For the people that purchased W4M full exhaust and found it to be to loud, i found a fix for about $50. You have to cut off the stock mufflers and put it on Jesses system. When you want, you can go back to stock. I made this change and it is almost stock sounding. I got these items from Summit. 2 1/2" clamps(2) Sum-G4625, 3" clamps(2) Sum-G4630(2), SST Strap Band WLK-33240(2) You can do without Strap and use the ones from Jesses kit, i just wanted a spare set, Reducer WLK-41973(2).
Picture 1 :http://rides.webshots.com/photo/2336142860032470346CFfsZH
This if part of what i got.
Picture 2 :http://rides.webshots.com/photo/2632786330032470346tRnsuQ
Make a cut on both pipes 4 1/2".
Picture 3 :http://rides.webshots.com/photo/2168674050032470346YtOkOJ
This show the weld.
Picture 4 :http://rides.webshots.com/photo/2688089640032470346BYSknA
You cut off the stock muffler 4 1/2" from curve.
Picture 5 :http://rides.webshots.com/photo/2294243670032470346lEucNc
Shows what it looks like hooked up.
Picture 6 :http://rides.webshots.com/photo/2134135990032470346gGunmn
Missing the 2 1/2" clamp.
Picture 7 :http://rides.webshots.com/photo/2328294820032470346FuHAOS
Last picture.
I can't say that my 4 1/2" cuts will work on yours for sure because of the varance in weld spots etc. You do have some play, so it should work but i give no guarantee. I am not a mechanic.
You can go back to stock at anytime by using the sst clamps. DO NOT cut off any extra pipe of the stock system.
If your still not sure what i'm doing, you can email me with your phone # and i will give you a call. I'm not the best at putting into works whats in my head. Cecil.........
This show the weld.
Last picture.
