Vibration at highway speeds
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 12 of 12
2009-2014 Cadillac CTS-V General Discussion Discussion, Vibration at highway speeds in Cadillac CTS-V Series Forum - 2009-2014; 2012 Wagon Auto Purchased new. 2500 miles on now. Changed stock tires to Bridgestone Potenza RE970AS Pole Position (245/45-19 98W ...
    team_car is offline Cadillac Owners Member
    Automobile(s): NONE (YET)
    Jul 2012
    35
    29
    2012 Wagon Auto
    Changed stock tires to Bridgestone Potenza RE970AS Pole Position (245/45-19 98W and 275/40-19 101W).
    Everything else is stock.
    About 8-900 miles since the change.
    At highway speeds (say 55-70) i'm getting a pretty significant vibration. I can feel it through the pedals, seat and steering wheel. I can see and feel the headrest of the (empty) passenger seat vibrating.
    Seems to be there at all those speeds, at any revs, and at any throttle.
    TPMS reports good, even tire pressure (have not checked manually yet).
    Tried a few road surfaces and it is similar on them all.
    No particular noise and nothing visual on the wheels/tires when stationary.
    Any ideas? Anything I should check/do?
    McGuffy's Avatar
    McGuffy is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V Coupe
    Jul 2012
    168
    Re: Vibration at highway speeds
    Either the wheels weren't properly balanced, or you need hub centric rings to get them centered on the lugs properly.
    CVP33's Avatar
    CVP33 is offline Cadillac Owners Master
    Automobile(s): '04V, '05V, '06SRT8, '10V sedan, '13ZL1 vert, '12 V coupe
    Feb 2004
    mockingbigjimsville, NC
    48
    5,951
    I'll bet you threw a wheel weight. Happened to me and show similar symptoms. Thought there was no way because it was isolated to certain speeds.......look the wheels over to see if you can see where some weights were glued maybe. Usually on our wheels they either 'glue' em to the inside or clamp them on the back side.
  5. #4
    baabootoo's Avatar
    baabootoo is online now Cadillac Owners Connoisseur
    Automobile(s): Blue/Titanium 2009 V Auto
    May 2010
    Racine, WI
    3,426
    Any other modifications?
  6. #5
    Dr. Design is offline Cadillac Owners Connoisseur
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    37
    3,388
    +1 on chucking a wheel weight. Have them re-balanced and if your tire place a road force balancer, might as well have them do that too.
    Thanks,
    Dr. Design
    D3 Cadillac
  7. #6
    Jul 2012
    35
    29
    Quote Originally Posted by baabootoo View Post
    Nope - all stock.
    Tire installer is going to double check balance.
  8. #7
    luderchris is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Sep 2009
    64
    Quote Originally Posted by team_car View Post
    Bent wheel.
  9. #8
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan A6, 730 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,100
    +2 On balancing the tires...
  10. #9
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    49,826
    Quote Originally Posted by luderchris
    Bent wheel.
    +2 on bent wheel.
    Quote Originally Posted by V locity
    What if they're not POS2s? lol...
  11. #10
    Jul 2012
    35
    29
    Tire guy came out and said that 3 wheels were off balance and one of the road force readings was really high. Can't test drive right now but hopefully it's fixed.
  12. #11
    DiamondWhtV is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS-V
    Feb 2010
    64
    364
    If you still have the vibration, like I did...then suspect front wheel bearings. Ended up replacing both front on mine over a span of several months trying to get rid of the vibration after tire swap out, balance etc.
  13. #12
    Jul 2012
    35
    29
    Definitely better on the way home. Will see how it goes for the next few weeks. Thanks for the suggestions and tips.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
