Stant InStant Fill Cap
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
2009-2014 Cadillac CTS-V General Discussion Discussion, Stant InStant Fill Cap in Cadillac CTS-V Series Forum - 2009-2014; While doing my weekly check for V parts on Summit's website, I found that Stant makes a gas tank cap ...
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Blue/Titanium 2009 V Auto
    May 2010
    Racine, WI
    3,467
    While doing my weekly check for V parts on Summit's website, I found that Stant makes a gas tank cap that stays in place. It has a self-sealing opening so you no longer have to take the cap off and let it dangle! Kind of like with NASCAR. I know there have been codes with a loose cap, but I ordered it anyway to give it a try. It also says it's scanner safe. If it works, it will be a time saver.
    cbloveday's Avatar
    cbloveday is offline Cadillac Owners Connoisseur
    Dec 2007
    4,151
    Re: Stant InStant Fill Cap
    Interesting. Let me know if it throws a code. It says it is OBDII compliant but unless it forms a seal, it may trigger a code. I was under the impression that the system must be under pressure. Also do you have link to the specific part number. I looked quickly and did not see one that is specifically for the cadillac cts-v.
    MReiland's Avatar
    MReiland is offline Cadillac Owners Enthusiast
    Automobile(s): 13 Volt, 2008 Outlook XR (05 CTS Blk/Blk Traded-in)
    Apr 2004
    Milwaukee, WI
    41
    662
    I think Ford uses a similar cap on many of their vehicles that is Emissions Compatible
    http://www.insideline.com/ford/ford-...e-gas-cap.html
  5. #4
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,467
    I just got my third tankful, and no codes or problems yet. It's even better because our tanks don't have that inner flap either. Just like at the racetrack!
  6. #5
    cbloveday's Avatar
    Dec 2007
    4,151
    Great find!
    Which part number is associated with our vehicles?
  7. #6
    CTSV4now is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS-V
    Oct 2009
    Houston
    413
    I have timed myself now and it only takes 2.6 seconds to remove the cap and another 3 seconds to grab the cap and screw it back on. Are you guys in that much of a hurry?
  8. #7
    OldRoadDawg's Avatar
    OldRoadDawg is offline Cadillac Owners Connoisseur
    Automobile(s): Radiant Silver 2009 CTS-V
    Aug 2004
    Spanish Springs
    1,792
    Quote Originally Posted by cbloveday View Post
    Great find!
    I think this is the one........
    Fill Cap
  9. #8
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,467
    Yep, that's it; 41004. It isn't the time really, it's the pain of that cap flopping around and twisting the cord. Have you timed yourself in -28F weather yet? It made me so mad on my Pontiac I pulled it off one day at a gas station. That cord stretched to about a foot, and snapped off. It puctured my skin slightly through gloves! this time, I gently removed it from the back.
  10. #9
    Oct 2009
    Houston
    413
    Okay, my times are biased since I don't get that much cold weather in Houston.
  11. #10
    Titaniumseeker is offline Performance Enthusiast
    Automobile(s): 2009 CTS, 2009 CTS-V, 2012 CLS550
    Feb 2009
    Maryland
    479
    You guys do know that the gas cap can rest on the gas door so that it does not hang and dangle, right? That is what the indentation on the inner gas door is for.
  12. #11
    cbloveday's Avatar
    Dec 2007
    4,151
    I am aware of that.
  13. #12
    mrl859's Avatar
    mrl859 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 White SRX Performance/2011 Radiant Silver CTS-V Coupe
    Feb 2011
    Home
    411
    Does anyone make a locking gas cap?
  14. #13
    09V
    09V is offline Cadillac Owners Fanatic
    Automobile(s): 09 CTS V
    Sep 2009
    226
    I know this may be overthinking things, but with everyday use and frequent inclement weather wouldn't you be concerned with moisture getting into the tank. It seems like the vapor in the tank is what keeps the valve closed presumably forming an air tight seal???? However, if I don't get the car washed real frequently I can notice a lot of dirt and crap in/on and around the cap that could wind up in your tank as well. Just a thought... or 4.
  15. #14
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,467
    Not much will get in this thing. The flapper is very tight and sealed well. If it were loose, I'd get an SES light, right?
  16. #15
    Nutz's Avatar
    Nutz is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS-V a tuxedo with a jetpack!
    Oct 2007
    Northeast Ohio hammer down
    47
    2,455
    Quote Originally Posted by zero26039 View Post
    what is the weight difference between this and the stock cap?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
