Question about tire size
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 5 of 5
2009-2014 Cadillac CTS-V General Discussion Discussion, Question about tire size in Cadillac CTS-V Series Forum - 2009-2014; I've searched but can't find the answer. Sorry if it's been addressed before. Can I put the same size tire ...
    PWE
    PWE is offline Cadillac Owners Member
    Mar 2008
    Rogers, AR
    6
    I've searched but can't find the answer. Sorry if it's been addressed before. Can I put the same size tire on the front that are on the back?
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,062
    Tire? Yes. But you'll want a square set of wheels, too...
    PWE
    Mar 2008
    Rogers, AR
    6
    Re: Question about tire size
    Ok I was pretty tired when I posed this question. So let me give more detail in hopes I can get a serious answer. I wanted to put Michelin run flats on all four corners but I can only find the 35's in run flats. Since there is only 1/2" difference in wheel width between the front and back. I wanted to know if you could put 35's on the front?
  5. #4
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    560
    you probably could, but the sidewall flex / look / and handling of the tires might not be ideal.
    Since these michelin tires look narrow relative to the rim already, getting a slightly wider tire might not be a bad idea - but there's still a bit of a gamble there as you can't expect the tire to handle and grip in the same fashion (even if it is only a 1/2" difference).
    You can check recommended wheel widths for a given tire size on the Michelin website, IIRC they will fit. But any wheel shop will also tell you when you place your order whether or not it appears compatible.
  6. #5
    PWE
    Mar 2008
    Rogers, AR
    6
    Thanks Random84.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
