Rear end symptoms?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 58
Like Tree1Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, Rear end symptoms? in Cadillac CTS-V Series Forum - 2009-2014; So, I think I may have the beginning stages of the dreaded rear end issues. Here's my symptoms, as best ...
    FLTRI's Avatar
    FLTRI is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 V-Wagon & 2012 SRX Premium
    Jul 2011
    Las Vegas, NV
    50
    855
    Rear end symptoms?
    So, I think I may have the beginning stages of the dreaded rear end issues. Here's my symptoms, as best as I can describe without making noises with my mouth...
    Cruise set at 77, smooth asphalt. Kinda sounds like tire noise under light acceleration, mostly goes away under decel. No whining, more of a very slight and I mean very slight, low pitched rubbing or grinding. Kinda like brakes rubbing, maybe. Once I get back on surface streets, and let the auto transmission shift down coming to a stop, I can hear it a little louder, and almost feel it, in 3rd and 2nd gear under decel, as the trans shifts down.
    Like I said, it sounds almost like tire noise, but I'm pretty convinced it's not, as the roadway surface doesn't change the pitch or volume. Also, it pretty much goes away on deceleration, at speed anyway. Also, brisk acceleration doesn't make it worse, and it may make it go away?
    Thoughts and input appreciated.
    2011 auto Vagon, 11,000 miles...
    dullaware is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    51
    4
    Re: Rear end symptoms?
    Mine needed the friction modifier additive. Seems fine now
    BklynEXT is offline Cadillac Owners Member
    Jun 2007
    33
    Mine makes a low speed groaning when making a left turn. Once the vehicle warms up it goes away. I'm bringing it in next week.
  5. #4
    Sep 2008
    51
    4
    My slip says TSB 10-04-20-001E
    Additive PN 88900330
    Main issue was groan in low speed turns when cold, hope this helps
  6. #5
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,629
    Been through this. The additive will not fix it. Maybe temporarily but it's a band aid on an artery. My carrier was just replaced with 46K and had whine and bearing failure when inspected. The whine was most present between 35-40 under constant speed. It would go away under power or when lifting off the gas and coasting. So far, the new one is as quiet as it gets.
  7. #6
    RobF300 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan HIS, 2012 CTS4 coupe- Her's
    Jan 2013
    Amityville, New York
    316
    Sounds Same as mine, they replaced the diff.
  8. #7
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,629
    FLTRI, I would settle for nothing less. Best of luck. Hopefully, your dealer is a good one.
  9. #8
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Automobile(s): All Cadillac vehicles!
    Mar 2010
    Michigan
    11,966
    Quote Originally Posted by BklynEXT View Post
    Hello BklynEXT,
    I apologize for the inconvenience your vehicle is experiencing. I see you are taking the vehicle in next week. If you would like us to stay invoked throughout the process, please private message us and we can continue our interaction next week to ensure your dealer visit goes well. Also we can be contacted for any other concerns or questions you may have.
    Laura M.
    Quote Originally Posted by FLTRI View Post
    Hello FLTRI,
    I am sorry your vehicle is experiencing a rear end issue. Are you going to work with a dealership on this concern? Please feel free to private message us so we can further discuss your issues and help work towards a resolution.
    Laura M.
  10. #9
    FLTRI's Avatar
    Jul 2011
    Las Vegas, NV
    50
    855
    Thanks Guys. I have a service scheduled for Monday. I'm sure I'm gonna get the "Could not duplicate customer concern" answer, but I'm going to have them flush and refill the diff, even if I have to pay for it...
  11. #10
    OldRoadDawg's Avatar
    OldRoadDawg is offline Cadillac Owners Connoisseur
    Automobile(s): Radiant Silver 2009 CTS-V
    Aug 2004
    Spanish Springs
    1,773
    I'm going in Friday and the differential 'low groan noise' is on the list of things to check. Mine has made a noise from Day 1. Did the flush at 5K mark at my expense since they said it was tire noise. Have replaced the tires once since then, sticking with PS2s, AND spoke with a Michelin engineer at a Cadillac Driving lab who said the PS2 tires should not make any noise.
    So I changed the fluid again using AMSoil Extreme duty + the additive (did it myself) and I still have a low level noise at 26K mark.
    Bumper to Bumper runs out next month so I hopefully I won't get the response: "tire noise", "could not duplicate", or "normal".
    More of a minor irritant, since otherwise the V has been nearly flawless. Never had an isolator rattle, wheel click, sunroof squeak, rockin' Recaro or any of the other sundry of complaints.
  12. #11
    RapidRob's Avatar
    RapidRob is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V Black/Black, manual
    Dec 2008
    Seattle area
    1,258
    IMO - personally demo the issue to the SA/SM, or a designated mechanic. Much more difficult for them to use the, 'can not duplicate', excuse afterwards.
    Rob
  13. #12
    Trapspeed's Avatar
    May 2011
    Central Florida
    2,629
    Quote Originally Posted by RapidRob
    Rob
    +1. Exactly.
  14. #13
    spearfish25 is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 CTS-V Wagon, Glacier Blue, Red Brembos, SB wheels
    May 2013
    Naples, FL
    689
    Quote Originally Posted by OldRoadDawg View Post
    The rear diff should be covered under your powertrain warranty which extends beyond the 4 years. Also, anything you've documented with the dealer as an issue, regardless of if they agree in their assessment at the time, is covered after the warranty expires. So if your diff dies after the warranty is gone, you should still be covered even if they 'can't duplicate' your concern when you initially brought it in.
  15. #14
    Xaqtly's Avatar
    Xaqtly is online now Cadillac Owners Connoisseur
    Automobile(s): 2011 WD Vagon 6MT "Unobtainicorn"
    Jan 2012
    Las Vegas, NV
    1,129
    FWIW when mine went I was experiencing both a groaning noise and a high pitched whining noise. I think the key is if it happens on throttle input. The sound will change pitch depending on wheel speed, not gear, and only comes on under throttle input, so if you lift off the noise goes away.
  16. #15
    Mar 2010
    Michigan
    11,966
    OldRoadDawg,
    I want to echo the advice that you should see if it would be possible to have somebody ride with you so that you can point out exactly what you're concerned with. Please don't hesitate to get in contact with us if you would like any further assistance.
    Sarah (Assisting Laura)
    Cadillac Customer Care
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
