Results 1 to 4 of 4
Thread: Wagon Rear Tire pressure?
    silvrwgn is offline Cadillac Owners Member
    Automobile(s): 12 CTSV wagon
    Dec 2013
    south san francisco
    7
    what are you guys running? door sticker says 35psi....got about 5K miles on tires and just looked at them and the centers are worn out more ... guessing should drop them to 33psi..?
    FLTRI's Avatar
    FLTRI is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 V-Wagon & 2012 SRX Premium
    Jul 2011
    Las Vegas, NV
    53
    1,006
    Re: Wagon Rear Tire pressure?
    I'm running 37 rear, 34 front. Tires are wearing evenly, rears have more wear than the front (no shocker there). I have ~17K on them now, and the rears look like they may hit 20K. Maybe. Fronts might make it a little longer. I'll be going to PSS's when the time comes.
    One thing I've noticed is that on both my iPhone app, and the monthly OnStar emails, the rear pressure recommendations have changed to 32 psi all the way around, same as the Coupe & Sedan. Not sure if GM really changed the specs, or if it's an error with OnStar???
    Dec 2013
    south san francisco
    7
    yes, i noticed the same thing with the app! I will also be using the Pilot SS .... thanks
  5. #4
    FLTRI's Avatar
    Jul 2011
    Las Vegas, NV
    53
    1,006
    I run all my car and bike tires at two pounds over recommended. Sidewall flex causes heat, heat kills tires. Max pressure on the sidewall (PS2) is 51 psi, so I'm well within limits even after the tire heats a bit, and goes up another pound or two...
  • You may not post replies
