Escort Passport 9500ix Radar detector Hardwire Install How-to Thread
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 30
Like Tree1Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, Escort Passport 9500ix Radar detector Hardwire Install How-to Thread in Cadillac CTS-V Series Forum - 2009-2014; Hi all, Since I've been using the resources of the forum here I decided to pay back some of the ...
    wetcoast's Avatar
    wetcoast is offline Cadillac Owners Fanatic
    Automobile(s): 2009 CTS-V Manual
    Jul 2010
    Langley, BC
    154
    Lightbulb Escort Passport 9500ix Radar detector Hardwire Install How-to Thread
    Hi all,
    Since I've been using the resources of the forum here I decided to pay back some of the good information I've discovered in my install.
    I purchased a Escort Passport 9500ix because it had great reviews and the features I really wanted (i.e. false alarm location memory, mark trap zones, etc)
    The coiled wire to the cigarette lighter was not cutting it because it was so fugly and the invisicord wasn't an option because I wanted to retain the alarm and power lights and the mute/memorize button that the Passport detectors have.
    Let me first say that I took all the pics with my phone because that's all I had at the time. If it's not clear enough once you start tearing into it just let me know.
    Oh and if you melt your car down to a bubbling steaming pile, lose my contact info.
    1. I started by purchasing the Direct Wire SmartCord Blue. It's really easy to wire since there's only a ground wire and a power wire. I just connected the ground wire to the screw that holds the OBD II connector in place under the driver side dash.
    2. I had to find a switched ignition feed because apparently in 2009 they cigarette lighter wasn't. I asked around for another ignition source but all i heard back was along the driver door sill and I wasn't very interested in running a wire all the way up when I figured there had to be Ignition power in the dash. After a bit of poking around in the service manual I struck pay dirt.
    Circuit 539 passes through the cabin connectors on the drivers dash panel that's exposed when the door is open.
    3. The connector in the side of the dash with the circuit 539 Ignition is X200 (the bottom connector in relation to the other two). The pin on X200 is pin 1 of the 20 pins and the wire is pink. It's part of the Misc Ign circuit which is fused separately from the airbag circuit.
    DO NOT INSTALL ANY DEVICE TO THIS CIRCUIT THAT DRAWS MORE THAN 1A BECAUSE THERE IS OTHER MODULES IN THE CAR THAT ARE ON THIS CIRCUIT. IF YOU NEED MORE SWITCHED POWER RUN A RELAY OF CIRCUIT 539 AND DRAW A DEDICATED POWER SOURCE FROM THE BATTERY THROUGH A FUSE. IF YOU DON'T UNDERSTAND WHAT I JUST SAID DON'T EVEN TRY.
    4. I decided to mount the Smartcord controls in the tiny storage pocket in the radio/HVAC controls panel so I could hide the LED's and button when not in use. I first dremeled a hole in the back of the pocket for the wires to route through.
    Front
    Back
    5. Then I drilled a hole 1" fromthe front lip of the pocket and 7/8" from the left side of the pocket just large enough to fit the single screw that is in the smartcord remote.
    6. I needed a bit longer screw than the single one that comes in the smartcord remote. I just found one approximately the same diameter and thread pitch and ground it to 1/8" longer than the original.
    7. Then I fed the wires through the hole in the back and assembled the smartcord remote with the longer screw in the pocket.
    Door closed
    8. The rest is pretty simple. Just run the smartcord plug (RJ-11) along the dash and up the drivers 'A' pillar by removing the pillar cover. Neatly tuck the cord in along the head liner and down the rear view mirror harness. Plug in and go.
    Easy stuff. The thing that took me the longest was climatizing to the service manual schematics. They leave a lot to be desired compared to everything else I've seen.
