gas tank replacement
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 15 of 15
Like Tree4Likes
  • 2 Post By spearfish25
  • 1 Post By Dr. Design
2009-2014 Cadillac CTS-V General Discussion Discussion, gas tank replacement in Cadillac CTS-V Series Forum - 2009-2014; Hi all This is my first post here, but I've been lurking for a while. Question: Is is possible to ...
    hoontang's Avatar
    hoontang is offline Cadillac Owners Member
    Automobile(s): 2014 CTS-V Wagon OBM 6MT
    Jul 2013
    central Florida
    38
    Hi all
    Question: Is is possible to replace the fuel tank in a CTS-V wagon with a higher capacity tank?
    I would think that with the way cars are designed this is not likely, but I am not sure. Of course in a 556-hp car, I don't care about gas mileage, but a larger tank would mean fewer visits to the gas station.
    Anyone know if this is possible/has been done?
    tinman's Avatar
    Automobile(s): 2014 CTS Vagon 6MT; 2010 CTS Shooting Brake 3.6 DI
    Jul 2006
    Jacksonville, Florida
    5,291
    Re: gas tank replacement
    I can't believe there is a "plug 'n play" gas tank. You will have to fabricate one (we can do that for you). Is there even room for a larger tank? Sounds like a real PITA.
    Jinx is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 CTS-V estate
    Mar 2003
    Oakland, CA
    45
    1,232
    As I understand it, the tank is under the rear seats. Take a look at some photos of the CTS-V undercarriage -- a quick search found one embedded in this thread:
    http://www.cadillacforums.com/forums...ing-cts-v.html
    You can probably find other photos attached to aftermarket exhaust system installation.
    I don't see a bunch of empty space around there for a bigger tank.
    Now if you were determined, perhaps you could add a fuel tank or fuel cell in the spare tire well. I'd be worried about what happens in a rear-end collision, but that is a chunk of unusued (or at least clearable) space.
    Otherwise, remove the rear seats and replace them with another tank
    I must admit I will have a litte range anxiety on future road trips -- not so much the getting-from-A-to-B portion, but the conquer-the-squiggliest-line-on-the-map portion. I just can't go gallivanting off into the wilderness without topping off first.
  5. #4
    tinman's Avatar
    Jul 2006
    5,291
    Remember, the fun is in the getting there.
  6. #5
    Mar 2003
    Oakland, CA
    45
    1,232
    Yeah, but it's nice to be able to get back
  7. #6
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    689
    I just did the Tail of the Dragon and a bunch of back roads. While I did top it off before venturing into no-mans-land, range was never really much of an issue. Just don't start off with under 1/2 a tank. I got about 300mi/tank on the highway and around 200mi/tank when carving the back roads.
    neuronbob and Vsochs like this.
  8. #7
    Dr. Design is offline Cadillac Owners Connoisseur
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    37
    3,395
    Hello,
    Unfortunately the twin bladder under the rear seats doesn't afford you any additional room. How do we know this? Because we had a customer commission us to build a supplemental fuel capacity system that increased his levels by an additional 15 gallons. The system was integrated into the factory OEM fuel system and runs off of high speed relays to alter fuel supply on the fly. So you can run standard gas in one tank and race gas/E85/or more standard gas in the auxiliary tank. The auxiliary tank is mounted in the trunk.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by hoontang View Post
    Hi all
  9. #8
    Club Malibu is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V, White, Manual, Bone stock, no sun-roof
    Feb 2010
    459
    Quote Originally Posted by Dr. Design View Post
    Pics!!!!!!
  10. #9
    Aug 2003
    Design Center
    37
    3,395
    Here you go.
    The gray tank on the hanging from the top left is the integrated fire suppression system. On the right side you will see the blue suppression nozzle tucked behind the trunk liner. Please let us know if there are any questions.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by Club Malibu View Post
    Pics!!!!!!
    Club Malibu likes this.
  11. #10
    May 2013
    Naples, FL
    689
    Awesome. I'd love that but putting it in the cabin of a wagon is probably a bad idea.
    How much $$$$? (You knew that question was coming)
  12. #11
    Aug 2003
    Design Center
    37
    3,395
    Certainly not recommended for a wagon setup that is driven on the street. As for costs, I dont have an accurate number as it was part of a much larger build. But if I had to guess I would say about $5K with all the wiring/fabrication/integration/etc...
    Thanks,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by spearfish25 View Post
  13. #12
    Feb 2010
    459
    What is that silver bar thing on the battery compartment door??
  14. #13
    Aug 2003
    Design Center
    37
    3,395
    That is a custom battery mount holder for his oversized battery. Inside that compartment also houses the high speed relays, dual battery switch, and a couple of other items we keep hidden from plain view. Underneath the spare tire wheel cover there is a custom 5 gallon methanol tank, HLS pump, and his back up battery.
    Thank you,
    Dr. Design
    D3 Cadillac
  15. #14
    Blakester's Avatar
    Blakester is offline Cadillac Owners Fanatic
    Automobile(s): 2011 cts-v wagon
    Dec 2010
    Edmonton Alberta Canada
    67
    264
    Remember the corvette Tanker from the 60's?
  16. #15
    Mar 2003
    Oakland, CA
    45
    1,232
    Things are farther apart in the West. But I shall not be deterred.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
