Ultraview wind noise when open
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 15 of 15
2009-2014 Cadillac CTS-V General Discussion Discussion, Ultraview wind noise when open in Cadillac CTS-V Series Forum - 2009-2014; Do you guys with the ultra view sunroof notice the air deflector makes the sun roof far noisier than if ...
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    689
    Do you guys with the ultra view sunroof notice the air deflector makes the sun roof far noisier than if there was no deflector? As the roof opens, a plastic deflector raises up automatically (it just has metal attachments that kind of spring load it to raise). If I'm driving along, the deflector makes an annoyingly loud rushing wind sound. If I reach up and hold the deflector down, it's far quieter and just has a deeper sound. Overall, I find it much less intrusive without the deflector raised.
    What do you guys think? I can't find an easy way to hold the deflector down or remove it.
    1997BlackETC's Avatar
    1997BlackETC is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Mercedes E63 Amg Station Wagon
    Apr 2006
    Florida
    56
    1,348
    Re: Ultraview wind noise when open
    How about if you kept a piece of black duct tape on the side of the center console and slapped it on the deflector when you need it?
    vfaninva's Avatar
    vfaninva is offline Cadillac Owners Connoisseur
    Automobile(s): Prev '09 Raven V sedan, Current '13 Thunder Gray V coupe
    Dec 2012
    Virginia Beach, VA
    51
    3,011
    Quote Originally Posted by 1997BlackETC View Post
    Ha! Welcome back!
  5. #4
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,418
    It is annoying that there is more noise with the deflector. The Ultraview has two 2 set settings when sliding back. 80% and 100%. If you keep it at 80% its much quieter. But I always likes mine all the way open and tunes cranked...
  6. #5
    Silverback is offline Cadillac Owners Member
    Automobile(s): None
    Dec 2013
    63
    67
    This has been true of every vehicle I have owned that had a sun roof.
  7. #6
    vfaninva's Avatar
    Dec 2012
    Virginia Beach, VA
    51
    3,011
    I used to use the vent feature to avoid wind noise or just turn the music up. If you can find a way to remove the deflector, and be able to reinstall it later, give it a try. Good luck.
  8. #7
    mpouls1's Avatar
    mpouls1 is offline Cadillac Owners Enthusiast
    Automobile(s): '09 V 11.99@118mph, '11 Tahoe LTZ, '03 Silverado, '00 Jetta
    May 2009
    iatethebones
    620
    Quote Originally Posted by spearfish25 View Post
    I noticed this also. I usually just leave mine closed though. Thought briefly if I could devise some device to hold it down but never put much thought into it. If you do please let us know.
  9. #8
    OldRoadDawg's Avatar
    OldRoadDawg is online now Cadillac Owners Connoisseur
    Automobile(s): Radiant Silver 2009 CTS-V
    Aug 2004
    Spanish Springs
    1,811
    Actually it is easy to remove/install. I had mine off about 2 yrs ago. Easier with two guys, but it snaps into place - no tools required.
    Quieter without it, but the wind buffeting is... different.
  10. #9
    May 2013
    Naples, FL
    689
    The deflector inserts into each of the lateral rails. I'll have to see if there's an easy way to disconnect it. I'll keep you guys posted if I figure out a reasonable workaround.
  11. #10
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,123
    Yeah - it's annoying. Try cracking open the back windows an inch (if you don't have a coupe). That helps a bit. My wife's '07 SRX has a similar Ultraview setup but with a taller fabric-like deflector that is much quieter. Wonder if this issue has been addressed in the new CTS...
    Best regards,
    Elie
  12. #11
    May 2013
    Naples, FL
    689
    OK, got the deflector off. It's simple actually. Here's how to do it:
    1. Open the sun roof all the way.
    2. Follow the metal air deflector supports toward the rear of the car. You'll see they insert with a little hook on each side of the sun roof.
    3. Using a flat-blade screwdriver, push down on the hook that's protruding and with your other hand, push the deflector towards the back of the car.
    4. Repeat on the other side.
    5. Gently disengage the front of the deflector from the leading edge of the sun roof.
    6. Once the front of the deflector is free, rotate is upwards and each support will now slip out and it's free.
    You can read the steps in the service manual below too . Problem solved.
  13. #12
    cdog533's Avatar
    cdog533 is offline Cadillac Owners Enthusiast
    Apr 2004
    539
    If you have the windows closed, and no deflector, you'll get pretty severe buffeting in the car.
    That's why it is there. Just push it down when the windows are up and you'll hear a WUB WUB WUB WUB... That's what it prevents.
    Maybe this is a non-issue, as 99% of the time my sunroof is open, my windows are too.
  14. #13
    Tedboss1's Avatar
    Tedboss1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTSV Auto
    Jun 2009
    Montreal
    987
    Attachment 174082
    I have removed my deflector as well and it reduced the noise a lot.
    There was another thread on this topic:
    http://www.cadillacforums.com/forums...ind-noise.html
  15. #14
    May 2013
    Naples, FL
    689
    I found little to no buffeting without the deflector which is why I took it off. Most cars get a nasty low resonance like you mention but my wagon doesn't do it. It's just super quiet now.
  16. #15
    HUGN*RDS's Avatar
    HUGN*RDS is offline Cadillac Owners Fanatic
    Jan 2013
    I'm shipping out to Boston
    27
    168
    Mine is loud too but it quiets down pretty significantly when I put the HVAC air on recirculate...try it!
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
