GM found a fix for the supercharger rattle! - Page 11
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 11 of 37 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 151 to 165 of 548
Like Tree52Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, GM found a fix for the supercharger rattle! in Cadillac CTS-V Series Forum - 2009-2014; Every car has something that can be improved. The fact that we are complaining about a slight marble sound at ...
  1. #151
    HeavyH20's Avatar
    HeavyH20 is offline Cadillac Owners Fanatic
    Automobile(s): Red 09 CTS-V, Silver 06 STS-V, White 08 SRX
    Feb 2008
    Minneapolis, MN
    48
    472
    Every car has something that can be improved. The fact that we are complaining about a slight marble sound at idle that can be remedied for $65 and two hours of shop time attests to how well these cars are designed and built. Night and day to my old 05 V with the glass rear and axles. My buddy and I went to the new car show (we both have 09 CTS-V's) and there is nothing I saw that drove me to trade it for under $100k aside from another CTS-V. These cars are that good.
  2. #152
    Reeper is offline Cadillac Owners Member
    Automobile(s): 2010 CTSV 2007 Escalade ESV
    Feb 2012
    Pembroke Pines, Fl.
    45
    75
    Re: GM found a fix for the supercharger rattle!
    My 2010 CTSV has the noise too!
    So, I just ordered an isolator bushing from Lingenfelter and should be here next week.
  3. #153
    MReiland's Avatar
    MReiland is offline Cadillac Owners Enthusiast
    Automobile(s): 13 Volt, 2008 Outlook XR (05 CTS Blk/Blk Traded-in)
    Apr 2004
    Milwaukee, WI
    41
    662
    Instead of saying that you need to tell GM, you actually probably need to tell EATON!!!! I believe they designed it and service any that have problems....
  4. #154
    GMX322V S/C's Avatar
    GMX322V S/C is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V, 2009 535i
    Dec 2008
    SoCal
    1,836
    Eaton certainly is the OEM, but the buck stops with GM as the integrator. As we blast GM, GM should be relaying some of that blast over to Eaton and work out a way to retro an improved isolator in a warranty safe manner. Somehow they have to get over it being a "non-serviceable part," when it very clearly CAN be serviced in the field by competent mechanics.
  5. #155
    theamcguy's Avatar
    theamcguy is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Wagon
    Sep 2010
    Fayetteville, NC
    61
    90
    Quote Originally Posted by GMX322V S/C View Post
    It is not GM's or Eatons fault when a part is functioning as designed. GM tests a lot of cars and engines before it gets released to production. I am sure some of them made the noise that some owners are now experiencing. But there is a reason some engineer put that spring in there. Usually a spring on a rotating assembly is there to absorb shock. Kind of like the vibration dampener on the front of the crankshaft. Could be that the noise in some instances is the trade off to making the supercharger last longer. I am quite sure GM tested the supercharger both with and without the solid isolator and something they saw made them choose the spring loaded isolator over the solid isolator, the trade off is the noise. Some have said that the new ZL1 will have the solid isolator, but what else did they change that allows them to use a solid isolator and still reduce the warranty repairs? Parts are designed not only to function but also to survive the warranty period. A nice quiet part that fails before the warranty is up causes as much problem as the noise is now. The "fix" is the solid isolator that voids the warranty. The choice is yours, not GM's or Eaton's.
  6. #156
    Dec 2008
    SoCal
    1,836
    Quote Originally Posted by theamcguy View Post
    It is not GM's or Eatons fault when a part is functioning as designed...Could be that the noise in some instances is the trade off to making the supercharger last longer...
    This has become circular, so I'll drop it after re-quoting one last time:
    Quote Originally Posted by Ed Piatek
    The torsional isolator is used in the CTSv LSA engine to isolate potential gear rattle noise during idle...
    It fails by inducing a rattle of it's own. Longevity is not mentioned.
    It's ironic that they went through all the trouble to develop and implement other NVH reducing measures such as engine covers, intake tract tuning, acoustic dampening of the supercharger lid, hypereutectic pistons, mild lift cam, cast iron manifolds, and so on, just to make it quiet enough so that the isolator coupler rattle stands out all that much more.
  7. #157
    352
    352 is offline Cadillac Owners Member
    Automobile(s): DTS, STS V
    Mar 2012
    10
    I cannot ask the dealer to install the isolaror which begs the question who can I ask to do this work in the Washington, DC area without boggering-up the job and the new car warranty?
    Oh, by the by, I sent via Cadillac's website an email addressing the isolator issue. Furthermore, I told them that their response would determine whether I purchase a V.
  8. #158
    rjoffe is online now Cadillac Owners Connoisseur
    Jul 2005
    1,629
    Behe performance
  9. #159
    Feb 2012
    Pembroke Pines, Fl.
    45
    75
    so let me ask this question, with all of the pictures of damaged input shafts with the spring loaded piece and with varying mileage (as low as a thousand miles to 20-40k miles) would the damage be more or less severe with a solid bushing? Because if the wear goes unnoticed there will be lots of SC's being hurt (hopefully no motorseither). If anyone can confirm LESS wear on the input shaft (of SC) please chime in and show GM some proof so we have more ammo for a warranteed fix!
  10. #160
    Dec 2008
    SoCal
    1,836
    They've said that the wear is as much of a non-issue (sealed chamber, will only wear so far, spring is intentionally harder than the shaft) as the noise...
  11. #161
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Automobile(s): All Cadillac vehicles!
    Mar 2010
    Michigan
    12,077
    Quote Originally Posted by valdeztkeCTSV View Post
    Just wanted to let everyone know that I added a video to my previous blog posts concerning the rattle. www.dcautogeek.com
    Hopefully for those that don't have the rattling yet you can hear what it is some of us are experiencing.
    Katie please feel free to share this video and blog post with the folks at Cadillac thank you.
    valdeztkeCTSV: Thank you very much for sharing and pointing me in the direction of your blog and video. I have made a note of it on the list!
    Best,
    Katie
  12. #162
    352
    Mar 2012
    10
    If Cadillac would agree to install Lingenfelter's plastic isolator under the new vehicle warranty, I would purchase a new V. GM are you listening?
  13. #163
    352
    Mar 2012
    10
    Does anybody know whether GM will fix the V's supercharger rattle for the MY 2013 cars?
  14. #164
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    14,013
    we don't think so since apparently they claim there's nothing to fix
    you'll probably just have to wait and see
  15. #165
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    Quote Originally Posted by 352 View Post
    realistically, the V is entering it's final MY. If GM had enough feedback to warrant a fix, it would have happened by now.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
