Which auto trans & brake fluid are our Vs filled with?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 3 of 3
2009-2014 Cadillac CTS-V General Discussion Discussion, Which auto trans & brake fluid are our Vs filled with? in Cadillac CTS-V Series Forum - 2009-2014; Mine is a 2011 CTS-v and some say ours is filled with dexron 4, but some say it's dexron 6. ...
    uptownvinc's Avatar
    uptownvinc is offline Cadillac Owners Member
    Automobile(s): CTV-V
    Jul 2013
    34
    41
    And i'm definitely sure that it must be dexron 6.
    Also, break fluid seems to be filled with DOT3 as it's marked on the cap.
    Is this right? Shouldn't it supposed to be DOT5.1??
    My friends checy cruze is filled with DOT3!!
    thegraham77 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS V Coupe Thunder Gray ChromaFlair
    Jul 2012
    Iowa
    57
    Re: Which auto trans & brake fluid are our Vs filled with?
    Its Dexron-VI. I was actually told by a tuner to fill the trans about 1.5 quarts over full, which is a pain because there is no filler can and you have to pump it in thru the check hole underneath. My car was "hesitating" on hard shifts from 1-2 and 2-3 gear. Although I couldn't get a full 1.5 quarts extra in, I got about 1 quart in and it seemed to solve the problem. The trick is to do it when the trans fluid is cold or you will never get the extra in due to the fluid being warmed up and expanded.
    As for the brake fluid, your guess is as good as mine on that one.
    jzchen is offline Cadillac Owners Fanatic
    Automobile(s): '85 Sedan de Ville, '10 CTS-V
    Sep 2009
    Arcadia, CA
    39
    344
    It is filled from the factory with DOT 3. The manual recommends changing to DOT 4 if you are going to the track...
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
