lost my only keyless fob
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Like Tree3Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, lost my only keyless fob in Cadillac CTS-V Series Forum - 2009-2014; i just lost my only keyless fob to my 09 CTS-V,, car is garaged,, shifter in park,, and ignition switch ...
    kj217's Avatar
    kj217 is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Sep 2012
    99
    car is garaged,, shifter in park,, and ignition switch in off position,,
    i have a mechanical key,,
    if i got a replacement from ebay,, how can i program it?
    neuronbob's Avatar
    neuronbob is online now Cadillac Owners Connoisseur
    Automobile(s): 2013 6MT V wagon, OBM, 2009 silver V sedan (traded)
    Dec 2007
    Cleveland area, OH
    46
    4,351
    Re: lost my only keyless fob
    How do you have a mechanical key without the fob? The key is usually inside the fob. In this case, it's good you separated them as at least you have access to the car even if you can't start it.
    Dealer is best bet to program your fob when it arrives.
    kj217's Avatar
    Sep 2012
    99
    Quote Originally Posted by neuronbob View Post
    i kept the mechanical key back at home,,
    will i have to tow the car to dealer,,car is in park and steering column locked,,
  5. #4
    neuronbob's Avatar
    Dec 2007
    Cleveland area, OH
    46
    4,351
    Problem is that to do it yourself, you need two keys, one already programmed and the new one. There are instructions in the owners manual as well, but that is for a previously learned key IIRC.
  6. #5
    kj217's Avatar
    Sep 2012
    99
    will the dealer be able to program fob without the presence of the car?
  7. #6
    neuronbob's Avatar
    Dec 2007
    Cleveland area, OH
    46
    4,351
    Answer is in the owner's manual, which I didn't have handy this morning. Assuming you are in the US, you need only one key fob.
    And lo, spake the Cadillac CTS owner's manual:
    Quote Originally Posted by 2013 CTS Owner's manual, pages 2-9 and 2-10
    Programming without a Recognized Transmitter
    United States owners are permitted
    to program a new transmitter to their vehicle when a recognized transmitter is not available. The Canadian immobilizer standard
    requires that Canadian owners see their dealer for programming new transmitters when two recognized
    transmitters are not available.
    The procedure requires three 10-minute cycles to complete the process.
    1. Make sure the vehicle is off.
    2. Place the new transmitter into the transmitter pocket with the buttons facing the front of the vehicle. The transmitter pocket is inside the center console storage area between the driver and front passenger seats.
    3. Insert the vehicle key into the key lock cylinder on the driver door.
    4. Turn the key to the unlock position five times within five seconds.
    5. The DIC displays PRESS START CONTROL TO LEARN KEYS.
    6. Press the ignition switch in.
    7. The DIC reads LEARN DELAY ACTIVE WAIT XX MIN and counts down to zero.
    8. The DIC displays PRESS START CONTROL TO LEARN KEYS again.
    9. Press the ignition switch in again.
    10. Repeat Steps 7, 8, and 9.
    11. The DIC reads LEARN DELAY ACTIVE WAIT XX MIN and counts down to zero.
    12. A beep sounds and the DIC reads READY TO LEARN ELECTRONIC KEY # X. All previously known transmitter programming has been erased.
    13. A beep sounds once programming is complete. The DIC displays READY TO LEARN ELECTRONIC
    KEY # 2.
    To program additional transmitters, insert each transmitter in the pocket until a beep is heard and the DIC advances to the next electronic key number. Up to four transmitters can be programmed. The DIC displays MAXIMUM # ELECTRONIC KEYS LEARNED and exits the programming mode.
    14. Press the ignition control knob if programming is complete.
    15. Press (unlock) on each newly programmed transmitter to complete the process.
    Should be similar for your 2009. Edit: I just looked at my old 2009 owner's manual and the process is the same. No dealer needed. You just need a new fob.
  8. #7
    kj217's Avatar
    Sep 2012
    99
    thanks a lot,, my car was originally sold in saudi arabia,, neither US or Canada,,
  9. #8
    Jinx is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 CTS-V estate
    Mar 2003
    Oakland, CA
    46
    1,232
    Does "press the ignition switch in" mean turn it to a particular position, or does it literally depress toward the steering column?
  10. #9
    kj217's Avatar
    Sep 2012
    99
    Quote Originally Posted by Jinx View Post
    toward the column,,
  11. #10
    Mongopush is offline Cadillac Owners Member
    Automobile(s): 2006 CTS V
    Mar 2013
    39
    93
    BTW, here is a link for the manual, just bookmark it.You can click in the menu and will take you right to the pages needed. Saved me a lot of trips to the glovebox .. http://www.cadillac.com/content/dam/...ers_manual.pdf
  12. #11
    kj217's Avatar
    Sep 2012
    99
    ordered used fob off ebay,, waited 15 days to have delivered,, then i followed the instuctions carefully,, repeated the whole thing 4 times,, wasted more than 2 hours and i couldn't have it done,,
    after the deadly 3 10min cycles it shoews ready to learn key #1 and it stucks there for few minutes before abortion,,
    tested the fob and battery,, all good,,
    please,, help,,
  13. #12
    kwilson is offline Cadillac Owners Member
    Automobile(s): 2013 CTS-V Coupe
    Aug 2012
    Edmond, OK
    36
    43
    It's a used key off eBay.....you sure it's still works like it should???
  14. #13
    kj217's Avatar
    Sep 2012
    99
    Quote Originally Posted by kwilson View Post
    used off ebay,, i guess i got the wrong key as this doesn't have the hidden key blade,,
  15. #14
    Aug 2012
    Edmond, OK
    36
    43
    Man....your driving a V. Go buy a new key fob from the dealer!!!!
    RapidRob, RapidRob, bbang and 2 others like this.
  16. #15
    neuronbob's Avatar
    Dec 2007
    Cleveland area, OH
    46
    4,351
    Yup, it's dealer time. That'll be the fastest way.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
