High speed wobble
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 6 of 6
2009-2014 Cadillac CTS-V General Discussion Discussion, High speed wobble in Cadillac CTS-V Series Forum - 2009-2014; Need some help. I was at the track today and I experienced high speed wobble coming from the rear end. ...
    Bstubbs is offline Cadillac Owners Member
    Automobile(s): None
    Jun 2012
    1
    High speed wobble
    Need some help. I was at the track today and I experienced high speed wobble coming from the rear end. I was running my pilot sports at about 26lbs of pressure. Funny thing is I have actually gone faster on the highway very recently with no wobble. I was also in sport mode on the suspension and comp mode on the traction control. Any clue what this could be?
    jzchen is offline Cadillac Owners Fanatic
    Automobile(s): '85 Sedan de Ville, '10 CTS-V
    Sep 2009
    Arcadia, CA
    39
    334
    Re: High speed wobble
    Usually you need higher pressure for speeds over 100 mph. 26 lbs is 6 lbs lower than recommended for normal (<100 mph) conditions. I would check for tire damage...
    RGaret's Avatar
    RGaret is offline Cadillac Owners Fanatic
    Automobile(s): None
    Mar 2009
    New York
    44
    491
    Quote Originally Posted by jzchen
    What happens if you keep the higher pressure in the tire all the time. Sometimes I exceed 100 for brief periods only.
  5. #4
    McGuffy's Avatar
    McGuffy is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    Jul 2012
    168
    The car was designed to drive that fast. 32psi is the way to go unless you're under some extreme (track) conditions.
  6. #5
    ClarkkentCTSV is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Thunder gray CTS V
    Jun 2012
    South Florida
    32
    215
    Did you refill the tire to proper recommendation? I'm sure it was the low tire pressure in the tires. Will help with traction, but get wobbly at high speeds.
  7. #6
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,140
    I would check the lugs just to be sure.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