    Tmer is offline Cadillac Owners Member
    Automobile(s): '11 V wagon, '09 G37x sedan, '03 G35 coupe
    Jun 2011
    Boston
    6
    Re: Escort Passport 9500ix Radar detector Hardwire Install How-to Thread
    Nice install and write up! How is the detector mounted?
    wetcoast's Avatar
    Jul 2010
    Langley, BC
    154
    I actually just used the suction cups that came with with the detector and mounted it right under the mirror. It doesn't take up much of the view. For windshield mount detectors you need to have them fairly unobstructed to be most effective.
  5. #4
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    payback indeed! Thanks for the writeup!
  6. #5
    Prof's Avatar
    Prof is offline Cadillac Owners Enthusiast
    Nov 2008
    Wadsworth, IL
    824
    Nice work.
    I faced the constant hot issue of the power port in the dash by rewiring it at the fuse box so that it would be a switched circuit.
  7. #6
    cdog533's Avatar
    cdog533 is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V
    Apr 2004
    539
    I have an invisicord. Why didn't that option work? I know it doesn't work for Escort Live, but what you did actually will, which is big for guys wanting Escort Live.
  8. #7
    wetcoast's Avatar
    Jul 2010
    Langley, BC
    154
    Quote Originally Posted by cdog533 View Post
    Invisicord didn't retain the button for muting and remembering false alarms. Yes the way I did it will work for Escort Live but since I have a Blackberry 9900 it doesn't really matter to me.
  9. #8
    TexasCTSV is offline Cadillac Owners Member
    Automobile(s): 2009 CTSV
    Sep 2011
    31
    51
    Quote Originally Posted by wetcoast View Post
    Does the 9500ix not have a mute/memory button on the unit itself? I know my 8500 x50 has a mute button there. This is a nice option for those wanting to use Escort Live, however.
  10. #9
    wetcoast's Avatar
    Jul 2010
    Langley, BC
    154
    Quote Originally Posted by TexasCTSV View Post
    It does have a mute/memory button right on the unit but it's not convenient to see or press the buttons because I have it tucked right up under the rear view mirror.
  11. #10
    keithsm2 is offline Cadillac Owners Fanatic
    Automobile(s): 05' Stealth Gray V, UUC STS, 11 V Coupe, W. Diamond, B&B Ex
    Dec 2007
    Texas
    51
    413
    only thing you lose using the invisicord is the mute function....the memory still works....
    Problem i have with it mounted to the mirror is false Laser Alerts.....mostly cured by turning down the contrast or briteness on the nav. system... Auto brightness on the Nav system still sets off the laser detection... and sometimes the Day setting.....any other cures would be appreciated.
    Keith
  12. #11
    wetcoast's Avatar
    Jul 2010
    Langley, BC
    154
    Quote Originally Posted by keithsm2 View Post
    Keith
    Ya, i didn't say it didn't work. The invisicord removes the convenient location for the button.
    I've never seen the problem you're seeing with the NAV brightness causing a false alarm. How do you have it mounted?
  13. #12
    Dec 2007
    Texas
    51
    413
    Mine is mounted to the mirror...forgot who makes the mount....but its right under the mirror.....Level..( actually touches the mirror)
    So...i guess the brightness from nav screen messes with it......( crazy i think....)....but i have verified it many times.
  14. #13
    Sep 2011
    31
    51
    Sounds like a Blendmount? I want one of those, but they are 80 bucks...Maybe put it on my Christmas list for my wife to get me.
  15. #14
    Dec 2007
    Texas
    51
    413
    http://www.cadillacforums.com/forums...40s-radar.html
    This thread mentions the people i got my mount from....they are a little updated now....( Some country craft place...? hahah) looks like husband needed something to manufacture.....( i ve had two now....one on my 05 and now one on the coupe.....I like them )......no falling off the windshield.....just bend the part that goes in the back of the detector so that it fits tight against mirror....or maybe a small piece of velcro....( to avoid vibration)
    Keith
    PS....I enjoyed the write up....Always appreciated peoples time to do these things.
  16. #15
    CTS-V Dragon Wagon's Avatar
    CTS-V Dragon Wagon is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Wagon
    Dec 2011
    141
    So the BlendMount does work with a V2 CTS-V, with a 9500IX?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
