oil overfill, how serious a problem?
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 5 of 5
2009-2014 Cadillac CTS-V General Discussion Discussion, oil overfill, how serious a problem? in Cadillac CTS-V Series Forum - 2009-2014; Just discovered that the dealer overfilled the oil when they changed out the oil and filter recently. I checked the ...
    baatar is offline Cadillac Owners Member
    Automobile(s): 12 OBM V Wagon
    Oct 2011
    47
    24
    Question oil overfill, how serious a problem?
    Just discovered that the dealer overfilled the oil when they changed out the oil and filter recently. I checked the dipstick and it's well over the full mark. I called and asked them and they said they added 7 quarts and I know our manual says 6. 2012 V wagon.
    In the past I've heard some folks say that the excess oil will just burn off but others say it can cause serious issues. Haven't heard one way or the other about the V2.
    I'm overseas and have the only V that anyone has ever seen here, so the Caddy dealer clearly isn't used to Vs. If it's a serious issue I can take it back to them and try to have them drain some off, but getting there is not easy so if it will burn off on its own I'll probably take that path. Also I don't have any guarantee they won't mess something else up if I take it back to try to remedy it.
    FYI I don't track or drive hard, aside from a few spirited bursts for a few seconds, up on-ramps and such.
    What do you all think?
    Trapspeed's Avatar
    Trapspeed is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    May 2011
    Central Florida
    2,699
    Take it back and have them fix it...or drain some yourself and save the headache.
    Zhariak is offline Cadillac Owners Enthusiast
    Automobile(s): 2015 Escalade ESV Premium, 2013 CTS-V Coupe 6MT
    Feb 2008
    Calgary, AB
    28
    777
    Re: oil overfill, how serious a problem?
    Quote Originally Posted by baatar View Post
    If it was me, and dealer was close. I'd take it in and get them to correct it...
    If I was international with a V and this happened. I'd either find a friend, or I'd do it myself and drain the oil, and refill it with the proper amount.
    If they screwed up and overfilled it, would it be worthwhile checking to make sure they put the proper oil in, in the first place?
  5. #4
    1997BlackETC's Avatar
    1997BlackETC is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Mercedes E63 Amg Station Wagon
    Apr 2006
    Florida
    56
    1,348
    I don't see why people have to overfilling cars so much. Use to drive me nuts when I had my quick lube, I posted fill charts all over the garage, it was a waste of oil and can cause issues. I'd drain off the excess, it's not good being a quart over. You could end up with rear main leakage if driven too much like that.
  6. #5
    Random84's Avatar
    Random84 is offline Cadillac Owners Enthusiast
    Automobile(s): Founder, OBWC
    Feb 2013
    Ohio
    560
    Nothing bad if you're not beating on it.
    Worse thing is extra foamy oil (with poor lubrication) while running, and a blown gasket or seal. If there's no puddle under the car, just drain a quart out, run it for a few minutes, and recheck for proper volume.
    It happens.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
