How does the V work at the track? - Page 4
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 82
Like Tree1Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, How does the V work at the track? in Cadillac CTS-V Series Forum - 2009-2014; Originally Posted by garfin I definitely agree! So... I gotta ask... just out of curiosity... is that unopened can metal ...
  1. #46
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    50,276
    Re: How does the V work at the track?
    Quote Originally Posted by garfin View Post
    I definitely agree! So... I gotta ask... just out of curiosity... is that unopened can metal or plastic? Given the vintage, I'm guessin' that it's metal. I'm definitetly thinkin' that you and I are from the same focus and generation... and I don't trust the plastic bottles that we get now. The old metal cans were great for preventing moisture osmosis, the plastic bottles, not so much.
    Bottom line is that we gotta swap our brake fluid at least at the beginning of the season, and maybe 1/2 way through the season as well, depending on how often we track our cars. Maybe even after each event, depending on how hard we are on the brakes.
    Best regards,
    Elie
    Metal can, mah man...
  2. #47
    garfin's Avatar
    garfin is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS-V 6MN Thunder Gray; 07 SRX AWD N*;
    Apr 2006
    Roches Point, Ontario, Canada
    1,117
    Quote Originally Posted by thebigjimsho View Post
    Thanks! Thought that might be the case... just not too sure if I'd be usin' the stuff in that particular can at this stage of the game.. LOL!
    Best regards,
    Elie
  3. #48
    dvandentop's Avatar
    dvandentop is offline Cadillac Owners Connoisseur
    Automobile(s): 09 Silver V 06 Silver Z06
    Jul 2005
    Sioux Falls SD
    33
    1,917
    castrol srf in my vette here, only have to worry about bleeding once a year.
  4. #49
    baabootoo's Avatar
    baabootoo is offline Cadillac Owners Connoisseur
    Automobile(s): Blue/Titanium 2009 V Auto
    May 2010
    Racine, WI
    3,497
    I just got back from Road America Friday and had no issues at all; other than stalling from running low on gas! My differential never got above 210, but it was in the 50s that day too. The brakes worked fine through 4 hard sessions. I started the tires at 43F/40R COLD but I'm sure they went up a bit from the day heating up. After the last lapping session they were at 53F/48R HOT. I used to get some slide at 40/40 COLD, so I'll try 44/44 next time. They stuck like glue too! I had a C5 Corvette, who was behind me tell me that I lifted the RR tire off the ground on the first right hander after the long 3000' front straight. He said it went up more than once and had no doubts. Next up for me is to lower that high back end and a heavier anti-sway bar. That is the ONLY thing that bothered me all day; and the $8.40/gallon of gas!!!! These cars are solid for running hard!
  5. #50
    CruzanTom is offline Cadillac Owners Member
    Automobile(s): 09 CTS-V
    May 2004
    SC
    23
    I have had my 09 V on the track for 4 days. This past weekend I blew by every 350Z and Corvette that were in my group. I kept getting comments like: "I can't believe a Cadillac went by me that fast" and "I tried but couldn't catch you" were common.
    The V is heavy. I boiled the stock DOT 3 brake fluid on my second trip and replaced it with ATE Blue DOT 4. The Michelin Pilot Tires do not do well on a road course (excessive wear on outside of front tires). I replaced my front tires with Bridgestone Potenza RE050A Pole Position and I am doing much better.
    Gas milage on the track is about 4.5 mpg.
    I think I am hooked.
  6. #51
    garfin's Avatar
    Apr 2006
    1,117
    Quote Originally Posted by CruzanTom View Post
    I took you that many lapping days to get hooked?!? LOL!
    Best regards,
    Elie
  7. #52
    Automobile(s): ZIP
    50,276
    My V had less tire wear when running 45psi hot in the front with 40psi hot in the rear...
  8. #53
    baabootoo's Avatar
    May 2010
    Racine, WI
    3,497
    Mine too. When I tried 30-something, they wore fast.
  9. #54
    Automobile(s): ZIP
    50,276
  10. #55
    MikeV is offline Cadillac Owners Fanatic
    Automobile(s): '05 Redline CTS-V
    Mar 2010
    Pittsburgh, PA
    172
    Quote Originally Posted by Z06ified View Post
    I saw that in the manual too, and I think the manual is crazy, if they're talking about cold tire pressure. 44psi cold will equate to about 53-55 psi hot, which exceeds the maximum pressure rating of the tire. That much pressure will also cause a scary lack of grip and some very squirly handling.
    If they're talking about 44 psi hot, then that's OK as a MAX, but I don't think they are.
    FYI, max pressure as listed on the tire sidewall is max COLD. It accounts for increase in temp as tire heats up. Plus there is a LARGE safety factor built in there. Engineers don't trust the general public who are mostly idiots.
    - Former automotive engineer
  11. #56
    jenlain is offline Cadillac Owners Member
    Automobile(s): '12 Vagon
    Nov 2011
    Louisville, KY
    60
    Reviving an old thread since invites are starting to go out for HPDEs later this season. Would like to see some Vs at the track this year, as I will be taking delivery of my vagon shortly (currently driving an E90 BMW that saw plenty of track time last season).
    Since there are no Caddy-specific events near me, I plan to tag along with the several BMWCCA, PCA, and PBoC events at Putnam, Mid-Ohio, Barber, and Road America this year. Have also heard great things about Road Atlanta, so may try to take a trip there as well. Anyone else planning to head to the track this year?
    For those who have not gone to the track, its a great learning experience and a fun way to meet new people. The events sponsored by the CCA and PCA tend to be very safe and well-run.
  12. #57
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    27
    4,552
    to do some more thread revival-- anyone know what the typical LS wet-sump is capable of in terms of lateral G's before it starts to suck dry air?
    I know the E90's is 1.4, and that's with two pickup tubes.
  13. #58
    Automobile(s): ZIP
    50,276
    I hope it's more than 1.4...
    OldRoadDawg and OldRoadDawg like this.
  14. #59
    M5eater's Avatar
    May 2011
    Suffolk, VA
    27
    4,552
    yeah... I'm thinking it's not, GM tells the regular vette guys to put another quart in when playing around, and you're approaching Z06 levels of grip. Grand sports with the plain LS3 come with a dry sump these days..
  15. #60
    ekyub is offline Cadillac Owners Fanatic
    Automobile(s): None
    Feb 2010
    104
    Does upgrading brake fluid and installing the optional diff cooler void the warranty?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
