Alpine PXA-H800 and aeroforce gauge /nitrous install pics
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By spdmn75
2009-2014 Cadillac CTS-V Appearance Mods Discussion, Alpine PXA-H800 and aeroforce gauge /nitrous install pics in Cadillac CTS-V Series Forum - 2009-2014; So still have to finish up some plumbing of lines under the hood but interior is finished. I had used ...
    spdmn75 is offline Cadillac Owners Member
    Aug 2012
    El Paso, TX
    39
    9
    So still have to finish up some plumbing of lines under the hood but interior is finished. I had used a JL audio clean sweep before with a trunk mount eq. This was running to 2 amps with JL separates and a 12". Sounded ok but did not have the adjustability I was looking for. So I moved up to the Alpine setup. This has a lot more features and can be adjusted on a laptop. So far it's been great. I ended up moving the volume and tune knobs to the glove box as they are not used with Alpine. I added the RUX control head to use as the master volume. It's not required but given the way this car is wired I needed it. I then moved my aeroforce gauge and added my other analogic gauge to the ash tray area. The nitrous window/wot controller is the HSW microedge mounted in the upper arm rest section of the center console. I also relocated the USB/audio in and cig lighter to a different area in the center console to add the arm/ heater and purge buttons. The other 4 black ones are to cycle through the pages on the aeroforce gauges.
    The four clear LEDs are for armed(green) heater (yellow) radar detector alert(red) n2o spraying( blue)
    V locity likes this.
    V locity's Avatar
    V locity is offline Cadillac Owners Connoisseur
    Automobile(s): 2011 CTS-V Sedan A6, 730 RWHP Stock airbox & stock exst
    Jan 2012
    Katy, TX
    1,100
    Re: Alpine PXA-H800 and aeroforce gauge /nitrous install pics
    Nice install! Very clean!
    Aug 2012
    El Paso, TX
    39
    9
    thanks, loving the adjustability so far of the Alpine unit. also has a road eq function that adjusts the sound based on additional noise entering the car
  5. #4
    SecretWeapon is offline Cadillac Owners Fanatic
    Automobile(s): 2009 Sedan, M6, Silver/Ebony
    Oct 2010
    Spring, Texas
    457
    Wow. I am genuinely impressed with what you have done. Kudos sir.
  6. #5
    Aug 2012
    El Paso, TX
    39
    9
    Thanks. I may redo the trunk now as I just have a 12" mounted on the spare tire well
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
