New Camaro ZL1 faster than CTS-V Coupe? - Page 2
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Like Tree15Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, New Camaro ZL1 faster than CTS-V Coupe? in Cadillac CTS-V Series Forum - 2009-2014; Magazine times are often not real world. Meaning some are unrealistically faster than what a common Joe will get on ...
  1. #16
    larry arizona is offline Cadillac Owners Connoisseur
    Automobile(s): 10 V 4DR,6M,Blk,2.55,airaid,160t,W4M HX & tune Eibachs
    Feb 2012
    Metro Detroit
    43
    1,347
    Re: New Camaro ZL1 faster than CTS-V Coupe?
    Magazine times are often not real world. Meaning some are unrealistically faster than what a common Joe will get on the street. I am not saying that there are not great drivers on this forum that can do as well as the mag drivers, just saying its rare.
    Find one race one and let us know how it goes. Real World.
  2. #17
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,090
    Always interesting for me to read everyone's thoughts and opinions on the inevitable CTS-V vs. ZL1 comparisons. I certainly am happy that I chose the V rather than wait for the ZL1. As others have said repeatedly, comparable performance, but 2 very different animals...
    Based on this, I found the following threads on Camaro5 interesting and thought others here might as well:
    1) GM engineers were able to get both the A6 and M6 ZL1 into the 11's this spring. http://www.camaro5.com/forums/showthread.php?t=221434
    2) Looks like the 1st bone stock A6 broke into the 11's as well about a week ago. http://www.camaro5.com/forums/showthread.php?t=252961
    3) ...with a manual not far behind at 12.07 the week before. http://www.camaro5.com/forums/showthread.php?t=251325 Cooler weather ought to bring times down a bit more over the next little while.
    4) As well there is a website noted in one of those threads that reinforces some of the techniques in launching/shifting for M6 drivers that will help them get the best times at the strip. http://www.rangeracceleration.com/Launch_Tips.html
    Best regards,
    Elie
  3. #18
    flatrockguy is online now Cadillac Owners Fanatic
    Automobile(s): 2012 Raven V Sedan, M6, Graphite Rims, Yellow Brembos
    Jan 2012
    Metro Detroit
    45
    309
    Doesn't the ZL1 have launch control as well, which should help quite a bit over our V's..
  4. #19
    V-swagon's Avatar
    V-swagon is offline Cadillac Owners Fanatic
    Automobile(s): 1985 Fleetwood Brougham, 2002 DTS, 2011 CTS-V wagon
    Aug 2012
    Ohio
    37
    161
    Has anybody considered that the cars tested could have been factory freaks? I'm sure the drivers of the cars tested may have different levels of expertise. Also, there might just be slight differences in the casting of the heads or tolerance of other components to make the difference of the cars being quicker than the other in various tests. In my opinion, any car coming off the showroom floor running low 12's or quicker is just awesome. Old pushrod technology mated up with modern engineering, semi ok mpg's, and high horsepower is the best combination. Just saying.
  5. #20
    Tedboss1's Avatar
    Tedboss1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTSV Auto
    Jun 2009
    Montreal
    926
    Each car magazine is using different method of testing cars.
    For example this is how Car and Driver is doing the acceleration testing:
    "To eliminate the effects of weather on performance, we employ proprietary empirical correction factors to adjust all results to dry air at 14.7 psi and 60 degrees Fahrenheit using PsyCalc 98 software (www.linric.com) to crunch the weather data. Since cars run best in cold dense air, our correction tends to add time to results generated in low-temperature, high-pressure conditions and subtract time from hot-weather, low-pressure tests. To cancel the effects of the wind, all acceleration tests are run in both directions; the best runs in each direction are then averaged.
    Other car magazines simply report best times not average times with correction factors.
    So you can see that it is hard to do realistic comparison when cars are tested under different condition by different drivers.
