam ? in terms of hp AND tq and is it across the board or just on the high end ?
  7. #97
    Dec 2008
    SoCal
    1,831
    Mine went in with a 9" pulley and ported snout and I went from 525 to 574 RWHP. Although the pulley alone is said to be good for around 30, I don't think this means the cam alone would be good for only 20. It might also be good for 30 on it's own, but since I have stock heads, exhaust manifolds, and all 4 cats, perhaps that is the limiting factor. From the dyno graphs, it looks like more power across the board (pulley), but the gap increases at the top end (cam)--so they raised the rev limit slightly to take advantage of it (better springs, but stock valves, pushrods, and rockers).
  8. #98
    Feb 2008
    3,092
    Hey GMX, what did your tq increase ?
  9. #99
    Dec 2008
    SoCal
    1,831
    Razor, I don't have my charts handy at the moment, but I seem to recall that it tracked pretty linearly. When I was at 524 RWHP, I believe my RWTQ was numerically within 10 points. I'm at 565 RWTQ now--still within 10 points.
  10. #100
    Nov 2009
    1,651
    I went from 476 to 579 with just the LS9 cam and 9.5" pulley an the car was still fast as well. I'm right at 600 RWHP with this combo now. Headed to the dnyo as soon as MSJ calls me back.
  11. #101
    Sep 2010
    Memphis
    37
    340
    I'm liking the specs on the GT9 camshaft, its more into the lift range a good set of CNC heads can take advantage of. I'm just wonder about how the car will behave with the larger stick in there? Does anyone have any experiance with this camshaft? Can you hear it at idle, any shake to the car, any low rpm issues?
  12. #102
    Feb 2008
    3,092
    Can one of you guys with the ls9 cam throw up a dyno graph, i'm curious to see what the curve is
  13. #103
    Sep 2010
    44
    drumstix, what's the 9.5" pulley worth hp wise? also i have seen adm claim the ls9 cam is 18-20hp over a stock ls3 cam. i would hope more with the blower.
  14. #104
    Dec 2008
    SoCal
    1,831
    Quote Originally Posted by Razorecko View Post
    Hey Razor, finally back home; here's what I got:
    I don't know why the resultant HP doesn't appear in the green box, but 525.8 + 47.9 = 573.7. (LS9 cam, ported snout, 9" pulley over baseline)
  15. #105
    Feb 2008
    3,092
    ^ thank, so you were bumped about 50+ over stock with a ls9 cam, ported snout & a 9". The 9" pulley is good for about 20-30 that would leave the snout and cam with about 20 left. The gain is smooth and very streetable. I think cam selection is a case by case basis. There are cams that will give alot of hp and pull tq or give slightly across the whole band. For someone that does inner city driving they might want a different cam than someone who drives 90% highway. Also this would play into if you are a manual transmission or automatic. If you have a large increase only at a certain rpm its much easier to get access to that power with a shifter and a clutch than two flippy paddles.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
