Hi all, I am new to the forum and planning on getting the 2011+ CTS-V, no more than 40k. I tried to search as much as possible the web and the forum on how reliable is the car and what are some major issues that many of you deal with?
Well, could not find much and that is why I am creating the thread.
I deff want warranty on the car cause I am positive that parts aren't cheap.
So, what common issues do 30k+ miles CTS-Vs have (read that some people have some rattle on the supercharger and whining sound from the differential) and what should I have in mind when buying one?
Any advice is appreciated! Looking forward to getting one one of these babies.
The most common issue is a noisy supercharger related to the isolator. GM has extended the warranty on that part to 7-8 years (can't remember which) and 120K miles from the original in-service date.
Other issues:
"Rocking Recaros" - a light shifting of the seats when making turns. I'm not sure if this is limited to the Recaros as my previous non-V CTS coupe without Recaros did this. My guess is that it is a chronic problem with the seat mounting points on the platform.
Rear end - some cars have had issues with the rear ends needing to be replaced. I think this was more common in earlier models, but other members can correct me on that.
Clicking front wheels - this is noticeable when making tight turns at low speeds. Difficult to hear in the cabin unless the windows are rolled down. Dealer can fix it by cleaning the hub and wheel, and in some cases replacing the lug nuts. It often reoccurs after a while. I had mine serviced in August and it hasn't come back yet.
Leaking moon roofs. - I believe this is most common in the sedans with the Ultraview glass roof. It is not exclusive to the V and applies across the CTS line. I believe it's less of an issue in the coupes as its a different design with a panel that only tilts (vents) and doesn't retract. The cause typically are clogged drain holes. Some folks correct the problem by using the line from a weed Wacker to clear the hole. I have not had an issue in my previous non-V coupe and my current V-coupe. Obviously not an issue if you get a car without a moonroof.
The clicking wheels and "rocking Recaros" are very minor issues in my opinion. The supercharger issue is covered by an extended warranty, even if the factory warranty has expired.
Do a search as there are plenty of these kind of threads. The car and platform is pretty solid.
How is the automatic transmission? Any issues that are common. I would really prefer a stick but haven't seen a sedan with stick for sale...but if I have no other option I will get the auto.
The replacement supercharger has a solid isolator which has a droning noise at low rpm until normal temps come up. I would not replace it if I had to do it over again. We were warned years ago about the new noise; it's embarrassing.
Looks like a fair deal, you could probably negotiate a bit more on the price. I personally don't put a lot of stock in Carfax. Not useless, but since it's all based on voluntary reporting there isn't anyway to be sure that it is completely accurate.
Because the car was a fleet rental and then privately owned for just one year it may not be modded but, you still want to have the dealership inspect it. There have been a few folks who found out after the purchase that their V had been previously modded and not disclosed. That can cause problems with the warranty.
I know a guy who rented a cts-v for two weeks and was killing it, cause it is a rental. The cars looks pretty good though, plus if it has warranty it should not be a big deal.
I might go and check it out.
Rental + 550hp = abuse. I know a guy who rented a cts-v for two weeks and was killing it, cause it is a rental. The cars looks pretty good though, plus if it has warranty it should not be a big deal. I might go and check it out. ---------.
Still under warranty, pick it up for $40-$42K and consider it well bought. Use consumables as leverage (tires, brakes) and any wear and tear (interior upholstery, paint chips). Gotta say though, I believe that there are some leftover 2013's out there with zero miles that can be had for $50K. Not sure if that's in your price range, but the peace of mind knowing that no one else, other than a few aggressive test drives, ever put miles on your car may be worth the extra dough. It was for me.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