  6. #21
    LyndellWiggins's Avatar
    LyndellWiggins is offline Cadillac Owners Member
    Automobile(s): 2013 Cadillac CTS-V Coupe
    Sep 2012
    44
    Tedboss1: I did not know that. That is very interesting. And kinda misleading?
  7. #22
    B T Williams is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan
    Aug 2010
    Naples, Florida
    62
    Quote Originally Posted by B T Williams View Post
    My 2011 CTS-V sedan (automatic transmission) in absolutely pure stock form (including Michelin PS2's) ran 12.02@ 118+ MPH, 12.03 @ 118+ MPH, 12.11 @ 117+ MPH and 12.11 @ 117+ MPH on PBIR's quarter mile track earlier this year on a less than ideal day, weather wise (85 to 91 degrees / 1500 to 1900 feet Density Altitude). That's quicker than what Chevrolet engineers could get both a manual and an automatic transmission Camaro ZL1 to run on stock tires and a cool day on a U-Tube video I watched a while back. Apparently the mild horsepower (+24) and weight (-100 pounds) advantage that ZL1's have over CtS-V's is not significant enough to make ZL1's faster, acceleration wise, than CTS-V's.
    As GARFIN notes in his post, GM engineers did indeed get both the manual and automatic transmission ZL1's into the 11.90's after they installed drag radials. (Watch the video closely. The accompanying text on a Camaro forum incorrectly concludes that the 11.90 runs were on stock tires.) With their stock Goodyear tires, neither of ZL1's ran in the 11's and neither of them, without or with drag radials, ran over 117 MPH.
    Note that the performance section of this forum indicates that stock CTS-V's have also run 11's in the quarter mile.
    That said, as an experienced drag racer, I can tell you that the most important statistic regarding quarter mile performance potential of a car is MPH, not ET. All of the test data that I've seen for stock CTS-V's indicate quarter mile MPH from a low of 115 MPH to a high of 119 MPH. Likewise, all of the test data that I've seen for stock ZL1's also indicate quarter mile MPH from a low of 115 MPH to a high of 119 MPH. The MPH data clearly indicate that the performance capability of stock CTS-V's and stock ZL1's is identical.
  8. #23
    Jinx is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 CTS-V estate
    Mar 2003
    Oakland, CA
    45
    1,230
    The concern here is nothing compared to the butt-hurt some base/GS Corvette owners have expressed about the ZL1.
    At the end of the day, if you're all about the street (bench) race, you should be driving a Camaro, unapolagetically -- that's what it's for.
    If you want the non-numeric benefits of Cadillac or Corvette ownership, you shouldn't fret over fractional stopwatch advantages of the knife-edge niche version of a ponycar.
    And while it sure would be nice for mechanical improvements added to the newer ZL1 to be applied back to the earlier-program CTS-V, the numbers probably don't support the investment.
    The CTS-V shouldn't be any less delicious just because Camaro went to the same gym. I certainly don't see it as any less desirable. Especially not after reading this thread.
    BTW, are there any third-party solutions for cooling the CTS-V rear diff?
  9. #24
    TiredIronGRB's Avatar
    TiredIronGRB is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan (V-Lab Car)
    Dec 2012
    Church Hill, TN
    50
    57
    I looked at a new ZL1 today while my V-sedan was being serviced, opened the hood and really looked it over good and I was surprised that the fit and finish wasn't any better than it was. There was over-spray on the hood hardware, some of the shields and covers weren't aligned very good and the exhaust tips weren't lined up. There was also a convertible SS and it appeared flawless but if I had to keep them I wouldn't take both of them for my V.
    brian-nicola and brian-nicola like this.
  10. #25
    Rule12b's Avatar
    Rule12b is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V Sedan
    Dec 2010
    Los Angeles
    544
    Quote Originally Posted by Jinx View Post
    There are. Check the performance threads. A group buy is up for a new option, and D3 sells one as well (I run it).
  11. #26
    Mar 2003
    Oakland, CA
    45
    1,230
    Thanks. I haven't settled on a V yet, but I'm getting closer, and this helps.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
