Full Spare tire kit for anyone interested in seeing. I made it work. - Page 10
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 10 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 LastLast
Results 136 to 150 of 207
Like Tree11Likes
2009-2014 Cadillac CTS-V General Discussion Discussion, Full Spare tire kit for anyone interested in seeing. I made it work. in Cadillac CTS-V Series Forum - 2009-2014; Side skirts under V are different than std.cts, what are we using to overcome damaging skirt when jacking car? Any ...
  1. #136
    Blakester's Avatar
    Blakester is offline Cadillac Owners Fanatic
    Automobile(s): 2011 cts-v wagon
    Dec 2010
    Edmonton Alberta Canada
    67
    268
    Side skirts under V are different than std.cts, what are we using to overcome damaging skirt when jacking car? Any pictures?
  2. #137
    jzchen is offline Cadillac Owners Fanatic
    Automobile(s): '85 Sedan de Ville, '10 CTS-V
    Sep 2009
    Arcadia, CA
    39
    340
    Re: Full Spare tire kit for anyone interested in seeing. I made it work.
    Quote Originally Posted by banph View Post
    I have been reading this forum quite often but this is the first time I thought a needed to reply. My wife just bought a new 2012 CTS-V. She also owned a 2009 CTS and when she bought it we purchased the Compact spare kit as an additional option. When she traded it in, we kept the spare tire kit. After reading all the discussions and looking at the Eurotek kit, I was trying to figure out what was different from my OEM kit and the one for $600.
    Here is what I did today. I pulled the front wheel off the CTS-V, since this has the largest caliper and put three spacers (approx 1.2") on the wheel lug bolts. I then held up the compact spare like it was mounted. I spun the wheel and no rubbing occurred. I believe it will fit with a 1 1/2" spacer. Clearly it is tight on the inside of the front caliber but fits with enough clearance to handle an emergency situation. Adaptit USA makes a wheel spacer just like the one Eurotek sells. Its about $50. Model # 51205120. I plan to call them next week and order one with the right 14X150 lugs. Unless I am crazy, this will allow both the front and rear wheels enough clearance to use my current OEM spare. When you look at the Eurotek product that is what they did, provide a spacer. Not clear why they had to mill the wheel unless it is for clearance of the lug nut bolts that attach the spacer. If you order a 1 1/2 inch spacer it appears this will eliminate this problem.
    Again, don't want to come off as an expert here, but maybe there is another cheaper alternative. Eurotek is a good one, but costly. When I emailed them to buy the spacer only, since I had everything else, they told me it was to expensive to build just the spacer and it would cost about $300. They did say that it was a little more complicated since they had to mill the wheel. Not clear why, based on my test fit this morning.
    Well, if anyone out there has different info, please share.
    In conclusion, I know that Cadillac personnel monitor this forum and they should. Clearly they need to provide a better alternative to CTS-V owners then inflatable compressors with sealant. Remember if you have to use the sealant, you ruin your valve stem monitor and that is costly to replace. I also have a 08 Z06 and it comes with Run Flat tires. I don't understand why the CTS-V doesn't.
    I think the reason for no run-flats was a bumpy ride. Run flats ride harsh, even on my '04 AWD Toyota Sienna with the tall sidewalls. Anyways, people who want runflats, AND don't care whether they are running different tires front and back, (I don't because they are staggered fitment anyways, but won't need new tires anytime soon,) can use these:
    http://www.tirerack.com/tires/tires....omCompare1=yes
    for the front.
    And there are several "99" sevice description runflats to choose from (I don't know if this link really works, tried on another tab but it seems generic.):
    http://www.tirerack.com/tires/CompareTires.jsp
    for the rear.
  3. #138
    oldiemotors's Avatar
    oldiemotors is offline Cadillac Owners Member
    Automobile(s): 2009 CTS-V
    Dec 2011
    Texas Gulf Coast
    54
    ... Adaptit USA makes a wheel spacer just like the one Eurotek sells. Its about $50. Model # 51205120. I plan to call them next week and order one with the right 14X150 lugs. Unless I am crazy, this will allow both the front and rear wheels enough clearance to use my current OEM spare.
    Has anyone confirmed that the standard CTS spare will work with the 1.5" spacer from Adaptit? Anyone have the part number for the standard CTS spare kit?
  4. #139
    banph is offline Cadillac Owners Member
    Automobile(s): 2012 CTS-V Sedan 6spd, 2008 Z06
    Apr 2009
    Cave Creek, AZ
    28
    I received the adapter a few weeks ago, but have not tried it on the car yet. It does fit properly on the Compact spare wheel, with no interference. I am confident it will fit the car and clear the brake calipers. I will try this weekend to jack the car up and install and confirm.
  5. #140
    Dec 2011
    Texas Gulf Coast
    54
    Does Cadillac sell a kit for the standard CTS. I called my Cadillac dealer and they could not find one.
  6. #141
    Apr 2009
    Cave Creek, AZ
    28
    They did in 09. It was an option on the order list.
  7. #142
    Dec 2011
    Texas Gulf Coast
    54
    Anyone have a GM part number for the kit?
  8. #143
    Apr 2009
    Cave Creek, AZ
    28
    I installed the spare tire on today using the Adaptit spacer and it worked fine. No issues. Will try to post pictures.
    If you have the ability to get the spare tire kit, then all you have to do is order from AdaptitUSA the spacer. 1 and 1/2 inch with 5 X120 lug pattern. ADAPTSM15
  9. #144
    Apr 2009
    Cave Creek, AZ
    28
    Here are the pictures of the spare tire with the Adapter on the vehicle. Hope this helps people with another alternative.
    The people at Adaptit USA are great to work with. You can look it up on the web if interested.
    dennych and dennych like this.
  10. #145
    Blakester's Avatar
    Dec 2010
    67
    268
    Did you have any trouble lifting car with sizzor jack.(clearing plastic facia?)
  11. #146
    Dogbreath is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Dec 2011
    Peoples Republik of MD
    60
    65
    So just to make it easy for those of us too lazy to go back through the entire thread, can somebody put together the part numbers and manufacturers for the kit?
  12. #147
    Apr 2009
    Cave Creek, AZ
    28
    Not really. If you have the spare tire kit option that came with the cts the jack works fine. I found it difficult to use the jack handle to turn the extension for the jack. it was a slow process moving the handle back and forth so I could make Full turns as well as It came very close to hitting the door. So I used an adjustable wrench, a large one and it worked perfectly. I am thinking of trying to get another jack handle that will fit the slot of the extension and cut it down so it can turn freely, making it a quicker change.
    thebigjimsho and thebigjimsho like this.
  13. #148
    Lenvo65 is offline Cadillac Owners Member
    Jul 2012
    N NJ
    41
    So I bought a kit advertised on eBay advertised to fit a CTS-V and it arrived today as a simply stock CTS spare wheel kit, with no spacer and will not clear front caliper. I've written the seller to try to resolve this, I am assuming from prior postings that buying tha spacer from Adaptit USA along with 5 lugs will solve my problem. Any other approach to resolve it?
  14. #149
    Apr 2009
    Cave Creek, AZ
    28
    Here is the website for the adapter that I bought. I asked them to install 14X150 studs vs the ones that come with them are 12X150. The cost is $3 each for the 14X150 studs. This way you can use your original lug nuts when installing the spare tire.
    Go to this website: http://adaptitusa.com/5x120to5x120wheeladapter.aspx
  15. #150
    FinestKind-CTS-V is offline Cadillac Owners Member
    Aug 2012
    47
    Is there a link to purchase the spare tire kit?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
